Question about Panasonic Toughbook CF-51 Notebook
Panasonic CF-51 toughbook will not start up
My laptop will not start up.  I was using the laptop when it all of a sudden shut off.  It went from running to black in an instant, no shut down process, nothing.  The battery was fine, and it was plugged in aswell.  I cannot start up the computer now at all.  This is what happens:
I push the button
The lights on the front of the laptop come on
There is a strange whirring noise (not loud, just not its norm)
The screen comes on for a split second
it turns off again.
all of this happens in about 4 seconds time.
The results are the same plugged in, with the battery in or out, with the hard drive in or out.  Same noise, same result.  Is it the fan, or is it the motherboard?  This hasnt happened before and the laptop has never been alowed to over heat, had anything spilled on it, or been dropped.  Sugestions?
I was able to fix this problem by reseating the componets inside (CPU & RAM) and resetting CMOS (pulled the batt for 10 sec.)
I had the same problem. Remove HD and Batt. Pop the cover over the speakers & power button off. Slide the keyboard up and out, fold over out of the way. Pull the connector from the cmos battery for 10 sec then plug back in (2 wire conn next to speaker wire connector. Unscrew the heatsink on the cpu, remove. Wipe the thermal compound off. Flip the latch down and lift the CPU slightly out of socket, put it back in socket and lock retain latch. Apply new thermal compound install heatsink. Put back together, boot up. You will get an error the first time because the bios has been changed. You can hit F2 for setup to change time and date, save changes exit.
Hope that helps.
Posted on Dec 03, 2008
  • 306 Answers
The sound you here would be the fan. Before opening the case check your warranty -the Toughbook is an excellent laptop so Panasonic may help you. If you have never opened a laptop you should get the remove/replace procedures, keep track of every screw as they vary in length and use an esd wriststrap so you don't make things worse. One possibility is that something got sucked into the fan which would change the rpm of the fan which would signal the computer to shut down. It may be worth trying to use a canned air to blast into the fan exhaust in case there is something in there. Good luck with this and repost if you need more help or info. ~Steve Medley
Posted on Nov 10, 2008
  • 24 Answers
A lot of folks don't realize that laptops get dust and dirt build up in the heatsink fins causing overheating and motherboard damage. In this case, I would blow out all the vents w/ an air compressor (no canned air doesn't have enough pressure) and re-seat the RAM as well as the processor. The whirring very well maybe a bad fan for the CPU or the video card and can also be the reason it's not booting. Sometimes laptops have sensors and when a fan isn't running at a proper speed it will halt the system.
Restore factory settings
Panasonic offers backup "Recovery Disks".
for ALL Toughbook Models
This is a service from the company itself.
There is a fee of $35.00
Please go to their website:
Good Luck!
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Jan 23, 2014 | Panasonic Toughbook CF-51 Notebook
Panasonic toughbook cf-51 drivers audio
The audio or "Sound Drivers" for the Panasonic
Toughbook CF51 are located at:
Please remember to choose your operating system
and click on the "Download Now" button located at the
right hand side.
Gracias and de nada.
Good Luck. Buenas suerte
Panasonic Canada Toughbook Dealer since 1989
Aug 29, 2012 | Panasonic Toughbook CF-51 Notebook
I need an owners manual for a Panasonic CF-51
ALL Drivers and Owners Manuals for
ALL Panasonic Toughbook Models are
located at the following website:
Make sure to select "Manual" on the menu on the
left hand side, fourth down from the top.
Good Luck!
May 30, 2012 | Panasonic Toughbook CF-51 Notebook
Cf 51 model number doesn't match any of their numbers
toughbook drivers go with cpu such as Pentium 4. Ebay people sells driver disk.
Apr 17, 2012 | Panasonic Toughbook CF-51 Notebook
Hi. I have a Panasonic Toughbook CF-51 that fell
I hope I am not stating the obvious by suggesting Panasonic's website.
Jul 29, 2009 | Panasonic Toughbook CF-51 Notebook
Need a motherboard for a cf 51. mine is a dl3up1481aaa. That number cannot be found. will anyother work in it's place.
There's one on ebay right now ! check it out fast.
Jul 14, 2009 | Panasonic Toughbook CF-51 Notebook
No drivers cd
Here is the link to download your laptops drivers.Go through the steps.
Panasonic Toughbook C-51
Mar 06, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 shutting down
Sue, it's not the inverter board. People who don't really know much about laptops will often diagnose them incorrectly, especially computer repair shops. The problem you're experiencing is most likely related to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
Feb 20, 2009 | Panasonic Toughbook CF-51 Notebook
Toughbook CF-51 Laptop DVD Drive Problem
It could be a software or driver issue. First try updating the drivers for the drive, and try either using different burning software or uninstalling & reloading your current software. I had a cf72 with a DVD/CD combo drive that the DVD reader went out. This could also be the issue, if so you'll need to replace it in order to burn CD's.
Jun 10, 2008 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 Notebook Logo
1,223 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
