Question about LaCie Electron 19" CRT Monitor
No Green Recently after a power outage and re-starting up my cpu and monitor there was no "green" only blue and red with the occasional flash of a greenish horizontal line appearing in various places on the monitor. The monitor worked fine up until the outage.
    Champion:
  • 217 Answers
Check the crt board and follow the green signal path, could have a shorted transistor or a resistor out of tolerance on that line, check all the components on that line
Posted on Feb 17, 2007
There no diplay eccept lots of blue, red, green lines on the monitor, please help
Try another monitor if it works the way it should then it's the other monitor. If the result is the same reboot the computer in safe mode by tapping the f-8 key when you see fhe first splash screen choose safe mode. If it still messed up then you have a graphics problem. Take the computer in and have it tested.
Terry
Apr 02, 2014 | Samsung SyncMaster 540N 15" LCD Monitor
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Red, Blue, Green white flashing screen
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 04, 2017 | Acer AL2016W 20" LCD Monitor
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
Monitor will not stay on
Generally Monitors have a single light in fron pannel, with dual mode colors as Green and Orange.
Green: Everything is OK .
Orange: Everything is OK, except it is not getting
any signals from computer or other source.
Try with any other monitor with your CPU, it may happen that CPU actually not providing any signal to Monitor. Try checking the "NUM LOCK" button on and off, whether it makes the light on keyboard to flash on or off.
If NUM LOCK is woking OK, there is surely some problme with your monitor and you need to get is checked physically with an engineer.
Jan 21, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
My monitor will not come on, the on/off light flashes occasionally and the monitor gives over a very brief light
make sure that your cpu is working. if the cpu is dead, there will be no display in the monitor. If the monitor light is flashing as you said, it could be the CPU not sending video signal to the monitor. also check if the cpu beeps when you start your computer. if not, check your cpu. try to re-seat your RAM modules. this will solve most of these types of problems
Sep 03, 2009 | Computers & Internet
Green light flashing on the back of the cpu
Your power supply just died. If you don't have a surge protector, the power outage probably sent too much voltage to your computer. A power supply is relatively easy to install, but you do have to have some knowledge to do so.
Try looking at this: http://www.fonerbooks.com/r_power.htm
If you don't understand it, you should be able to get someone to replace it for you for relatively cheap. Also, you can get a new power supply for about $20 on E-bay.
Also, make sure your computer-- and all major appliances-- have a surge protector on them, because this kind of stuff happens ALL THE TIME.
Apr 04, 2009 | HP Remanufactured Compaq Presario SR1130NX...
LaCie Electron 19" CRT Monitor Logo
126 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
