Question about Whirlpool ED0GTKX Side by Side Refrigerator
Whirpool Side by Side Ice Dispenser Freezes up
I manage a rental for a friend and the tenants have been complaining of ice build up on the inside door where the ice dispenses through the shoot and on the inside of the freezer compartment where the ice maker is located. I suspect that the flap isn't sealing when dispenser is used creating air sipage and the ice buildup. The model number is ED250FXHW02 but can not locate that model number on any web site that I have researched. Any suggestions on how to approach this problem? Or, where I could find a repair model that would help me understand the dispenser system? v/r 3d
  • 237 Answers
Think you have it figured out. Just had a similar problem. The flap leaked air (moisture) up into the area which then froze. Then the customer chipped it out with a knife and not only damaged the flap seal worse but also made the chute area rough from the knife tip "burrs" in the plastic chute. A new flap door with factory seal along with sanding down the burrs cured the problem. Spraying something food grade like Pam cooking spray (very lightly) will aid in the ice cube/crushed ice to slide down the chute better. With any refer, keep the moisture out or it WILL freeze up stuff.
Posted on Nov 09, 2006
Ice dispenser freezes up and will not dispense ice. It freezes so that I cannot remove the bin.
Your door on the dispenser is not closing and sealing. Probably have corroded linkage and solenoid and/or curled door seal that is alowing cold air to escape from the freezer which causes frost to build up inside the ice shoot.
Mar 29, 2011 | Refrigerators
I have a whirpool ED2VHEXTB side by side: ice maker works fine but often the ice freezes while inside the automatic despencer and wont come out
Check to make sure that the dispenser flap is closing properly. Sometimes an eyelet will break off and cause it to see ackwardly. They make ita kit to fix that even thought they try to get you to purchase a new door.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Oct 28, 2010 | Whirlpool Refrigerators
FROST BUILD UP ON ICE STORAGE BIN AND INSIDE OF
Most times this is caused by the dispenser door not shutting all the way. This causes moist air to be drawn in through the opening and the moisture will freeze in that area and also cause the dispenser door to have even more problems closing. Check the door and get me your model number so I can list the parts that are most likely causing this, Thanks Sea Breeze
Oct 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Oct 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
No water but ice is fine
turn freezer side to zero for 1 minute press water dispenser
Mar 29, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
Water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
Mar 01, 2008 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Whirlpool ED0GTKX Side by Side Refrigerator Logo
1,041 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
