Question about Meade 1209 Zero Image-Shift Microfocuser 07079 for all Schmidt-Cassegrain Telescopes models, w/FRE...
42' LG plasma
HEllo, I have a 42 plasma. the image is off about 1' to the left and 1.5' down. Could someone help please. thank you very much.
0 characters
1 Points
Hello, I m using the 60700 Telescope but the image i see in lens is very blurred, i assembled my telescope as per Manuel instruction but still i see upside down image with blurred effects. I tried several...
All astronomical telescopes show upside down and or inverted images-- it's normal nothing is wrong. You are applying too much magnification. Do not use the 2x barlow-- and start practicing how to focus using only the eyepiece with the largest number written on it which is your LOWEST power.
You can practice focusing during the daytime on a distant object like a telephone pole or a building.
Jul 29, 2011 | C-Star Optics 60700 (60x700) Telescope
I was given the power seeker 76 already assembled,,all images are up side down. i have taken the terlescope apart 20 times and cant get image thru scope right side up
Powerseeker 76 is reflector telescope that is why he gives up side down images. If you want right side up please you buy imege eractor eyepiese. Thanks. - Dhananjay Raval - INDIA.
Jul 09, 2011 | Celestron PowerSeeker 76 Astronomical...
Hello... I'm kinda new to all this, so please bare with me! I recently purchased a used Orion Skyview 6 Deluxe EQ. The scope is in great shape and things look great through it. However, it did not...
First WHY would you use a erecting DIAGONAL in a reflector style telescope. Upside down images are completely normal for an astronomical telescope. You only need this diagonal for terrestrial viewing NOT for star gazing. ALL astronomical telescopes show upside down and or inverted images- it's completely normal.
If you cannot come to focus with the erecting diagonal, it's probably because the diagonal moves the eyepiece too far OUT away from the point where the scope comes to focus. Again-- you do not use those for night time sky viewing. Just stick the eyepiece directly into the focuser.
May 29, 2011 | Orion SkyView Deluxe 6 EQ Newtonian...
Hello there. just a question about my telescope. it looks like the baska . all it has is a model number 70060. view finder is upside down ( apparently that is normal). but when i look through the main...
You are using an erecting diagonal mirror between eyepiece and the scope. This flips the image (normally inverted as you realise) upright, but does not correct the reversal from side to side. These are often supplied with astronomical scopes more for ease of looking through the scope without craning one's neck upwards, rather than for the purpose of erecting the image.
There are other types of erectors that will fully erect the image if it bothers you, but astronomical telescopes normally are used without concern for such conventions, as the erecting lenses or prisms absorb light and introduce aberrations or reflections. If you wish to use the telescope for terrestrial work, you would probably be better off with a "spotting scope" which will be fully corrected for image orientation.
Jan 22, 2011 | Barska Optics Barska AE10094 - 70060, 525x...
On a tasco851tr why is the image upside down? also where can i get instruction booklet and are there various lenses? this one has a 20 power only thanks fred
All astronomical telescopes show upside down images. It's normal, no up or down in space.
You will not find an instruction manual. What you need to do is to learn a little Astronomy by buying these two books.
Turn Left at Orion
Both available on
Read my TIPS on my profile page and these two articles:
Download this free star chart:
Jan 13, 2010 | Tasco Telescopes
Received used scope and know squat!
Meade's website has manuals on most of their product - since they make hundreds of styles, an exact manual may not be available - just choose one that is closest. Things are inverted and reversed, as it is an astronomical telescope, and it does not matter what the orientation is when viewing the sky. To get the images part way corrected, use the diagonal mirror before the eyepiece and look in the downward position. images will be correct in the Up/Down direction, but not left/right. That is why binoculars have 2 prisms to correct the image.
Sep 19, 2009 | Meade TeleStar AZ-S Telescope
Image upside down
Hi, this is a common "problem" for astronomical telescopes. Same with my Meade 3" refractor and spotter. It is actually a design 'feature' not broken.
The issue is that most astronomical telescopes naturally show images upside down, or some combination of upside down and left-right.
(Astronomers usually don't care, because space has no up or down.)
It is just the way optics work when lenses or mirrors bounce and bend light. (And since the professional astronomer wants the most light and most direct image, they usually don't want extra devices just to make it right-side up.)
Reason that binoculars don't do that , is they employ special internal prisms to get the image back right-side up.
Easiest solution for astronomical telescope is to buy what is called a "star-diagonal" or "image-erector prism". These will usually make the image look normal for us earth-based folks.
I do not know what exact type your Meade 227 telescope is, but the spotter scope is most likely a simple refractor. So it MAY be possible to install a star diagonal onto it. Or might not. Depends on the exact spotter scope design.
Another option may be able to buy a replacement spotter scope that is designed for correcting image orientation.
Aug 10, 2009 | Meade DS-2114 ATS (325 x 114mm) Telescope
The image is upside down in my tasco galaxseer. Please help.
This sounds like a name for an astronomical telescope. I do not own/may have not seen one, but anyway here goes.
Terrestial images do/will appear upside down. This is normal. Just to add to the confusion some telescopes LEFT and RIGHT can be reversed.
First a few Q's & A's
Can you use different eyepieces?
If 'yes' then what is the diameter* where it enters the scope drawtube/foucuser? (the most popular size is 1.25inch the other is .965inch).
You can purchase what is called an "image erecting prism". This should solve your problem. These are available as an accessory from on-line astronomical dealers. Sorry, but I do not how much you will pay.
As there are many telescope manufacturers 'out there', prices do vary. I cannot remember whether Tasco have one made under thier name. If it helps Tasco are owned by Celestron.
Good luck and clear skies.
Mar 24, 2009 | Tasco Galaxsee 46114375 (375 x 114mm)...
Inverted image
All images in astronomical telescopes are upside down and reversed-- this is normal. There is no up or down in space. Reversing the image just adds more GLASS to the light path.
Nov 13, 2008 | Bushnell NorthStar 78-8846 (675 x 114mm)...
Assembly Drawing for Bausch and Lomb Harbormaster
Dear Hlkwan,
Please clean all lence with tisue paper.Telescope gives always up side down .If you want real image you must image erractor on the eyepaiese.
Dhananjay Raval
Aug 22, 2008 | Bausch and Lomb Harbormaster 68-3576 (35 x...
Telescopes Logo
Top Meade Telescopes Experts
Joe Lalumia aka...
Joe Lalumia aka...
Geoffrey White
Geoffrey White
Are you a Meade Telescope Expert? Answer questions, earn points and help others
