Question about Toshiba DR4 DVD Recorder
Problems finalizing discs
When i record anything and go to finalize the disc it says ther is a problem with my disc and an error 14 comes up. But i know the disc are compatable because the first four discs i did worked but now it wont let me finalize any disc what is the problem.
  • 4 more comments
  • Anonymous Nov 24, 2007
    won't finalize discs eroor code 14 message say function terminated because of error on disc. disc are brand new and clean. I am extremely disapointed with this recorder. this is bullshit!
  • Anonymous Dec 24, 2007
    I have studied this recorder over and over and I clearly understand the manual. I am having the same problem trying to finalize my disc. I will never purchase another Toshiba again as this is BS.
    It's not the operator it's the player itself. It has too many dysfunctional problems and customer service has no idea of how to help you.
    I will search for the firmware upgrade but I won't purchase anything for it.
    I will give this piece of junk to the goodwill if it doesn't work properly by 12-31-07.
  • bzak55 Dec 29, 2007
    Exactly my problem, I have tried a multitude of different discs and always the same problem. It has a 10% sucess rate. I will never purchase a Toshiba DVD recorder again. This DVD recorder is JUNK!
  • gmm2626 Feb 19, 2008
    I keep trying and trying but it won't finalize. It used to work but now it doesn't. When I try to finalize, it always flashes "Error 14" I don't know what to do.
  • Anonymous May 18, 2008
    i get "error 14" on my recorder , everythin works normally i can still record and watch programs , but the "error 14" sign keeps flashing and the timer doesnt show.
  • dii1972 Feb 03, 2009
    flashing err 14
Check to see if you are using 16x media.  If you are you need to get a firmware upgrade from Toshiba.  Contact their support number listed inside of the manual.  They will ship you a dvd to insert into the unit.
Posted on Oct 29, 2007
Solution 2 worked for me thanks
Posted on Jan 21, 2009
Hit display to remove error message. Clean disc possibly several times. When completely dry, try again.
Posted on Jan 26, 2007
This seems to work most of the time. I record a full disc with timer. Turn on the recorder let it load the disc, then eject the disc, then close it and let it load. Go through the finalizing steps, at the end choose the recorder to shut off.This week I did three in a row and they all finalized ok.
Posted on Sep 26, 2009
Disc error shows up after loading Problem with the Sony RDR-GX300 DVD Recorder I record a show then go to play it and it does, but when I open the disc tray and then put disc in again to view message...
Recording tv program or duffing none codes dvd disc,must wait it for finalizing code done completely before can take it out or can be watching it on the same DVD recoder player or a compatible one.Record other disc,just must wait the disc to completely finalizing it final codes,the disc should play with no problems.
Mar 22, 2011 | Sony RDR-GX300 DVD Recorder
Finalizing a DVD-R blank disc
try changeing the disk name and then see if the finalize option is availalbe.
Jun 18, 2008 | Sony RDR-GX315 DVD Recorder
DVD Recorder is ruining the DVDs
Here is the link to the manual for LG DR1F9H
read pages 33&34
you may be using wrong
disc or wrong mode
Dec 13, 2007 | Televison & Video
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Magnavox DVD recorder...finalizing problem
The manual isn't too helpful either - "Recording error other than below," it says. There are a couple of possibilities. The Philips/Magnavox/Funai recorders automatically record in VR mode when you use +R discs (there are two possible recording modes - V Mode and VR Mode). Is it possible that you have switched disc types lately? If you are currently using -R discs, switch to +R and vice versa. The manual states that +/-RW discs take a while to initialize.
I couldn't find a full factory reset on that one, so you may have to unplug the unit for about 20 minutes to restore all the defaults.
Another possibility: Finalization requires some extra space on the disc. If you accidentally pressed the button that changes the recording format between SP, EP, LP, etc., you may not be able to fit the same amount of video on the disc that you were able to fit before. You can change the format by pressing the Disc Mode button on the remote - LP Mode will fit 3 hours worth of recordings onto a 2-hr disc and is considered a "medium quality" recording. Try changing the Disc Mode to LP and see if it will finalize the next disc that you record. The downside of this possibility is that the discs that you have already made that are giving you errors are not "fixable" - you will will have to re-record the shows to a new disc in LP mode.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Recording error
mine was doing the same thing.and we found out that if you recorded something and dont finalize it will not recored anything else till you finalize what you recored then it works again
Jul 07, 2008 | Philips Magnavox MWR10D6 DVD Recorder
Error 14
Check to see if you are using 16X media. If so contact Toshiba for a fireware upgrade. If that is not the problem try cleaning the disc and cleaning the unit with a DVD Laser Lens cleaner. Then try again.
Mar 30, 2008 | Toshiba DR4 DVD Recorder
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Finalizing and reading discs
What a load of rubbish this camcorder is and Samsung customer service is a load of rubbish too.
Jul 11, 2007 | Samsung VP-DC161 DVD Camcorder
Toshiba DR4 DVD Recorder Logo
979 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
