Question about Pioneer DV-79AVi DVD Player
Remote Control does not work
Hello, I have A pioneer DV-79AVI and the remote control does not do anything when I use it. The remote seems to work (LED comes on when I press jog button but nothing happens. If this is an internal IR issue what are my options? Thanks
Found this on a website. I have have the same problem, and going to tackle it today. Remove the volume control and input select knobs, which should pull off with a little bit of force. There are 12 black case screws holding the exterior metal housing on, and these are easy enough to remove. The circuit board is attached by 13 more brass screws to the front bezel, which are a bit more difficult. It's much easier to remove these screws if you can first remove the entire front bezel from the rest of the housing, or at least detach it enough to move it around to get a better angle for these 13 screws. I also had to use a flathead screwdriver, as the phillips head was only stripping out the screw heads. I had the correct size screwdriver, but the metal was just too soft. The front bezel, aside from the aforementioned 12 case screws, is attached by two clips on either side, to the metal housing. You just have to pull out on the clips some to get them over the stub that holds them in place. With the 12 case screws, and the 2 clips removed, the front bezel is still connected by 3 other wires. The circuit board is still connected with an additional 2 wires. 1 of these is a 3-pin wire coming from the headphones jack. To unplug this wire, for me, I had to take the screw out of the headphones jack, which is attached to the reciever housing, because the connector was wrapped under another wire that was released when I unscrewed the headphone jack from the housing. The next 2 wires are flat parallel cables, similiar to IDE cables in computers, which attach from inside the reciever housing to the FRONT side circuit board we're trying to remove. I haven't been able to remove these cables as of yet, and I don't think it's necessary. These cables, for me, were taped in a couple of places to other parts of the reciever housing. If you're able to remove all of those, there's 2 other cables, I'm aware of, that are holding the circuit board to the front bezel. One of which is another 3-pin connector that is connected to the volume control knob, and the other is another flat parellel-like cable that is, again, on the front side of the circuit board. Anyway, like I was saying, I don't think it's necessary to remove everything. With all of the circuit boards screws out and a couple of other wires disconnected (at your discretion) you can pry up the circuit board enough to find the sensor. It's directly to the right of the front display. The 3 pins for my sensor protrude through to the other side of the circuit board, and other people haven't been commenting on their particular situation. The pins on my sensor come out about 1/8" on the backside, and come through the solder. For my particular situation, upon closer inspection, you could see a circular crack on all 3 solder points. Imagine a popsicle. Inside of the popsicle is the popsicle stick, and the stick protrudes out the bottom. Well, if you were to break just the popsicle in half, and slide the bottom half of the popsicle away from the top half, you'd have a section in the middle that was just the popsicle stick. Similiarly, that's what's happening here, but just on a much smaller scale. The two sections of solder are no longer making contact. So, after applying a little solder to the 3 joints (and I don't recommend trying to use a large soldering iron. You need a smaller "finesse" soldering iron for intricate eletronic work), and my remote began working like nothing was ever wrong. Also, when re-assembling the parts, if the plastic block that contains the buttons was moved/jostled/whatever, make sure that the top 4 buttons work. These buttons use an additional clear plastic piece, which needs to be positioned correctly for those 4 buttons to make contact to the circuitry. I would say this takes about 2 hours from disassembly to having it put back together again, but it does indeed work.
Posted on Jul 31, 2007
  • 45 Answers
Have you tried the remote infront of a camera phone or normal video camera? you should be able to see the front IR led blinking whilst pressing any button!! Patrick
Posted on Jul 25, 2007
Tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 | Televison & Video
My pioneer remote XXD3086 shows the display ,but doesn't function
clean the remote with an alcoholic solvent then try to look for any loose joint mostly near the LED transmeter then use your mobile phone camera to check whether light is visible when you press the remote buttons while directing it to the camera
Aug 03, 2014 | Pioneer New Original XXD3086 Remote...
Remote control problem pioneer dv-f727
A few thoughts.
1. The remote was water/liquid damaged and the buttons no loger make contact with the silicon board to send a signal.
2. Low battery??
3. If you are using a universal remote, you may have found a code that only partially functions. Keep going through the codes until you find one that fully functions.
Hope this helps!
Jun 26, 2012 | Pioneer DV-F727 DVD Player
I have the pioneer vsx-d814 with the xxd3069 remote but the remote wont work anything and it has power.Need help
Hello
Get into this link and see the faults that can occur with a remote control. Just check all that suggested. Even after all che checks are found OK ,and your device does not repeond to the remote control, the remote sensor inside the unit must be checked.
http://www.fixya.com/support/r8733688-common_faults_in_infrared_type_remote
Dec 15, 2011 | Pioneer XXD3033 Remote Control
Just bought a Pioneer DV220V-K and need to make it region free/unlock. I've been looking, but can't find any remote control code that works. All the ones that I found are for other models - and I do not...
Hi you need a special remote control.I bought this dvd player and the seller had a remote control different than the one you get with the dvd.And he pressed 4 buttons on it and it opened the region
Apr 03, 2010 | Pioneer DV-300-K Player
Front panel only lights up wen turnd on or adjusting ...after it turn s off
Need to press the fl dimmer button on the front panel it controls the display.
Jan 29, 2010 | Pioneer VSX-D409
Unlock Pioneer DV 410 k?
hi! try this two steps i hope it will work on your unit.
Turn on with no disc in. On the remote control, press "SETUP". Select
"GENERAL" (certify that the "SETUP" is on "BASIC". Press "DISPLAY". Press
"CONDITION". Choose region code and quit "SETUP".
or
Remove any disc in the tray, Press the SETUP on the remote control. Move over
to GENERAL using the arrow keys; Select BASIC, Press DISPLAY - this will display
your region and firmware version. Press CONDITION/MEMORY (nothing is
displayed or changed on the screen). Press the REGION # required (i.e. 2 for
Region 2 etc). Press MENU to store.
Aug 12, 2009 | Pioneer DV-300-K Player
Is Sony DAV-S500 optical input compatible with optical output from Pioneer DVD player DV-566K?
I don't think this has an Optical but a Coaxial connection. You might try a coaxial audio cable not optical.
Dec 30, 2007 | Sony DAV-S500 System
Pioneer DV-79AVi DVD Player Logo
79 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
