My nvidia geforce 7300 le has an error code 43 what is this and can it be fixed? thank you
SOURCE: Hello, my video card is
You should be able to adjust the color balance for the card. There will be software on your machine that allows you to set the color balance and other things. Usually there is at least some red However if the red is totally gone then it could be a problem with the cabling/connector between the desktop and the monitor, like a loose pin or wire. It is possible that it may be the monitor that has the red out. So first check your connections and your color balance. If that seems ok then try another monitor before you go further. If a different monitor has the same problem (with different cabling too) then you will know.
