Question about Compaq EVO 2.0GHz Pentium 4 Notebook with DVD-ROM (N1020V) PC Notebook
System unstable for the last month, my daughters laptop has been behaving very oddly. It runs slow while on charge, shuts down for no reason and gets very hot when in use.
    President:
  • 2,961 Answers
This could be a couple of things, the shutdown will probably be because of the overheating, check for blockage around fan extraction area. The other could be that there is a virus or spyware running, taking over the processors work and causing a shut down or overheat error, check for both. The other could be a driver conflict, try doing a system restore to before the problem started.
Posted on Nov 01, 2006
Acer Aspire 4830T battery behaving vaguely.
Are you using the provided charger, or are you using an after market "Universal" charger?
If you're using a universal charger, it could be charging the battery too hot and the computer just doesn't understand why the battery is putting out more than the system is expecting.
It could also be that the battery is wrong type. The voltage may be the correct, however the Ah may be too high. This being the case, the computer doesn't understand what why the it's getting a higher Ah reading than it's expecting. The system can not reason that that if it detects more amp-hours than the it should have that it has that much more charge time. It just sees "ERROR" and since you're dealing with a system function that is designed to prevent loss of data the default action is to shut down to prevent loss of data.
You may be able to fix by resetting the Power Management Options. Unfortunately, with out doing test on the machine, it is impossible to tell. I could be software or hardware. If nothing else works, try replacing the battery again.
Oct 11, 2014 | Acer Aspire Timeline X 4830T 14 Inch...
Acer Aspire 4830T laptop battery behaving vaguely
Do you still have the old battery. If so charge it, and see if it charges properly. If so then you have a bad battery.
Mar 18, 2017 | Acer Aspire Timeline X 4830T 14 Inch...
My hp compaq g62 suddenly run slow when power cord is removed and it runs slow too on battery after some time
The processor is designed to gear down when you switch to battery mode to conserve power, this way the rechargeable battery last another 30% longer at least.
May 19, 2012 | Compaq Presario M2000 Notebook
Acer 8920 G restarts after 3 min and again shuts down
First make sure your fan is operating on your processor it takes about 3 mins for it to over heat and stop and shut itself down for safety to prevent burning up the processor.if its not this read on.
Also when you boot into safe mode then do a system restore to a date before the problem started. But first in safe mode run your antivirus scan to find something that is missed while being hid behind the operating system while functioning. Remember to rate my solution and leave testimonial this is how i earn my achievements here on FixYa thanks in advance
Apr 28, 2012 | Acer Aspire 8920-6048 Notebook
Slow shutdown HP Pavilion dv7
There are a number of reasons that may causing your HP computer running slow to shut down or start up, but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues. Regards!
Jan 31, 2012 | HP Pavilion dv7-1132nr Notebook PC
My computer shuts off randomly and its annoying
The main reason for a computer random shut down can only usually be one of 2 common problems:
You have too many programmes running at the same time on a computer with few resources eg: small RAM, slow processor etc.. The solution to this is to upgrade your memory and perhaps your processor too.
The other common problem is that you probably have a virus on your system, and the automatic shut down occurs whenever the virus is trying to carry out an illegal operation on your system. To get rid of the virus, download a trial version of Kaspersky total inetrnet protection from this website - http://www.kaspersky.com . It will run in full mode for 30 days, hence you can scan your entire system with it.
Aug 19, 2009 | Timex Expedition 84601 Wristwatch
Problem with a IBM ThinkPad T20 2647 PC Notebook
check ur hd for bad sectors...shutting down for no reason is usually this(bad sectors)
also check system information and check device manager..could be software problem/incompatabilty/no drivers installed/or two devices trying to use same resource and shutting down cos cant.
Jan 07, 2009 | IBM ThinkPad T20 2647 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Acer Aspire 9300-3655: Shuts Downs When Idle
does it just shut down randomly? and then when you turn it back on it shuts down nearly straight away? if so then it sounds like the processor is overheating and as a saftey mechanism it shuts down. which could be a big problem.
or you just need a new battery. because you are supposed to only charge it when it is dead. if you keep it on charge and plug it into the mains randomly,then the battery will eventually lose it capacitence (basically how much charge it can hold) and then it wont last long atall. you want to hope its the battery.
hope this helps.
Aug 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
Compaq EVO 2.0GHz Pentium 4 Notebook with DVD-ROM (N1020V) PC Notebook Logo
44 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
