Question about Clarion VZ401 Car Video Player
Clarion vz401 unlock reset?
Have a Clarion vz401 stereo system. changed battrey in the car and my son entered the wrong password 3 times and the whole system locked up. Does anyone know how to reset it so that it will function again? Thanks
  • 1 more comment
  • Meagan Anema
    Meagan Anema Feb 28, 2016
    I have THE EXACT SAME PROBLEM! There's no way to unlock it. And apparently Clarion is the only one who can bypass the password setting. And they want around $200.00 to fix it. You'll have to remove the stereo, send it to them & pay for shipping-both times!
    I think the only thing you can do, is disconnect the battery, and try to do the password again (If it'll let you)
    Good luck! I'm in the same boat :(
  • Geraldo Bezerra
    Geraldo Bezerra Dec 12, 2018
    VX401 ASX: 4356 Funcionou.
  • Christian Kingsley
    Christian Kingsley Aug 31, 2019
    Yeah guy it worked for me switch
    off the the set hold Down volume minus while holding put it on code will appear once more input 4356 it worked for also clorion vx401 thanks
    New Friend:
Ok i have a vz401 and it was locked out so what worked for me is.
hold the volume down button then push the power button after you are holding down the volume button.then if you dont know the code put in 4356 it worked for me
Posted on Aug 20, 2016
  • John Korschen
    John Korschen Dec 05, 2017
    Dave Phillips way worked for me. Thanks dude!!!!
  • 752 Answers
Disconnect the battery and wait about an hour, reconnect battery and try again. If this does not work take it to the dealer.
Posted on Feb 28, 2016
4 Suggested Answers
SOURCE:
SOURCE: multiregional code for clarion ohm107vd
Press 9653 on the remote then press 0 when asked for region
Posted on Jun 18, 2009
smarthome2
  • 1114 Answers
SOURCE: clarion vrx485vd wont play videos from iphone when connected
You need a composite video cable to the Clarion Video input. The usual ipod adapter is for audio only. If you have an AV ipod adapter and you still don't have video, the signal is not strong enough for the clarion to see it and you need a 12volt pre amp. you can find them online starting around 25. Hope this helps
Posted on Jun 24, 2009
SOURCE: My clarion nx409 has frozen on the clarion screen
Did you try re-setting the tape. Its reset switch is located right to AUX-IN pin.
Posted on Nov 12, 2010
I calibrated my clarion vz401 wrong now I can't operate from the screen at all what can I do
If all else fails, I recommend contacting a local car audio professional or Clarion customer support directly here:
https://clarion.com/xe/en/user-support/inquiry/contactus
I trust this information proves beneficial.
Apr 27, 2016 | Clarion Car Audio & Video
How do i get my clarion vz401 too play dvd videos from my USB
The Clarion VZ401 can only play audio (MP3 or WMA) files from a USB device. This is listed in the manual on both page 33 (USB Operations) and page 46 (Specifications). This unit can't play audio file with DRM and some USB drives may not be compatible with the device. It can play some videos from some IPod/IPhone models with the Clarion CCA-750 adapter. This is a USB to RCA composite stereo audio/video jacks cable. This feature isn't compatible with the Lightning connector or some versions of the iOS operating system. To view any other videos, you need to play them back on a device that can directly connect to the composite RCA audio/video ports (AUX In or AV In).
I hope this helps. The list of compatible IPod and IPhone models is available from Crutchfield on the VZ401 Details tab: http://www.crutchfield.com/S-ix4f1cAUkb9/p_020VZ401/Clarion-VZ401.html . This tab also has a link to the manual; the direct link is http://d2stobyut4u5rx.cloudfront.net/ImageBank/v20150407084800/Manuals/020/020VZ401.PDF .
Nov 18, 2015 | Clarion Car Audio & Video
I Need The Wiring Diagram For The Clarion Vz 401
[PDF]VX401 VZ401 - Clarion
www.clarion.com/br/pt/pdf/VX401_Manual.pdf Clarion Co., Ltd.VZ401. Owner's manual & Installation manual. Mode d'emploi et manuel d' ... Congratulations on your purchase of a Clarion mobile electronic product. We are.
Sep 22, 2015 | Clarion Car Audio & Video
Wiring diagram for clarion vz401
Get the Owner's Manual here.
http://www.clarion.com/ca/en/pdf/VX401_Manual.pdf
The Installation Guide and Wiring diagram starts on page 47.
Sep 09, 2015 | Clarion Car Audio & Video
How do I connect a reversing camera to a Clarion VZ401E stereo so that it shows when reverse gear is selected.
If the stereo does not have the ability then take the connection from the reverse light switch at the gear selector!
Dec 27, 2014 | Clarion Vz401 Car Stereos with Bluetooth
Clarion nx501 with hino and password
i hAVE the same exact issue and the 4 digit password to unlock it is the last 4 numbers the HINO trucks V.I.N... they say u only get 3 tries and it locks it and the only way to unlock it is to contact clarion... lick my balls clarion the default password is 0000 and u get 3 tries but just disconnect the power and reconnect the power and BAM... you will be asked to enter a security code all over again...0000 that is your unlock code.
as for the start- up HINO screen... good luck. its called a splash screen and you would have to hack clarions firmware in order to do so and i suppose if you were able to locate the internal hard drive but even then. clarion invested billions to protect their operation systems in their devices. i think the image is burned into the chip where the head unit was sent from a hino dealer brand new in a box directly to clarion's I.T. to have changed cause it comes factory as a clarion boot screen.
you will also notice that the hint clarion nx501 wiring harness is altered so to make work in that truck that only comes with two front speakers.... the rear speaker leads are nowhere to be found; GONE like a new brides panties!.. you also won't have any rya leads ect.. gay gay situation and if u figure out the splash screen change let me know.
peace.
S.D
Jan 16, 2013 | Clarion NX501
How do i change the region codes on my clarion vz 401
My head unit clarion vZ401 plays only region 1. I live in Australia and this head unit is now ******** me as all DVDs sold in Australia are region 4. Can some please tel me where to buy a hack cd or add on . Wayne
Sep 17, 2012 | Clarion VZ401 Car Video Player
CLARION ADZ628R STEREO UNLOCK CODE
To reset , leave SWITCHED ON ...UNDISTURBED for up to 24 hours
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000000 + + + + on a label somewhere on the metal casing.
(There are usually two barcodes on one label. The one required is the lower one )
T
If not then it will only be available from your Main Dealer or a Decoding
Apr 16, 2009 | Clarion ADZ628R CD Player
Clarion VZ401 Car Video Player Logo
5,616 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
