Question about Sanyo HT32744 32" TV
Audio has a lot of static
I am a cable user and recently this tv has lots of static noise. All other tv's work fine. Static level not affected by volume control. I unhook cable and still have the same static level with sound on mute. The only way to stop static noise other than turning tv off is to let tv autoprogram channels but once that process is over it starts up.
  • BarbVee Dec 26, 2008
    I have the same thing w/Sanyo 19 inch flat screen HDTV. Annoying static, even when muted, makes it almost impossible to hear the dialogue unless the volume is turned almost on full power, to drown out the static, which makes the sound way too loud. Tried disconnect and reconnecting cable, doesn't solve. This TV is barely 2 years old.
  • Anonymous Mar 15, 2014
    My ex muted the tv to hook to surround sound,remote cant access the audio for volume i dont understand what is wrong it worked before without the spe
    Sergeant:
  • 337 Answers
You can possibly diagnose the problem by trying a different speaker,it does not have to be the same shape as the original but it has to have the same amount of resistance (ohms),radio shack might have one that you can try or one from a broken radio ,if you use one with different value it might not sound as loud but we are trying to see if you hear the static or is gone.You need to unplug the unit from the wall,remove the back cover and locate the speaker,disconect the wires and reconect the one to try then plug the set and turn it on,the antenna will need to be reconected too.Is the most simple test you can do without getting in too deep.Let Us know how it goes by a way of a new question or if you need more information.
Posted on Nov 01, 2006
  • 1 more comment
  • Omar Urrutia
    Omar Urrutia Nov 01, 2006
    Your rating response is also important.
  • Omar Urrutia
    If the set has two speakers disconect one at the time and see if the static goes away.
  • Omar Urrutia
    If the speaker test does not take care of it or you feel is not safe you should call for help from a servicer.
After some homework, I am thinking perhaps the problem is the T-CON board? Do you think that is likely the problem?
Hello... No, it a Main board. If the T CON was the cause, all video would be affected, including the menus. This is not a guess... I work on TVs for a living, and have seen this symptom several times. It's always the Main board. I hope this helps!
Nov 26, 2017 | LG Televison & Video
My tv only displays snowy screen with load static noise. When I unplug it and plug it in the tv turns on by itself and the snowy screen and load static are there.
check that the antenna wire is properly connected as the screen indicates that it is not working or connected properly
Jan 03, 2016 | Televison & Video
Receiver static
It could be just a lead, check your lead heads and inserts are clean.
Check along your leads and wires for any obvious kinks / tight bends / cuts / nicks / something sitting down on it or any damage to the wires.
It could be there is another electrical device nearby interfering at a electromagnetic level.
It could be just the dials / knobs need taking off and cleaning in behind. the pickups, you may not need to remove them just spray with electronic cleaner b3203b06-4ced-4fda-befd-44f385f97b7e.jpg this stuff is great for lots of different electrical cleaning problems.
Good luck
Feb 10, 2014 | KLH Audio Players & Recorders
I have static in the right ear of my headphones. They started doing this when only two weeks old. I have changed batteries, tried adjusting the sliding fit mechanism and everything else I could think of....
the static that you have on the headphones is probably because a loss connection or no floating ground- it means that should be a cable inside that isolate all the noise its probably loss if you can open them you should be able to see the cable its better to take it to a technician
Aug 19, 2010 | Audio Players & Recorders
Static with playback on samson-gtrack with windows xp
i have the same problem with my g-track on a macbook im just going to take the thing back
it works for a feww min when i first start recording the is falls apart
Jan 10, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
N64 has static and audio noise
If its got what looks like a cable jack plug, its an RF Cable. As is, if those get kinked up badly enough, the copper inside of them can become damages, which can affect the way it sends the signal to the tv from the N64. Those cables can be picked up from local game stores. my suggestion though, is if you have the connectors, go with the Red,Yellow,White setup, Red and White are the sound cables, and the Yellow is your video. Better sound from it.
Oct 29, 2008 | Nintendo 64 Console
Tascam CD-RW4U
Try adjusting the input level so the meter stays close to 0 when recording. It sounds like the levels are too hot.
Aug 04, 2008 | Tascam CD-RW4U CD Recorder
Static
The cordless phones have a button to change the channels that are within the radio freq. range. I would change the channels until you get a clear/static free call.
May 20, 2007 | Northwestern Bell 35807 Cordless Phone
Sanyo HT32744 32" TV Logo
560 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
