Question about Dell Inspiron 3800 Celeron 500MHZ Processor (CPU) - 569KW
Laptop HDD boot problem
About once a week,the W2000 boot process stops and message appears:"W2000 could not start because of disk hardware configuration problem. Disk I/O error 00008001". I turn the computer off, then on again, and it starts normally (so far). Some day, it may decide not to. I cleaned the contacts at the rear of the HDD, but this did not seem to make any difference.
  • 624 Answers
I would be inclined to think this was the beginnings of a hard drive failure. Typically these failures are due to mechanical wear on the disks where data is physically recorded. You can continue to use it, however, be aware that when it finally does fail you will likely corrupt some if not all data stored on the drive. At your first opportunity you should back up all data, pictures music, Internet favorites to CD or USB drive. You should also ensure you have your restore CDs for your operating system and any other programs you?ve since installed as well.
Posted on Dec 30, 2006
SOURCE:
Reset factory settings for toshiba S241-504
Back up all of you data to an external drive before you begin the process
If you make a mistake during the process, your laptop may not be able to turn on or load the
operating system, so copy valuable information to media where you can retrieve it, even if your laptop malfunctions.
Turn on your system and wait for it to finish loading Windows and start-up programs.
You can tell when the operating system has loaded, and start-up programs have been initiated, by the HDD (hard disk drive) light.
It should have came with discs. Put one in and reboot the laptop
Insert the system disk when the hard disk light stops blinking, signaling that the processor has finished accessing the hard disk, and that the system is idle. Shut down your laptop after you insert the disc.
You do not have to wait for the computer to access data from the disc.
Turn on the laptop again. Keep pressing the "C" key continuously as the system boots. This will enable the laptop to boot from the disk. Once the disk is accessed, the laptop will show
the message "Loading Files;" begin the factory reset process by always selecting the default option that pops up.
You can also use the "F12" key to boot from the disk.
Highlight the CD/DVD option and press "Enter" to begin the restore process.
Follow the on-screen instructions until the process finishes
Restoring a Toshiba laptop back to factory settings may take 30 to 45 minutes.
Unless you terminate a process by pressing "Cancel," your laptop will be rolled back to factory defaults, when the operating system installs completely.
hope this helps
Jul 18, 2012 | Toshiba Satellite Computers & Internet
Factory settings for toshiba satellite laptop
Back up all your data to external media before you begin the process.
If you make a mistake during the process, your laptop may not be able to turn on or load the operating system, so copy valuable information to media where you can retrieve it, even if your laptop malfunctions.
Turn on your system and wait for it to finish loading Windows and start-up programs. You can tell when the operating system has loaded, and start-up programs have been initiated, by the HDD (hard disk drive) light.
hope this helps
Jul 17, 2012 | Toshiba Satellite Computers & Internet
I cannot get the screen to come on, it is just black but the laptop is on
try removing the battery from th back.wait for like 5 minutes then restart the computer.
else try pressing F8 at the startup if you can go yo the advance boot options.
go to repair my computer..select the language then select the username and password..then in system reco ery optios try startup repair or system restore.
else go to safe mode with networking...there in command prompt type sfc /scannow if you have vista or 7..else if you have the xp in advance boot menu try last know good configuration.
Try the below steps to start the recovery
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
if the above step is not working try to use the windows repair with the oprating system cd.
insert the cd in to thr cd rom, restart the computer
press F12 at the startup it will give you the boot sequence then select the cd
and if none of the things are working contact Toshiba..there might be a hardware issue
plese rate if you find this helpful..thanks
Sep 01, 2011 | Toshiba Computers & Internet
Yes I have forgot my password on my toshiba Satellite L3550 and I cant do any thing on my laptop. I dont have a boot disk either, is there anything I can do to beable to use my computer again
CAUTION:
Restore Partition C: of HDD without changing current partition size
CAUTION:
Restoring the C: drive to its factory default state formats your drive. Your information on the drive will be overwritten, and lost. Be sure to back up all important files first. If you have created other partitions (for example, a D: drive) those partitions and any information on them will not be affected and will remain intact.
To restore only the C: drive:
  1. Press 2 to restore only the "C:" drive (the letter C is traditionally used to designate the first volume on the hard disk drive) on your computer. A confirmation message will appear, indicating that all information on the drive will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
Restore Image to C: Partition with user specified size
CAUTION:
Resizing and restoring your C: drive to its factory default state formats all partitions on the HDD (for example, if you created a D: drive, it will be deleted during the recovery process) your information will be overwritten, and lost. Be sure to back up all important files first.
To resize and restore your C: drive:
  1. Press 3 at the Toshiba HDD Recovery Utility screen. A confirmation message will appear, indicating that all partitions will be reformatted and all information will be lost during the recovery process. Be sure to back up all important files before proceeding.
  2. Click "Yes" to begin the recovery and to specify the size of the C: drive.
    • Press the Left/Right Arrow keys to increase/decrease the C: drive size by 1 GB increments.
    • Press the Up/Down Arrow keys to increase/decrease the C: drive size by 5 GB increments.
      NOTE:
      The size of the C: drive will be displayed on the progress bar as you make your selections.
  3. Click "Enter" to begin the recovery. A message will appear once the operation is finished, indicating that the HDD has been restored.
  4. Press any key to restart the computer.
Aug 12, 2011 | Toshiba Satellite L355D-S7815 Notebook
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
CAUTION:
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
I have a Lenovo g530 laptop with Windows Vista installed. I'm having a tough time getting it speed up, so i'm wanting to restore to factory settings. I have the factory disk it came with. Can you take me...
hi,
This is what you are going to do, insert the disc inside the drive then restart the laptop, keep on tapping F12, then you will see there a list of option that says Boot from HDD, ODD, LAN you need to choose ODD then press enter, remember, there will be a message that will appear asking you to press any key immediately to boot from ODD, you need to press any key immediately once that message appear, then it will come up as windows is loading files, choose restore from factory default or initial backup then you will see there different partitions, choose disc 0 partition 1 then click start or OK, that will reinstall your OS to the factory default.
Hope this will help...
Dec 29, 2010 | Lenovo 3000 G530 Notebook
Locked Laptop
This is from a factory repair and maintenance manual for Acer Aspire Laptops. It may work for you.
Forgotten Hard Disk Password
When the user keys in the wrong password three times, an error message appears. The user must now reset
the password.
1. Make a note of the error code that is displayed with the error message.
2. Run unlock6.exe from the DOS prompt in the following format:
unlock6 XXXXX 00
(XXXXX = HDD password error code, 00 = CRC base - default is 00)
3. Select Upper case ACSII Code from the screen that appears. The HDD master password is displayed.
Make a note of this password.
4. Reset your system. When the Enter Primary Master HDD User Password prompt appears, enter the
password you made a note of in step 3.
Resetting a BIOS Password
The user can reset a BIOS password using the clnpwd.exe utiility.
1. Copy clnpwd.exe to a DOS boot up disk (or flash drive).
2. Boot your system in DOS mode.
3. Execute clnpwd.exe from the boot up disk (or flash drive).
4. Press 1 or 2 to reset the required password as shown on screen.
5. A confirmation message appears when the process is successful.
May 24, 2010 | Acer Aspire 5315-2713 Notebook
NO HDD RECOVERY AREA !
first boot pc, then right before windows would start, press either F2 or F8,, I think it's F2, this will bring you to bios settings, look for bootup device options, Set cd-rom as first bootup device, then Hard drive as second device, Then save settings, insert recover cd, then restart pc, it will immediately boot up your recover cd or windows disc
Oct 06, 2009 | Computers & Internet
PXE-E61: media test failure check cable
The PXE-X61 error means that the laptop cannot detect the hard drive. This can be caused by a faulty disk controller, or a faulty disk drive.
1st. Reseat the hard drive and see if the laptop boots up.
2nd. Go into the BIOS configuration and see if the BIOS detects the hard drive.
3rd. If the BIOS can't detect the hard disk, the remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer detects this drive as an external disk drive and you can see the contents of the hard drive, then the hard drive is OK and the fault is in the laptop.
4th. If the hard drive cannot be detected then the hard drive is faulty, you need to replace the faulty hard drive in your laptop and install Windows to get an operating laptop again.
May 18, 2009 | HP Pavilion dv1000 Notebook
Computers & Internet Logo
43 people viewed this question
Clive
Clive
Alun Cox
