Question about Inovix iMP-33B MP3 Player
LED indicator flasshing Red/Green and cannot be cleared
Hi all, I have just bought anInovix IMP21 MP3 player and have recently successfully load it with a whole session of music which I have now heard and cleared and am in the process of downloading a new selection. However, having put the new tunes on the MP3 when I turn on the LED indicator light just flashes red/green and I cannot seem to clear it no matter what I do. Can anyone assist please.
2 Suggested Answers
SOURCE: down laoding music
iTune format will not play in a MP3 Player, you must first convert them to MP3 format.
Posted on Sep 07, 2007
Flasshing red light and wont play anything
red light flashing indicates an issue with the power supply board, there may be other issues but until this is resolved you cannot do anything with the unit. contact point of sale or b and w service to have the problem resolved, this is a known problem!
Jan 17, 2011 | B&W Bowers and Wilkins Zeppelin iPod Music...
The green light is blinking on the supply unit but it not coming on or booting up , i need to know if the supply unit is bad
Close examination of your power supply may reveal if the psu is bad.
When the power supply is plug in ac socket the green indicator led inside the motherboard will lit steady green. See if by turning on the cpu you will see some sparks in the power supply connector attached to the motherboard. This is a clear indication of a bad or shorted psu.
You can also smell if there is a burning inside the psu.
See if the fan inside the psu is working if not then its a clear indication of a bad psu.
Using a multimeter if you have one measure the dc voltage coming from the supply connector. Insert the black probe to one of the black wires in the connector. And the red probe to the red wire in the connector. the reading should be +12VDC. Put the red probe to the red wire and it should read +5VDC. Any readings below this, means bad psu.
Measure also the output voltage when there is a load in the power supply. Connect a CD-ROM drive or hardisk and measure again the voltage. Dropping of voltage when put some loads is a clear indication of a bad power supply unit (psu).
I hope this will help you.
Thank you for using Fixya!
Jan 11, 2011 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Any idea how long it takes to charge the Sylvania SMP2012? How do you tell when it is fully charged?
The Sylvania SMP2012 charges fully in under 15 minutes on a regular USB port. Sometimes it's much quicker.
When the device is charging, both the red and green LEDs are lit (not flashing). When the device is fully charged, the green LED turns off, and only the red LED is on.
Sep 12, 2010 | Sylvania SMP2012SL 2GB MP3 Player
Silver Sylvania smp2012 2gb what kind of charger do I need for this mp3 player
No separate charger is required. Use a USB cable to connect it to any computer (desktop or portable), or to any powered USB hub. It should charge in about 5-20 minutes. While charging, both the red and green LEDs are lit. When fully charged, the green LED turns off and only the red LED is on.
This device should also be possible to charge using a stand-alone USB power source, such as those used to charge Blackberries.
Aug 14, 2010 | Sylvania SMP2012SL 2GB MP3 Player
NAD C521 on / off button light
"POWER ON: Press this Green button to switch on the power to the disc player from Standby mode. The LED will change from Amber to Green, and the EFL display will illuminate."
So besides the L.E.D. the unit has another visual indicator that it's turned ON, the display lights up. Is this worth pursuing a fix?
Mar 03, 2010 | NAD C521 CD Player
Ipod shuffle cannot hear music through headphones
Is it really a Head phone issue? lets find out that first.
If your headphones don't work as expected or not at all, connect the headphones to another audio source, such as your computer's speaker jack or another audio device that has a 3.5 mm stereo headphone jack, and test them. If your headphones are under warranty and still don't work, you can order replacement iPod headphones - Link - https://selfsolve.apple.com/GetWarranty.do;jsessionid=1B9ED1B556F0978A6C914A52711E59AA
And about the yellow and green LEDs
The yellow LED shows when the player is charging and a blinking green LED indicates you've paused the player.
At the back is another LED, the 'Battery Status' button, just below the toggle switch; when pressed, it flashes to give you a general idea of how much battery charge remains... green indicates a full charge... yellow, a low charge... red, very low charge... and no glow means its given up its ghost.
Hope this helps :-))
Dec 24, 2009 | Apple iPod shuffle MP3 Player
Wharfedale s20030 speakers broken?
First, check input power (electricity) of your speaker. You can see lamp indicator on speaker (usually LED lamp, Light Emitting Diode, green light or else) must be light ON.
Two, jack line out (usually green) on the speaker, you must touch that jack. Don't worry, you can't heart attack cause of it (for touching that jack, DC-Direct Current supply). If you hear some noise, sound of droning, buzzing, that is indicate of sound will be come out from that speaker.
Three, you play WinAmp software (or Windows Media Player, from Microsoft) and get in one of mp3 file, and load it into WinAmp player. Make sure if your mp3 file is normally sound.
Four, plug in your green jack (of speaker) to the line in of your sound card (refer to mainboard PC, if your soundcard get in ONBOARD or plug in PCI slot). Green jack line of speaker to socket green of sound card.
Five, now you can hear sound of your song....
Sep 06, 2009 | Computers & Internet
Little manual does not indicate to charge unit before using
Hi-the light stays Green when it is fully charged-does not flash-just stays on!
Dec 01, 2008 | Mercury Electronics MP250 (128 MB) MP3...
Computer won't turn the device on.
HOLA NO TENGO EL SOFTWEAR DEL MD-PORT DG2 COMO LO PUEDO BAJAR A MI PC PARA INSTALARLO.
Oct 26, 2007 | Xitel MD-Port DG2 (MDPORTDG1)
Inovix iMP-33B MP3 Player Logo
35 people viewed this question
Top Inovix Audio Players & Recorders Experts
Tom Chichester
Terry
Terry
Are you an Inovix Audio Player and Recorder Expert? Answer questions, earn points and help others
