Question about Circulon 48785 Non Stick Electric Wok
Need new temperature control unit
Unit got hot, melted some plastic. Wok itself appears undamaged and fine. Temp unit has the following numbers on it: E82773, Model PA8300-5SC, Temp. Control PA8300 Please let me know if you know where/how I can order another control unit as I love this wok and would hate to see it head to a landfill. Thanks, Lance
  • 3 more comments
  • Anonymous Dec 03, 2007
    The web site in the response for the wok looks to be the exact same for my electric circulon griddle and I ordered it.
  • Anonymous Mar 19, 2008
    Need a control unit for a Meyer (490 120 VAC 1350 W UL 89GT temp control PA 8300 Stainless Steel without non-stick coating) electric skillet. This is my second search. The first search netted me a circulon control PA8300 which worked for a while then burned out. I will not know if the pan has been damaged until I get another temperature control unit and try it out.
  • gshuster Oct 17, 2008
    Where does one get a new E82773, PA8300-5SC Temp Control?
  • Anonymous Jan 28, 2009
    need new control
  • Anonymous Feb 10, 2009
    Need a Temp. Control (PA8300) for Cooks Essentials slow cooker. Where can I get one of these
I am having the same problem trying to locate/find such replacement part.
if some assistant cold be found.
Thanks,
Lance Mc.
Posted on Dec 06, 2008
Yup, I just got a replacement for $8.99 at potsandpans.com.
Posted on Jul 29, 2007
  • raggiefurbal Jul 19, 2011
    The control at potsandpans.com is not E82773, PA8300-5SC Temp Control. But it still worked for you? I just want to be sure it will.
Ignition is fine, fan kicks in as it should. Unit shuts itself off afer approx 15 mins. Cannot relight till it has cooled down again
Coolant temp sensor has shifted out of range. It is telling the computer that the vehicle is overheating and the computer is shutting off the spark. If the car has a gauge, do not buy the temperature sending unit, this only sends the signal to the gauge. Change the Coolant Temp Sensor.
The other possibility is that your ignition module is bad or the dielectric grease is gone allowing the unit to get hot.
May 27, 2015 | Heating & Cooling
Meile fridge freezer ice on floor of fridge
This fix procedure is simple and should not daunt anyone. First switch off the unit - best by removing any electrical connection, plug, socket, etc. At the rear of some (?) Miele fridge freezer units inside the compartment, is a large plastic panel. Remove this by first removing the food trays and then, use the screws in place on this panel. You wioll probably have to manoevre out the small cabled temperature "sender" control unit. Also see the drain hole at the bottom of the unit's back wall. Above this is a heat exchanger (like a car radiator). You need to pour hot water into the heat exchanger body at the top so the probable ice build-up is melted. This can take several jugs full of hot water and the drained water needs to be recovered at the bottom and lost elsewhere. I think I used a combination of old towels and drain cooking tray. If you don't do this, you will simply have a big water mess. When you feel the water flows easily the ice has probably been melted. The hot water shouldn't damage the heat exchanger at all. Dry all the components you can see around the heat exchanger. Then turn your attention to the drain hole. This discharges through a small plastic outlet into a water overflow tray and this is likely to be blocked with either more ice, or dirt. Poke a plastic rod or wooden stick down this hole and wiggle it about. You are trying to ensure that the drain hole is free to drain any auto-defrost water away by itself. When all is clear and dry, replace the large plastic panel, switch on the unit and hopefully see that the fredige freezer comes back down to the right temperature. You may need to refer to your User Manual to see how the temperature and settings all work. Good luck.
Jun 03, 2014 | Miele KFN8762SDED Bottom Freezer...
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
Need a temperature control unit pa 8300,for a Meyer Work
Try Meyer Customer Relations
http://www.meyer.com/contact_us.html
In 1998 I lost the cord for my wok (don't know the wok model as I do not have the wok now). Meyer sent me a replacement. The TEL number I called was 800 326 3933.
Jul 18, 2011 | Meyer 48986 Electric Wok
After self cleanin our GE jkp90 oven we get an F9 code when we cook above approx 450 degrees. Once it gets to temperature the F9 comes on the display, locked flashes, and the oven shuts off. Sometimes...
sounds like you have a bad interface or control unit ... being a g.e oem authorized service tech for the last 18 years we see this alot... the self cleans should be removed on these things... it literally gets the units to hot and starts melting and destroys the components on these things... the control board will actually come with a new door latch mechanism as well and that normally is the culprit.... the thermostat is connected to the erc ( erc being the control board) and when the unit says it is high temp the erc faults you need a new control board assembly.... god luck
Dec 31, 2010 | GE JKP90 Electric Double Oven
95 Lincoln towncar stuck on high temperature setting
u need a new blend door motor. this is a job 4 the machanic cause the whole dash must be pulled back
Mar 25, 2009 | 1995 Lincoln Town Car
Honeywell fan&limit stat manual reset control
Okay, the red button is a manual reset that is the heat enchanger gets to hot it opens the safety cicruit. The new one does not have the red button so therefore it will automatically reset itself once the temperature of the heat exchanger cools down. Once you install the new one verify the control shuts the unit down. The easiest way for you to do this is to cover the return grilles with a plastic bag with a little tape to hold it to the grille. Then start the heat cycle and observe the furnace operations. There should be a little tab near the 200 degree temp. once it gets to the 12 oclock point the burners should shut down. If it shuts down properly pull plastic bags off returns and satisfy tstat. now turn heat on again and observe what temp the blower comes on
Jan 24, 2009 | Honeywell L4064B2236 Fan/Limit Control...
No heat in vehicle
there is a door that moves to control air temp from the heater core and AC evaporator core, it is the air temp control blend door , the door can stick and cause this or the little electric motor can fail, the electric stepper motor is much more common, I worked as a tech for a large Ford dealer for 20 years so I am sure of this diagnosis.
To cut to the quick of this, u must remove the dash assembly to replace this little motor, a 10-12 hour job for a pro, all day and into the night for a shade tree. Sorry for the bad news, but at least u know what the problem is.
Jan 15, 2009 | 2000 Lincoln LS
My GE Microwave/Oven Combo Unit JKP85B0A3BB has a melting chamber
It is one unit. You can not replace just a microwave.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 01, 2008 | Ovens
Circulon 48785 Non Stick Electric Wok Logo
2,279 people viewed this question
Top Circulon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Irene Tulloch
Are you a Circulon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
