Question about Frigidaire PLEC30S9EC Stainless Steel Electric Cooktop
Frigidaire smooth cooktop PLEC30S9EC
I have a professional installer put in the unit Sept 25 but I have not used it as up to date, reasons described below... Right after it was installed, one burner would not come on. After warranty service #1, none of the burners came on. Warranty service #2 ordered power supply board to replace. Throughout the whole repair history, our smoke alarm would come on after the unit staying on for a while for testing purpose. The time the alarm triggered varied but the pattern was consistent. I was told that this model is 2006's model. I am deeply concerned that this could be a safety related design flaw. Please advise.
  • wendy liang Nov 02, 2006
    Catriver:
    I used to have the Frigidaire model RBF139CE, on its user's manual page#15, under 'Voltage is incorrect' problem solving paragragh, it stated "Be sure appliance is property connected to 240 volt elctric supply". Since I never had any wiring related problem with the old cooktop, I could safely assume that the house wiring had adequately accomodated the cooktop's voltage requirement which should be >= 220V. You may ask then why I wanted to replace the older model. Because I was told that the replacement parts for some broken control knobs were obselete, I had no choice but to move onto a newer model.
    I noticed that the wall and sorrounding cabinets were warm to touch after the bew cooktop being turned on for a few minutes. That could be the trigger of the smoke alarm perhaps?
    I am no electrician, so this question could be very naive. I know Frigidaire is an European brand, wouldn't the manufacturer convert the voltage to fit US requirement if the US uses 110V for most? Also hypothetically if the mismatched voltage was the culprit, how would this situation be handled between the innocent consumer and the manufacturer?
    Frigidaire customer support was not much help other than delaying the issue resolution. I am at the end of the rope so to speak, so any advice and suggestion would be greatly appreciated.
    Smalltree
  • wendy liang Nov 06, 2006
    Catriver:
    IT is getting a bit technical here. Are you suggesting that I need to lift up the cooktop to get to the power terminal? I have no tools to check the voltage and don't know how to check the breaker amps level.
    If the warranty service contractor did the repair, wouldn't you assume that they would have checked all that out especially they are the contracted warranty service.
    Anyways, the warranty service contractor replaced the power supply board and all heat do come on, my main concern is the safety since it consistently triggers the smoke detector alarm.
    Can you come out under the cooktop's warranty and provides 2nd opinion?? THanks, Smalltree
I have planned to buy a Frigidaire cooktop but after learning all the complications about 220V and 120V I decided to buy an American-made cooktop instead.
Posted on Dec 23, 2007
    President:
  • 878 Answers
Smalltree, You may want to make sure that they have 220 wired to the cooktop. I've seen a lot of new construction where they are hooking the cooktops up to 120V and wondering why they're not working. Check this first and post back..Catriver.
Posted on Nov 02, 2006
  • Ron Marek
    Ron Marek Nov 05, 2006
    Smalltree, your unit should be set up for 220V. You can eliminate your ciruitry for any problems by checking the power at the terminal block of the cooktop. Where the power hooks up you have 3 terminals on the terminal block. From the center terminal to each end terminal you should have 120V. Across each end terminal you should have 240V. You should be on a 40 amp breaker as these units can consume 9700 watts. If your power is correct, warranty service #2 may be correct in his diagnosis. Catriver...post back
SOURCE:
Burner won't turn off. stays in simmer mode
Good Afternoon Judy, thanks for your post!
From what you have described the burner on your Frigidaire cooktop will not shut down and continues to run in simmer mode. I would suggest performing a reset on your cooktop and you can do that by disconnecting power from your cooktop for at least ten minutes. If that does not help alleviate your situation you may need to have a burner switch or control panel replaced and that is not a simple DIY job. If any electrical components need to be replaced I would recommend contacting a professional technician for proper repairs to be completed. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -OOS
Apr 04, 2015 | Frigidaire Cooktops
How to unlock the door when not cleaning by itself
Thank you for your post, wilma jones!
I understand that the door on your Frigidaire range is not unlocking. I see that you have attempted several troubleshooting steps and the door is still locked. From what you have described it sounds like a possible faulty door switch or wiring harness. I would recommend having a professional technician out to properly diagnosis your range this will help to avoid any unnecessary part purchases. Best of luck! -Matt
Dec 24, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
I have a Frigidaire Gallery Professional Series Stove and Oven unit. The oven temperature indicator light has been fading for years and is now barely visible. Everything else on the control panel (timer,...
Hello arab125 - I understand that the timer and clock works fine, however from what you have described it sounds like the range could possibly have a wiring failure, faulty sensor, or an issue with the EOC. I would suggest contacting a professional to move forward accurately.
Oct 08, 2012 | Frigidaire FGEF3031KB Gallery 30"...
Burning plastic smell coming from new cooktop fan.
Sorry - this is not an answer but a question. Did you get your problem resolved. We just purchased a induction stove & oven and are having the same problem you described. Could you let me know what happened. Regards Bob
Apr 06, 2009 | Kenmore Elite 44173 30 in. Electric...
Smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
Cleaning of stove top
I assume you are talking about a glass smooth top stove. Use any of the liquid polishing type cleaners made for this use. Regular use leaves a build up that makes it easier to clean without streaking.
Jun 29, 2008 | Cooktops
Frigidaire glass cooktop
first try putting pans on top and see what they do you should not operate these type of eyes with nothing on them as you will burn out the sensors in the eyes if nothing is there to reflect the heat back to them if it does the same thing with pans on them then you will have to replace the elements
Feb 11, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Open Questions:
See all Frigidaire PLEC30S9EC Stainless Steel Electric Questions
Frigidaire PLEC30S9EC Stainless Steel Electric Cooktop Logo
534 people viewed this question
Top Frigidaire Cooktops Experts
Carmen Mikulic
Eric Sutherland
Are you a Frigidaire Cooktop Expert? Answer questions, earn points and help others
