Question about Sony Handycam CCD-TRV37 Camcorder
Sony hi 8
When I shut off camecorder, the battery life is displayed sporadically in viewfinder, which then drains battery completely I have to take battery out of camera after every use any suggestions ty
  • 38 Answers
This is actually a faulty switch located in the front assembly. Sony has a revised switch with better contacts. The switch is continually turning on by itself. Sony reccomends that servicers replace 3 switches at one time; the camera-on, play-on and the record standby switches.
Posted on Aug 19, 2007
SOURCE:
My PSP shuts down sporadically while I'm playing a game
might be the battery , it runs short of life after while.
Mar 08, 2011 | Sony PSP (Piano Black)
Ways to increase laptop battery life
Let the thing drain completely down to nothing.  When the pop up window says you gotta plug the thing in, just ignore it and do your thing.  When the computer shuts off by itself, hold down the power button for 5-10 more secs to fully drain the thing.  Then plug your computer in and let the battery charge for a good 6-8 hours.  Then unplug the charger and let the battery sit and cool down for about 15 minutes.  This is called conditioning the battery and should be done once every other charge.  Also, its a good idea to turn off your wi-fi if your not using it, bring the brightness down on your screen, and close any non-essential applications that are running.  Cheers old chap.
Nov 21, 2009 | Televison & Video
Battery level don't show on display.
hi friend,
follow these steps
  1. Turn off your LCD display screen. I know this is hard—who likes shoving their face against the camera to compose a shot through the little viewfinder? But the LCD screen single-handed-ly drains a lot of power.
  2. Minimize the picture preview to the least amount of time possible—usually one second. This uses less LCD screen time, thus less power.
  3. Dim the brightness on your LCD screen. A dimmer display extends battery life by consuming less power to light the screen. This might make the display harder to see, but usually only in direct sunlight.
  4. Set the power saver to the least amount of time. Power saver lets your digital camera “sleep” when not in use, but doesn’t shut it down entirely. To “wake up” your digital camera, simply click the shutter button.
  5. Use your zoom as little as possible. The motor that moves the lens uses power. This also goes for repeatedly turning your digital camera on and off if it has an extend able lens.
  6. Turn off the continuous focus. Again, constantly using motors and electronics to ready your shot drastically minimizes battery life.
  7. Don’t push the shutter button half-way down until you’re ready to shoot. Pushing the shutter button (constantly resetting and refocusing) will drain battery life.
  8. Use the flash only when necessary. Your digital camera’s “auto flash” option should take care of this, but make sure your flash isn’t going off in broad daylight.
  9. Don’t delete pictures from your digital camera unless necessary. This consumes power. Wait until you download the pictures to your computer before deleting.
  10. This one’s basic, but charge your battery often. Lithium ion batteries, which most digital cameras use, don’t have “battery memory” like older alkaline. In fact, lithium ions work better and last longer if charged completely and regularly.
thank u for using fixya
regards,
sivaranjini
Aug 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
How long to charge cordless battery for Oster Power Pro Ultra
Usually it is recommended that you leave it plugged in to charge a minimum of 12 hours before you even use it. Then, once you unplug it to use it, keep it completely unplugged and use it until it dies completely and shuts itself off. Then, and ONLY then, plug it back in and charge it again for a minimum of 8 to 12 hours and do not use it while it is charging! Once you've passed the 8-12 hours, you can unplug it again and start using it again. After you do that, you should be able to use it for a few days before it dies and you will have given the battery a "memory". After that, you don't really need to have it plugged in more than a few hours to fully charge after being drained. It's always best to let the batteries fully drain and shut off before plugging back in to preserve it's life.
Mar 30, 2009 | Oster Golden A5 2-Speed Universal Motor...
Batteries wear out quickly -- after 6 - 10 photos. I've tried a variety of brands and quality - both rechargeable and non-rechargeable.
Hi there Jeroldine.
Battery drain the one of the top things that make people upset over cameras. It siits number one over lens errors. The only thing I can say is that your LCD screen is the culprit. The LCD screen is a vampire that sucks batteries quicker than zooming the lens. There is nothing that you can do about it. The amps that a camera uses during normal operation is pretty severe.
You can do some things to help lessen the impact on your batteries.
First. Turn off your LCD screen. Use the viewfinder to sight in all your shots. You can save up to 75 percent of your battery life if you turn it off and use the viewfinder. Second is...zoom less. What usually happens is, you start to take a shot, and you want to get closer, so you so you zoom in. Then you might decide that maybe you have zoomed too much. Then you wind up zooming back out. - Instead, try and get closer to your subject if you can.
There is no magic fix for battery drain. Just remember that everytime you perform a function on your camera, you drain the battery. Hope this helps.
Rob
Mar 09, 2009 | Sony Cyber-Shot DSC-S90 Digital Camera
Camcorders that run on 3 AAA bateries, how long do the batteries last????
I assume we're not discussing the Sony DSC-W55 since that doesn't use AAA batteries.
The battery life varies depending both on the camcorder and the type of batteries. In general, lithiums will last longer than alkalines, which will last longer than a single charge on NiMHs. On cameras that give you the option, you'll use less juice shutting off the display and using the viewfinder. Many manuals will give you estimates of battery life, but these are estimates only, the battery life also depends on how YOU use your camcorder.
Dec 11, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
SONY camera - black photo
Not that it helps at all, but I have the same problem with my sony DSC 80 but its because I dropped it in a river. It works just fine, other than the fact that it takes black pictures now.
Sep 08, 2008 | Sony Cyber-shot DSC-W80 Digital Camera
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Battery life?
Using the LCD viewfinder to compose images drains the power capacity of alkaline batteries very quickly. Instead, use the Optical viewfinder to compose your images. Under normal operating conditions using the Optical viewfinder, a set of AA-size alkaline batteries should last for about 35 images. Additional tips for extending battery life: * Use the AC adapter to review images on the LCD. * Use the AC adapter to review images on your TV. * Disable Quick Review mode. * For longer battery life, use one of the following types of batteries: o High capacity alkaline (a new product on the market as of Jan 2000) o Lithium o NiMh (Nickel Metal Hydride) rechargeable. o NiCd (Nickel-Cadium)
Sep 21, 2005 | Polaroid PhotoMax PDC 700 Digital Camera
Sony Handycam CCD-TRV37 Camcorder Logo
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
