Question about Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping
Toyostove Laser 73 EE2
The stove runs for about a minute and shuts down. display reads EE2 noflame is visible. I don't have a manual, not sure what I need to do. Ifanyone could help it would be greatly appreciated.
Thanks!
Sterling
  • 1 more comment
  • Anonymous Dec 18, 2008
    I have
  • Anonymous Dec 22, 2008
    toyostove 73 EE2 - I pushed the 'burner' button, will that restart the stove
    EE2 was on when I got us this morning with the smell of fuel in the house. What's wrong. I pushed the burner button and the temp gauges came back on. The green light is flashing. Does that mean the heat will come back on now.
  • Anonymous Apr 09, 2009
    my toyo is
    getting fuel it will startup ignite and run on medium th will click over to high run for alil bit then flash ee2
  • 8 Answers
The firing sequence for a L73 is blink, blink, blink, on the green burner light, then it clicks up to the medium, amber or yellow light...that's when the pump kicks on. If you hear click, click, click, or thump, thump, thump, that means the pump is starving for fuel. The problem is from the carburaot/sump back to the fuel tank. You may have icing in your line or a line restriction, no fuel, plugged fuel filter or plugged sump screen. You can thaw your fuel line, until you have a free flow of fuel and then push the red restart button on top of the sump. Try to restart your Toyo.
If you follow the firing sequence and hear no click, click, click or thump , thump, thump and your Toyo goes off on EE2 then you can have a dirty flame sensor...the whilte wire running to a U shaped part that is the ground for the entire unit. You can take ythe ytwo phillips screws out, turn the part to the side and wiggle it out. Clean it qith a green scrubby or sandpaper and put it back in. Be sure it points stright down. Then take out the igniter which are the red wires. Put a long screw driver in there and rattle it around real good. You are trying to shake any carbon cxhains off the burner ring that can be "shorting" the flame sensor. You can also removee the 1/2 inch flare nut from the fuel nozzle...brass yellow colored metal part, and put a paper clip or wire down that about 3 inches. That will clear any blockage in front or inside it. Put everything back together, hit the red reset button on the sump and re-fire your Toyo. You might get it going in this manner. If not, you may need a tuneup because your Toyo is too sooted up to run correctly. Try these things and post back!
Posted on Nov 14, 2008
After my stove runs about two cycles, it shows E E 2. we relight and it ignites and then shuts back down with the error message. The tank is full, no air in the fuel line or filter. suggesations?
Has this unit been serviced. Sounds like the Flame Sensor is dirty and not sensing flame OR this actually isn't any flame due to an ignitor or fuel issue. Here is a complete explanation and diagnosis of the EE2 problem: Toyostove Error Code EE2
Feb 07, 2016 | Rinnai Toyostove Direct Vent Heater:...
Lazer 30 error 22 on panel
The stove quit three times with an ee2 message. The stove is trying to save you from flooding. You may have a fuel problem that is causing the ee2 problem. After three time the stove locks out and won't let you try again. Find out whats up with the fuel. Unplug the heater for 20 minutes and you will be able to try again. Also make sure the igniter is getting hot. Two red wires going into the burner should get hot.
Tom
Sep 25, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
My toyo lazer 30 won't start, and the EE2 problem comes up.
With an EE2 message you have a problem with the stove igniting during start up. If you continue to try you will end up with an EE22 and the stove will be locked out. If so, un plug for 20 minutes. While you are waiting check out you fuel system. Low fuel, no fuel, dirty filter on tank and stove. Be sure to bled the air off the top of the filter when you change it.
Keep us posted.
Tom
May 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Lost manual stove is blinking code ee2
No ignition. Check the igniter by feeling around the two red wires when you try to start the stove. They will get very hot so be careful. If the igniter gets hot you have a fuel problem. No fuel, low fuel or dirty filter.
Keep us posted,
Tom
May 10, 2010 | Rinnai Toyostove Direct Vent Heater:...
EE2 usually has to do with fuel flow but could also be a dirty flame rod which can be cleaned with some steelwool. You should check your filter and also the strainer in the heater. Have something to direct the kerosene that will come out of the strainer into a bowl or something or just have some rags or paper towels ready. You can find the owners manual at www.toyostove.com.
Mar 17, 2010 | Rinnai Toyostove Direct Vent Heater:...
Gettin an EE2 error - replaced the fule filter at the tank, removed and cleaned the sump screen, no luck. Does the sump screen on this stove fit into the sump with the open aspect of the screen facing the...
The open end goes toward the back of the heater.
Next try cleaning the flue.
Other potential causes for an EE2 are malfunctions of the circuit board, flame sensor or or fuel pump.
-Helping Hands Services
Fairbanks, Alaska
Oct 11, 2009 | Rinnai Toyostove Direct Vent Heater:...
Not having a cleaning in the last couple years may be the problem. Carbon build up in the burner pot and on the flame rod (a chain of carbon) will cause the flame to not be sensed. Then the flame will burn out. A temp solution would be to unplug the stove, then unscrew and jiggle the flame rod to break the chain. When tightening the screws do not over tighten. You could also try hitting the edge of the pot to see if you can knock the carbon loose. You could also have a warped burner ring which would cause problems keeping the stove running.
Nov 03, 2008 | Rinnai Toyostove Direct Vent Heater:...
EE2 code for toyo 3
What Does EE2 Mean? Laser 30, 56, and 73 model Laser heaters cease operation and display
the EE2 code on the control panel (instead of the clock or temperature settings) when the primary
flame rod on the heater fails to sense a flame during the first 5 minutes of the Ignition and Pre-
Heat cycle. On the Laser 55 and 72 the heater will stop and the red Reset lamp will light rather
than the EE2 code. (Note: There may be other reasons for the reset lamp to come on but much of
this information will apply.)
What Can Cause An EE2 Error? The primary flame rod is the only sensor in the heater that
can cause the EE2 error. Thus, if it occurs, either there is (1) no flame to detect, or (2) the
sensor failed to detect the flame. The flame rod is located on the lower 1/3 of the burner. It is a
heavy wire with a ceramic insulator. A single white insulated wire connects this device to the
main circuit board.
Dec 12, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Dec 01, 2007 | Rinnai Toyostove Direct Vent Heater:...
Rinnai Toyostove Direct Vent Heater: Toyostove Laser 73 Shipping Logo
4,401 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
