Question about SanDisk Sansa m200 (2 GB) MP3 Player
Mp3 keeps turning off and on and its stuck on pause.
I was syncing songs onto my mp3 then I toke it out and when I turned it on it kept turning off then back on again.Also it is stuck on pause.Please Help.
Return the god damn device
Posted on Mar 26, 2007
Sansa Clip 8GB is stuck in pause mode
You mean it hangs up at pause mode and you can't turn off you device? if so, push up/press power button and hold for 10 to 20 seconds until the device turn off.
Then, turn on. if it' working. You should update new firmware.
Good luck
Jan 17, 2010 | SanDisk Sansa Clip MP3 Player
I have not been able to copy CD's onto the MP3 player. I keep getting a formatting error when trying to convert even though I am using WMA and have tried MP3.
mdcope2 - delete the msuic files that you already ripped from CD off the GoGear. If you Rip a song in WMA, and then re-rip it in Mp3 format, when you go to sync the mp3 file, the GoGear will basically ignore the new file, because it thinks that the file is already on the GoGear since it has almost the same name. Once you have deleted the affected songs, re-Rip the songs in Mp3 format using Windows Media Player. This time, when you go to sync the songs, it will work.
Guest - to load video files onto the GoGear, you have to convert and sync them through the Philips Media Converter - no other method will work.
-Tha Mp3 Doctor
Mar 02, 2009 | Philips GOGEAR SA6045 MP3 Player
MY SANSA WONT PLAY SONGS, IT SHOWS ARTIST BUT STUCK IN PAUSE
Some songs are in the wrong format, or your DB is corrupt. Either way:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to the Sandisk website and click "Firmware Updater" to find out.
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa Clip MP3 Player
Philips GoGear SA3345 (4GB) Media Converter 2.5 to converter ERROR
Disable Auto-Sync in Windows Media Player 11 – go to Microsoft's website for pictorial demonstration
Major Symptom: The Mp3 player is adding songs that I don’t want onto the player
Major Solution:
Open Windows Media Player WITH the mp3 player connected
Move the mouse cursor over to the Sync tab
Click on the tiny black arrow underneath the word “Sync” to bring down a drop-down menu
Select Set Up Sync (this option will not appear if your mp3 player is not connected to the computer)
Uncheck box that says "automatically sync files to device"
Click OK to finish
Voila! You are now set up for manual sync instead of auto-sync.
-Tha Mp3 Doctor
Oct 31, 2008 | Philips GOGEAR SA6045 MP3 Player
Help!!!!!!!!!
Reformat the player
Apr 22, 2008 | Samsung YP-K3 MP3 Player
Hidden Song Files on an ILO
The songs are in the wrong format
Jan 11, 2008 | iLO (2 GB) MP3 Player
When i burnt music onto my MP3 something happened!!!!!!
Nellbell you still having problems with this unit.
You Might try
Copying and deleating all songs on player then load 1 song and try
Reformat the unit and try again
Update firmware from Samsung site.
Try reset button (Under color cover use a pin)
Sep 09, 2006 | Samsung Yepp YP-F1Z MP3 Player
SanDisk Sansa m200 (2 GB) MP3 Player Logo
90 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
