Question about Rosewill RADEON 9200LE (128 MB) Graphic Card
Monitor picture is blank on Windows startup
I have Radeon 9200LE video card, and I run it on Windows XP. Whenever I turn on my PC, everything is fine until the Windows startup, then the monitor turns black and I have tu restart the PC. That happens a few times,and then 2nd or 3rd time, it's suddenly OK,and Windows start normally. This is not so much of a problem but it's very irritating because every time I turn on the computer, I have to restart it 2-3 times before I get to Windows. First I thought it was the drivers, i tried the Omega package, but the same thing happens with or without the Omega. Can you maybe link me to some better and more suitable driver download?
  • 30 Answers
There is ATI Catalyst control centre, which can be downloaded at: http://ati.amd.com/support/driver.html But, I do not think that the problem is from the graphics card. Why is it that you think so? Did you recently install this card? When the computer restarts like that, without any warning, it is often because of a System Error. You could try to reset the computer to a point when it worked fine.
Posted on Apr 07, 2007
Monitor goes blank when trying to use radeon HD 2400 Pro graphics card
Well Michael,
it can be your monitor thats broke u can test it on a other system and see if the monitor works or not,if it works than u know its your graphic card thats broke and u should replace it
May 09, 2014 | ATI RADEON HD 2400 PRO Graphic Card
When i put my AGP ati radeon x1300 video card in it, it makes a blank white screen, any help
Have you turned off any onboard video card that is running??
if not go into the bios(f10 when you see the startup screen) and go to video:agp
If this is not the case try a older or newer version of the driver. Start windows in safe mode and install it that way.
remember that you can always start windows in safe mode even if your graphics card is not working as it will run in software mode instead.
Mar 16, 2010 | Medion MD-1768 PC Desktop
Radeon X1300 card displays blank screen at logon
Boot the system in safe mode. Go to device manager and under display adapters , right click on the onbaord graphics adapter and disable the same. It worked on one of the systems i troubleshot for the same problem.
Thanks for using Fixya
Proton
Aug 28, 2009 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
No picture on properly connected TV
Are you sure that both in windows control panel AND in CCC the tv is either selected as extended desktop or as cloned screen?
Jun 08, 2009 | ATI RADEON X1650 Graphic Card
Blank screen after boot up
Remove the card, plug into your built-in card. Start your PC in safe mode. Uninstall all ATI software and delete the card from Device Manager. Restart. Reinstall the ATI drivers. Power down. Install the card and connect your monitor to it. The OS will find the card in default mode - let it. Restart. When it comes back up, you will be able to select the full range of operating modes.
BACK UP :)
May 03, 2009 | ATI RADEON HD 2400 PRO Graphic Card
Monitor goes black after windows boots up
Try removing the video card, and look up your motherboard / system manual on dell's website on how to manually reset the bios.
1. Remove video card
2. Reset BIOS (physically opening the computer and using a special jumper and/or removing the battery...what ever the manufacturer says to do to reset the BIOS).
3. After BIOS is reset, try booting up via your onboard video card first. Once you get that working, go into the bios settings and make sure it is set to boot the onboard only for right now and then you can make sure the ATI software is fully uninstalled when you get into windows.
4. Reinstall the ATI card and boot up with the video still connected to the onboard card. See if it will let you install the driver.
The trick here is to reset the bios and get the system booting off the onboard card if at all possible. If that works, then you can always reinstall drivers and then tweak the bios to boot off the AGP card instead of the onboard.
May 01, 2009 | Rosewill RADEON 9200LE (128 MB) Graphic...
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Display blanks after installing drivers
Try the final AMD Display Driver (version 8.31) downloaded directly from AMD for the Radeon 9250 series running in XP. It will be several years more recent than any provided in Windows XP (by Microsoft), and may just fix your problem. The fact something causes XP to identify your Radeon 9250 as a 9200 Pro shows that something is not right. You might also want to launch Device Manager, use the option to show hidden devices, and delete any "ghost" video cards. I suspect a 9200 Pro may be a ghost, which could be causing problems.
Sep 13, 2017 | GeCube Computers & Internet
Screen goes blank on Log on
You must uninstall your previous video card drivers before installing the new card, especially if they were nVidia drivers.
Jul 23, 2008 | IBM NetVista PC Desktop
How to tell if computer hardware will be sufficient for Flight Simulator X
From the specs you have supplied, your friends computer should be able to run FS X just fine.
Matt
Apr 16, 2008 | Computers & Internet
Rosewill RADEON 9200LE (128 MB) Graphic Card Logo
77 people viewed this question
Top Rosewill Computers & Internet Experts
Steve Allison
Steve Allison
Ian Ballard
Level 1 Expert
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
