Question about Sony DVP-NS730P DVD Player
Picture in Black & White
I have just run out of my warranty for SONY DVP-NS730P DVD Player. I am getting Black and White video instead of colour now. How can I get the colour video as usual? Thanks
    Scholar:
  • 119 Answers
If you are using composite cables (yellow,red & white), make sure your yellow (video cable) is into the yellow output. if you plugged the wire into the green on the back of the dvd it will give you a black & white picute. But if it is in the yellow then you most likely have a problem with the dvd player that will need to be taken to a service center.
Posted on Nov 03, 2006
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
While watching a DVD my Sony DVP-NS30P failed completely, presumably the power supply. Is this common and is it relativly straight forward to fix? Thanks Neil
Yes! the power supply is the issue, I have found the main filter capacitor in some units opens stopping the power flow, if that is the case the repair is simple to correct.
Jan 01, 2011 | Sony DVP-NS730P DVD Player
Since disconnecting my Sony DVD player it now only plays in black and white. It is relatively old model DVP-NS51P. I have successfully connected an alternative DVD player to the same TV so it cannot be a...
Make sure that the TV system that the DVD is outputting is NTSC, Press SYSTEM button on the remote control (is there's such button) or change the system in the DVD's menu.
Nov 09, 2010 | Sony DVP-NS51P DVD Player
I am only getting black and white pictures when using the sony dvd -DVP-SR200D when hooked-up to tha TV
Change your tv colour System in to Auto mode.It will adjust in menu.Mostly DVD recorded on NTSC 3.58 colour system.After adjust on auto mode Colour will come.
Oct 30, 2010 | Sony DVP-SR200P DVD Player
Why is it that some dvds only play in black n white?Is there any way to fix this?
Your solution may be to connect your cables to the front of your tv, instead of the back as found here:
http://www.velocityreviews.com/forums/t699272-problem-solved-for-dvds-showing-in-black-and-white.html
Sony also supports this solution, as found here:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C89600&fes=true
Sony also advises it may be due to a faulty cable or if the signal is being transmitted via a vcr.
As per this site:
http://www.gaiaonline.com/forum/computers-technology/sony-dvd-player-only-plays-in-black-and-white/t.41173519/
if your s-video cable going to your tv is loose or is faulty, then only 2 of the 4 pins are communicating with the tv, thus resulting in a black and white picture.
Jun 28, 2010 | Sony DVP-NS51P DVD Player
I have a Sony DV-NS730P and it is currently not
Hi
Depends on what you paid for it. The error is an indication that either the laser head is misaligned or defective or the motor or associated head/motor electronics is defective.
Jun 06, 2010 | Sony DVP-NS730P DVD Player
Sony DVP NS67 P displays picture in black and white. Help me fix this problem using the remote. I received this as a gift and opened after a month. So has the original setting changed to default and...
I do not know about this machine but two general things spring to mind.
One is if the output is set to NSTC (US format) a UK PAL based TV will show it in black and white if it is unable to convert. Check the Sony's output settings in its setup menu.
Svideo output will also create this problem because it separates the colour and image parts of its signal, this again is output or input settings of both items, plus type of cable that you use in particular say phono's to Scart.
I would think its a setting or cable issue than a fault.
Hope this helps..............
Dec 02, 2017 | Sony DVP-NS67P DVD Player
DVD player only plays DVD in black and white - what's wrong?
Ok,
I'm not sure what you mean by digibox. Under what conditions are you able to see things in color? Is a digibox a seperate device you can get to work with the same connection as your player? If one device displays color on the same connection and another doesn't then that seems to rule out the television being the problem. Can you clarify a little more?
Jan 11, 2009 | Sony DVP-NS330 DVD Player
Sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Sony DVP-NS730P DVD Player Logo
194 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
