Question about Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Fan assisted oven not working
The fan assisted electric oven on our Classic 110 Dual Fuel cooker has stopped working. I presume the problem lies with the heating element, although I suppose there is a chance it could be a faulty thermostat. Is the element easily replaced? I am a reasonably competent amateur but obviously don't want to take any risks. Any advice will be gratefully received!
  • Sarah32 Feb 27, 2008
    Yes my electric oven on the rangemaster doesnt work. The fan just blows out cold air. Whats the problem?
If the fan is still working then it is the element that has gone. This is easily replaced as you only need to remove the back panel and swap the the element.
Posted on Jan 12, 2008
The fan on my diplomat oven does not spin but the thermostat is working.I have got access to the motor and tried cleaning it.It worked for one day but then it stopped working.Does this mean that i need to replace the motor.
Posted on Oct 21, 2008
SOURCE:
I have a 4 year old range master classic 110 Tonight both ovens stopped working and the clock does not work also. However the grill works and the hob works.... Any idea as to the problem? I have checked...
Hello Jeff,
it seems to me a problem with the timerfunction of the clock.
Clocks are the most source of problems, so when I refurbish a cooker and the timer does not work properly, I shortcut the timer as new clocks are very expensive.
In that case, the clock itself stays working.
For doing this, you need to lift the hob.
BE CAREFULLY, AND BE SURE THERE IS NO TENSION ON THE COOKER
I hope this will help you and I wish you a good weekend and a nice meal with your friends. Dik
Jul 20, 2017 | Rangemaster Classic 110 (Dual Fuel) Dual...
I have a range master 110 clasic 2007 when the small oven was switched on a fan would come on. my engineer says that this model has no fan because it is gas.
I have a Rangemaster and like yours is dual fuel. Gas hob and electric oven. The large oven is fan assisted but the small oven, on the right hand side of the range) is self cleaning and not fan assisted.
Hope that helps.
http://www.pricerunner.co.uk/sp/rangemaster_classic_110.html
Mar 31, 2011 | Microwave Ovens
I've a dual fuel 1100 rangemaster professional- when i use the ordinary oven i get a pool of water under it,what's causing this and what can i do to stop it
this condensation. and your cooker is removing the moisture in the air in the room. this if not fixed will rust your cooker from the inside out , you will need to fit an extractor fan to your room or if one already fitted get a larger one. or use a dehumidifier
Feb 27, 2010 | Rangemaster Professional 110 (Duel Fuel)...
The fan has stopped orking on my new world oven
I have no worked on a new world oven, but i will assume you speak of a convection oven.
Typically convection ovens have a door switch a motor and a run/start capacitor which helps the motor "turn over". I suggest, you have the oven cool, remove anything blocking the convection motor. Take your hand and spin the wheel, then while its spinning turn it on. You may have to try counter or clockwise. If you cant spin it at all, you have a bad motor, if the motor starts up with your manual assistance, the capacitor is bad. If there is not even a hum, a door switch is faulty, that or the motor has a thermal overload (usually a red button on the motor that needs resetting).
Dec 19, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Diplomat elite (MFI)
it is dangerous there is a short do not use until its been electrically checked out. eg resistance to earth.
Mar 25, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Fan not working
test fan for resistance with multimeter or get new fan from spares at rangemaster number is 08707 895 107
Jan 27, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Oven fan noisy/broken
this noise probably means that the fan is about to stop working, this is what happened to mine. You can easily buy replacement fan off E-bay (it seems easier to find the right fan on e-bay that any of the confusing supplier sites). You then just need to remove the inside oven back and the outside electrical to replace the fan.
Sep 24, 2007 | Rangemaster Toledo 110 (Dual Fuel) Dual...
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Rangemaster Classic 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
2,668 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Thomas F. Schneider
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
