Hi; I have a Neff slimline Dishwasher that won't fill with water but works ok if I fill with a bucket. I have searched the net and found that it probably has either a stuck float or a faulty inlet valve. The probelm is I can't find these things. Should I pull it out and turn it upside down or what? And if I do need to replace one of these where can I get them from? I have tried a search online but can't find them.
1)Be sure water supply is arriving with enough pressure. 2)If the hose between the crane and dishwasher has an aqua-stop ( or water-stop) which you recognize at the hose being enlarged twice the size close to the crane, possibly water supply can be blocked there. You can change it temporarily with a regular hose ( for garden or car-wash ...). If dishwasher is doing the job buy a new hose with Aqua-stop in a regular electro- household appliances shop. 3) If this solution is not the good one, you might check in fact to the inlet valve, which you find at the other side of the metal plate where the watersupply is flooding inside the diswasher. Generally a white coloured threaded plastic pipe.
Unplug your dishwasher, close water supply (!) and disconnect the water hose. Open the dishwasher ( either top-plate and/or back-panel). Now you see the inlet-valve ; unscrew this one and mark the position of the 2 electrical wires, which you also unplug then. Also unplug the internal water drain, and ask again a regular shop (see 2) if they can check this valve and if necessary get a spare part.
There does not seem to be an obvious way to turn end of cycle beep off on our neff dishwasher...
(More)
There does not seem to be an obvious way to turn end of cycle beep off on our neff dishwasher S5443X/GB/29
