Question about Motorola Mobility V220
Authorization Error After d/l neopets.jar when I go to install it I keep getting the message Authorization Error. What does this mean and how do I fix it?
0 characters
1 Points
I hav install line app in my nokia c5 bt i have a problem to install its show a "authorisation fail" bt hw can i install completely?
The authorisation Failed message might be due to several reasons.
1) May be due to that the MIDlet is using APi's that are not supported by the phone.
2) Also might be due to some problem while Signing. It is not necessary that the app needs to be signed. But Signing will makes the app trusted and remove the permission messages.Hope these links help you
Nov 30, 2013 | Nokia C5 Cell Phone
Install games java jar mobile
First .jar is a file extension so you won't need to do anything special for downloading but the file sits so when download JAVA based games the file is there to basically run those games for you. So there isn't anything needed to "fix" the problem for your Dell Aero.
Nov 25, 2013 | Dell Aero Smartphone Cell Phone
I am getting error while i am try to install .jar file in my LG GD 510 while downloading jar file it opens downloader while gets error that network lost
Hi,the jar file might be corrupted or your mobile will be protecting from something (virus etc) that jar file carries to protect your mobile, so the net breaks. Try installing any other jar file and see if the problem still persists.
hope this helps, thanks!
Sep 27, 2011 | LG GD510 Cell Phone
Hi, i have a samsung champ mobile . i have problem with jar file when ever i try to install this type file ti's show message " download file are invalid" it's started from last couple of...
I hope you are downloading files meant for your phone model. Not all jar file will run on all phones. They are written for specific models keeping their architecture in mind.
Jul 05, 2011 | Samsung C100 Mobile Phone Complete
Dear Friends,
I've tried the code*#52828378# and changed the OTA test and finally succeeded to install my software, but the problem is that after launching i see this message: Java Error: No memory available....!!!!
Could you help me?
Jun 28, 2011 | Samsung B2100 Cell Phone
I have samsung champ gt-c3303 .It cannot run any java supported file what can i do for it ?
Just place a jar files(games or apps) on a memory card. Then just click on the apps or games it will install. Samsung champ will only install below 500 kb/apps or game, if you want to install higher than that just used this code by dialing *#52828378# you will go to Java Test Menu, then go to OTA test, change 500 to 4000 then save. You can now install as much higher than 500 kb but less than 4 mb.
Oct 05, 2010 | Cell Phones
"Jar file is over max size"
Every phone has a different maximum jar size limit and when you accour this rate you will get this error message. There is no solution to solve this problem. You can't install this jar to your phone.
Jun 28, 2009 | Samsung J700 Cellular Phone
How to install jar/ jad files samsung sgh e 250-
Samsung mobile phones
1. You will surely need Samsung uploader. Download the PC Studio for your model from
2. Next, you have to transfer the desired files (both .jad and .jar) in the folder "other files" of the mobile phone.
3. Enter the code *#9998*4678255# (that means: *#9998*INSTALL#), or *#9998*52824678255# (that means *#9998*JAVAINSTALL#) and the message of activation will come.
4. Then, you have to go to the above mentioned .jad file and click "Options".
5. You will be asked if you want to install the application. You shall say: Yes.
6. If you will be asked: "Va zice Non Secure Are you sure to install?". You shall say: Yes.
7. If you want to unset the Java install locking, you will have to enter again the above mentioned codes.
In the past I recommended the following link:
Feb 07, 2008 | Cell Phones
Motorola Mobility V220 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
