Question about Dell 1710n Laser Printer
Dell 1700 Hi, my Dell 1700 printer is being ridiculous and says it has a paper jam...um no such thing. I've been cleaning it for the last hour every way possible and it still has "Continue" and "Paper Jam" lights blinking slowly. Any ideas?
  • Baer0 Nov 20, 2008
    Mine prints about 2/3 of the page then stops with a "paper jam". I clear the paper out the back and have to turn it off and back on to clear it.
  • alancorr Nov 29, 2008
    MY PRINTER SAYS LOAD / REMOVE PAPER , THERE IS NO PAPER JAM AND PLENTY OF PAPER AND IT STILL DOESNT PRINT
I've experienced this in the past and found a paper jam in the back feed roller and had to take the unit apart to retreave document. Try doing this (only if no longer under warranty) there are a few screws in the front and it should be able to come off easily.
Posted on Apr 02, 2009
Paper jam light stays on and unable to find any paper jam
pls clear paper feeding sensor clean and blow the air into the printer using electric blower i hope problem is cleared
Oct 01, 2010 | Dell 1700 Laser Printer
My dell 1700 says that there is a paper jam but there is no paper jam visible
You must remove all drums & toner and open all doors and look with a flash light. steven 818-888-0006
Apr 26, 2010 | Dell 1700n Laser Printer
Our printer is having paper jams in the back we have cleaned the printer and took it apart to see what was wrong and it still keeps happening is there anywhere we can take it to
You may have some luck trying some of the tricks found here. I have a 1700 myself, but don't use it much...works great when I do thou!
Aug 13, 2009 | Dell 1700 Laser Printer
Won't pick up paper, yellow light on paper jam
ok if you checked the rubber wheels ..that is ok but have check the clik inside the printer if not than chk it out .....might it will work cause if ur priners rubber is clean than there must be some problem in wiring or clicker
Jun 11, 2009 | Dell 1700 Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Dell 1700 will not feed paper
If your Dell 1700 laser printer is not pulling paper all the way, try cleaning the pick up rollers.
To access the pick up rollers. Turn off the printer. Unplug everything from the back of the printer. Take out the toner/drum and set this aside out of the light (the drum is effected by light). Remove the paper tray. Set the printer on its backside. The rollers are located on the underside of the printer where you just removed the paper tray. You may have to move a blue flap to get at the rollers. Take a damp paper towel and clean these off. Another possible solution is to take the grey rollers off and turn them inside out and then place them back on the printer.
The pick up rollers should not be shiney, or cracked and dryed out. If they are, they will not pick up the paper to feed it into the printer. The tires should have "traction" to them so that they can grip the paper and feed it into the printer.
Once you have the tires cleaned off or turned inside out and placed back on reassemble the printer and try printing.
Mar 28, 2009 | Dell 1700n Laser Printer
Dell Laser printer 1700
pickup rollers bad, you can try to clean them with rubber cleaner but it's best to have the rollers replaced.
Jan 22, 2008 | Laser 22 ppm Mono Printer
Dell 1700 often jams in one spot
Just in case you don't know where the rollers are in the paper cassette...remove the paper cassette drawer and he rollers are at the top of the entrance to the drawer. There are two rollers, grasp one between your fingers and gentle pull the roller down to see the mechanism better. Rotate both rollers and you may find a build up of dirt/grime on either or both. Simple clean them with an appropriate wet cleaner & lint free cloth.
Mar 04, 2007 | Dell 1700n Laser Printer
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Dell 1710n Laser Printer Logo
343 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
