Question about The Times Case Corporation Tractors International Harvestor
Need Case 1390 Tractor controls layout
I just got a Case-1390 tractor and all of the controls labels are worn or missing. I need the basic transmission, transfer case and rear hydraulic control layout
4 Suggested Answers
  • 3519 Answers
SOURCE: i have a case 4210 farm tractor and need to know
Older case machines used a fluid identified as TCH (Torque Converter Hydraulic) for both the transmission and the hydraulic system. It's not readily available so has been replaced by default by separate products. Hydraulic fluid for the cylinder system, and transmission fluid for the torque converter. I'm currently using NAPA TDH with no problems.
Posted on Sep 08, 2009
SOURCE: diesel tractor ran out of fuel now it won't start
You have to take the air lock from the fueling system.
Posted on Mar 04, 2010
  • 68 Answers
SOURCE: I have a ford tractor and hydraulics are slow
not so fast,, yes thick hydraulic oil can cause slow hydraulics and if the hydraulics speed up when warm then this may be your problem. if they dont then you need to look at possible problems with the pump, the spool, or linkage to spool. remember that speed is flow, a pump can have good pressure but lousy flow. also there should be some kind of pressure relief valve in system if this stuck open then it will let oil go back to tank causing your problem. there is no quick answer to your problem but there are a lot of possibilities. need to do some diagnosing!
Posted on Mar 11, 2010
Anyone have auxiliary hydraulics layout particularly where/how its plumbed into control valve
PDF]2013 Skid Steer Loader Parts - Tractorpartsasap.net - All ...
www.tractorpartsasap.net/.../2013_Skid-Steer-Loader_Parts-Catalog.pdf
Auxiliary Heaters . ... Hydraulic Lift Cylinder . .... Service Manual - Tells you how to take the skid steer apart, how to fix it, and how to put it back together ... in the serious repairs or restoration, you need the shop service manual; It can give you many ...Bobcat. 520, 530, 533. 122571. $48.00. Bobcat. 500, 600, 610. 122521.Missing: layout ‎plumbed ‎into
[PDF]PARTS REFERENCE GUIDE - Service Motor Company
servicemotor.com/catalogs/PM-8490.pdf
HITCH PARTS. 125. HYDRAULIC PARTS ... Find the same heavy-duty quality builtinto Case IH batteries for your truck ... lawn and garden tractor, Case IH has the ... Whether it's off-road, lawn and garden, automotive, or marine application, look ...... 12 Gauge. Aux. Lead, 3/8" Eye with B- Splice 12". ZQC708101. 4 Gauge.Missing: layout ‎plumbed ‎1977 ‎clark ‎520
Massey Ferguson Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages9/
What hydraulic fluid is needed for a Massey Ferguson 390 · MF135 Selling ...... Hydraulics quit working after installing Aux Hydraulic control valve. MF 135 lift
Case Farm Tractor Parts and Manuals - Yesterday's Tractors
Dec 12, 2015 | Garden
Case tractor problems
The clutch plate is worn out and needs replaced. They are a pain to change so replace the throw out bearing at the same time because they are inexpensive and it is cheap insurance of not having to do the job again.
Jan 31, 2014 | Garden
Case tractor
the brake come apart, worn out, or need adjusted.
Dec 05, 2013 | Garden
NEED ALL DIMENSIONS FOR JCB 3CX4TJ MAIN PUMP
Is there any hydraulic oil that is compatible with a case 1390 tractor?
Jul 19, 2013 | Jcb Motorart 13136 3cx Backhoe 187
Ford 1620 tractor pops out of 4wd
This is the wrong section for this problem, but based on the symptoms you will need to remove and tear down the gear box, you have worn parts.
Jun 12, 2012 | Cars & Trucks
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Jun 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
2090 case trasmission problems
That's because you have two separate pumps controlling each. My best advice is to get a farm mechanic to take a look...it may be a simple seal to a need for a rebuilt pump. www.nyagparts.com
Jun 01, 2010 | RTO Case W14 1570 2090 2290 2294 2590 3594...
Tractor belt slips so blade doesn't cut
There is an electrical clutch that drives the belts. This clutch may be worn. Some will have adjustments that will allow it to tighten them up and not slip. Now when your tractor is running and you turn on your blades there is power sent to this clutch, it is mounted on the engine shaft and has flexible metal plate that is pulled into a pulley buy an electro magnet this plate is worn or could be full of grass/dirt. You need a good strong light, with the tractor OFF, get under and look at this clutch, look for grass/dirt or if the metal has changed colors meaning it has gotten very hot. If it has gotten very hot it is time for a new clutch... Sorry if this is the case. Good hunting.
May 22, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cannot get 5300 series John Deere to go into any gear.
I wanted to know can I pay you for a copy of your cd technical and operators manual IU really need for my tractor, If your in florida i have a really good reasonable on site repair tech i can refer, di you figure out the engage probelm. ? Miss Delynda
Oct 02, 2009 | John Deere 3010,3020 Tractor Basic...
The Times Case Corporation Tractors International Harvestor Logo
397 people viewed this question
Top The Times Toys Experts
Andrew Taylor
Andrew Taylor
Are you a The Times Toy Expert? Answer questions, earn points and help others
