Question about Orion STV2763 27" TV
Orion 27" tv
I have about 20 white horizontal lines across my tv set. what could be the problem? checked all connections and everything is fine. can you help diagnose the problem and see if its worth fixing. thanks!
  • 4 Answers
Hi your problem could be two different things , the first one is that it mught have a cold solder in the vertical or a bad capacitor in the same area.
Posted on Nov 06, 2006
Ten year old emerson 27" flat-screen tv has multiple thin white horizontal lines and has audio
Backlight CCFL lamps fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 30, 2014 | Emerson Televison & Video
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
I have 8-10 horizontal white lines at the top of my screen
CHANGE VERTICALL STAGE ALL FILTERS.1000/MY 35V,47MF/220MF 10MF.
Aug 04, 2010 | Orion STV2763 27" TV
White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
May 31, 2010 | JVC AV-27230 27" TV
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
White horizontal, zig-zagging lines
It sounds to me like you're describing the re-trace of the unit. It is repairable, and more so the sooner you get it to the repair facility.
Nov 21, 2007 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Horizontal white lines
if you cant adjust the A1s then it sounds like the F.B.T. is up the swanny (faulty).
Jun 01, 2007 | Jensen Q2049J 20" TV
Orion STV2763 27" TV Logo
137 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
