Question about Philips 42FD9932 42 in. Plasma Television
Plasma won't stay on red light flashes and shuts unit off
I have a Philips 42fd9932 42 in plasma. It is about 3 or 4 years old. It is shutting itself off. The green led light that is on when the unit is on will flash to red and then it just shuts down. Is this a part or is it overheating? Any suggestions? Thanks.
  • Anonymous Mar 27, 2014
    lights are flashing also when off
  • 45 Answers
I had similar problem with 42fd9932, run for a few secs or minutes, shutdown and flash red led for ever. Fans in this unit were not causing shutdown although I could stop one and get the red led flashing thing.
Replace c2212 100uf, c2508 4.7uf changed to 10uf, c2664 100uf. I also added clip on heatsink to U7203 8.5v TO-220 case regulator( next to c2212) and a drop of oil to each fan(poked a hole through label center). Something else I did was add a 47 ohm 5w in parallel with fan ps 100 ohm 5 w resistor.
These parts are all located on the two power supply boards. Use Caution 380V is present on these boards. Allow a few min for caps to discharge.
Posted on Nov 04, 2007
I had the same problem w/ my 42PF9630A and I downloaded software updates from Philips.com for my unit. You need a portable memory (I used my daughter's PSP) to download the file to. I then plugged the PSP into the USB port on the side of plasma and the TV did the rest. It no longer shuts off. There are specific directions on the website.
Posted on Nov 01, 2007
    Sergeant:
  • 337 Answers
The fans are visible in the back and they can be cleaned with compressed air with no moisture built up in the hose line,We don't want to spray water in the fans.Is the only thing you can try and the unit's back does not have to be removed.If this does not solve your problem you might need the help of a servicer.Let Us know how it goes or if you need more information.
Posted on Nov 02, 2006
  • Omar Urrutia
    Omar Urrutia Nov 02, 2006
    Your rating response is also important.
Philips plasma with Ambilight...turned on today, no picture. Red light flashes 6 times in succession over and over. The unit is 10 years old .... Repair or replace ?
Could be a power supply fault.
How deep is your pocket will answer whether to replace it assuming there is a repair shop that can repair it at a cheaper price.
Jan 23, 2017 | Philips Televison & Video
Uniplas 30 power light flashing
See if the torch electrodes MIGHT be stuck... welded together. They have to arc and then separate or unit will shut down.
Jun 15, 2012 | Welding Tools
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
I have a Fujitsu 42'' PDS4221 - 10 years old - shuts itself off
See Fixya tips and tricks:-
'Fujitsu Plasma 42" random shutdown - continuous flashing red'
While the model of your set is slightly different, the checks described generally still apply, as it is very similar.
Nov 18, 2009 | Cars & Trucks
Plasma TV Does Not Turn On - continous Red Flashing Light
Had a similar problem with my Sony. Unplug for 36 hours and try again.
Aug 29, 2009 | Philips 50PFP5332D 50 in. Plasma...
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
My phillips flat tv won't turn on?
I have come accross a lot of complaints regarding philips tv's, with premature failures the common ailment. I have filed a complaint at the following:
http://www.consumeraffairs.com/class_actions/
Click the "complaint button" and fill out the form. If enough complaints are filed, an attorney will review them.
Apr 15, 2008 | Insignia 42" LCD Flat-Panel HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42FD9932 42 in. Plasma Television Logo
250 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
