2001 Cadillac DeVille Logo
Posted on Apr 09, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my A/C Compressor and High Coolant Fans Engage?
Car was hit in front(light)...condensor and radiator replaced. Went to charge A/C...pulled vacumn(Held) . proceeded to put in oil and freon(1 can..12oz) .....Started Cad. ...compressor would not engage.....Found relay, grounded relay compressor kicked in; however coolant fans did not come on....Found relay for coolant fan #2 high fan, grounded. I grounded both coolant relat and compressor in order to fill system. It is filled...unhooked ground on relays. Turned on A/C at module head inside cad....no compressor or coolant fans come on.......changed head with used head control, still not working. Give me some pointers.....thanks
Scott Campbell
Level 3:
  • Cadillac Master 916 Answers
  • Posted on Apr 09, 2017
Scott Campbell
Cadillac Master
Level 3:
Answers
916
Questions
0
Helped
205592
Points
2366
Check for broken wiring, blown fuses, possible bad relays, and look at the pressure switch. Some systems have a high pressure switch (some have a low pressure also) that prevent the compressor from running. If it is faulty or damaged, it could be preventing the compressor from running. Wire damage could be possible with front end damage.
5 Related Answers
Anonymous
  • 1263 Answers
  • Posted on May 09, 2009
SOURCE: coolant fan relays
if there is power to the plug then the relays are good. chances are that the thermo sensor to the fan is faulty.
Anonymous
  • 6982 Answers
  • Posted on May 14, 2009
SOURCE: overheats on hwy. Radiator fan does not engage after overheating
fan does not generally come on till you reach about 210f. second fay comes on when ac compressor is on. Allowing for gauge inaccuracy this does not sound like a problem. Have you checked for coolant loss inside or outside the engine? If coolant is low, it may not be reaching the sensor unless you make pump run faster. Those engines are known for head and intake gasket problems, which may be the underlying cause of what you described. A partilally obstructed radiator can give some of the symptoms but I don't thind that is it.
fordexpert
  • 5692 Answers
  • Posted on Jun 24, 2009
SOURCE: MY 1999 CAD WITH 52,000 MILES HASC DEVELOPED A
If you have an electric display ATC type control there is a blower switch which controls only the blower whether its on heat or cool. On my Ford system it was under the hood in the duct work on the opposite end of the blower. Your system is probably electronic and if you replace this part it may work, mine did. You might want to go to a salvage yard and reclaim one from a wreck. You will learn where the part is and how hard it is to remove before you work on your car.
Anonymous
  • 7353 Answers
  • Posted on Oct 19, 2009
SOURCE: 1997 cadillac deville coolant fan
with the a/c on, the fan should be on. crank it up, turn a/c on, now take a hammer and gently tap on the coolant fan, if it comes on, or attempt to spin, its bad.
Anonymous
  • 564 Answers
  • Posted on Jun 18, 2010
SOURCE: Flush radiator and cooling system on 1997 Calillac DeVille Concou
your radiator has a pecock on the bottom of it screw it out then you can run water through a hose behind it once it stops draining to get any residue out as far as the engine youll never truly get all of the old coolant out without tearing it down and putting it back together so flushing the radiator is just fine.
2008 kia sorento ac compressor/condensor fan wont engage
check relay and fuses and a/c switch on front panel inside the car
What would cause my ac condensor to not engage on my 2002 Axiom?
The condenser is in front of the radiator, the ac clutch is on the compressor.
If the ac clutch does not engage, you would need to check to see if the system is charged with freon and if voltage is getting to the clutch.
94 olds 88 a/c
no it requires full 12 volts to work the clutch the coolant fans have no connection to the ac system so they will not run until the engine temp requires them to
there is a fan normally in front of the condenser coil that will start as soon as the ac compressor gets power
the ac will not work until there is sufficient charge in the system to activate the low pressure switch
have to ask are you using the right gas as 134A requires all new system( evaporator , condenser , compressor , hoses) as the pressures are very much higher than r12 gas
I have oldsmobile alero 1999, problem is that the engineer idles after running for an hour or when engine is getting hot
SOUND LIKE ENGINE COOLANT FANS NOT RUNNING.CHECK TO SEE IF COOLANT FANS RUNNING WHEN ENGINE START OVERHEATING.IF NO CHECK COOLANT FANS FUSE AND RELAYS.IF ALL IS GOOD.HOTWIRE COOLANT FANS TO MAKE SURE THEY ARE WORKING.IF NO REPLACE FAN MOTOR.IF FAN RUN WHEN YOU HOT WIRE IT.THE COOLANT TEMPERATURE SENSOR FAULTY ARE THE PCM FAULTY YOU CAN USE A SCANNER TO CHECK THEM FOR FAULT CODE.IF EVERYTHING GOOD SO FAR.REPLACE THERMOSTAT AND RADIATOR PRESSURE CAP FLUSH ENGINE BLOCK AND RADIATOR.CHECK RADIATOR AND CONDENSOR AIR CORES MAKE THEY NOT STOPPED UP WITH LEAVES AND OTHER DEBRIS THAT WILL BLOCK OFF AIR FLOW THROUGH THE FRONT GRILLE RADIATOR CORES.ALSO CHECK WATER PUMP WEEP HOLE IF ITS LEAKING WATER PUMP NEEDS REPLACING.
I got a waterpump and a termasated put on and my car still running hot
IF CAR OVERHEATING WHILE SITTING STILL IN LONG TRAFFIC LINE.COOLANT FANS DONT TURN ON CHECK COOLANT FANS FUSES AND RELAYS.IF ALL IS GOOD.COOLANT TEMPERATURE SENSOR FAULTY.HOTWIRE COOLANT FAN TO MAKE ITS WORKING.IF NOT REPLACE FAN MOTOR.IF FAN WORKS WHEN HOTWIRED YOU HAVE SHORT IN WIRE OR CONNECTOR.IF COOLANT FANS RUN WHILE ENGINE OVERHEATING.YOU HAVE RESTRICTED CLOGGED RADIATOR CORES AND ENGINE BLOCK FULL OF LIME AND GUNK.IF YOU FLUSHED OUT RADIATOR AND ENGINE BLOCK.FRONT GRILLE WHERE AC CONDENSOR CORE FINS AND RADIATOR FINS CLEAN FREE FROM DEBRIS AND TRASH AND LEAVES.WHEN ENGINE COOL DOWN. CHECK ENGINE OIL ON OIL LEVEL DIP STICK. IF OIL LOOKS LIKE MILK SHAKE YOU HAVE BLOWN HEAD GASKET.
Replaced r12 still blows hot air only
is your pressure sensor on the condensor working, it controls the engaging and disengaging of the compressor, if your compressor doesnt enguage it could be a bad compressor, and with my old c4 vette which was a 1992 the test for it was to run the ac on max, let the compressor try to cycle on its on, if it doesnt unplug the pressure switch on the condensor, but (WARNING: YOU MUST DO THIS EXACTLY AS STATED) plug it back in with in 5 seconds. as the pressure switch is what tells the compressor to engage, (NOT PLUGGING IT IN WITHIN 5 SECONDS COULD CAUSE YOUR SYSTEM TO BE OVER CHARGED AND EXPLODE.) . if your ac clutch does engage and your starts running the compressor with in that 5 seconds, your compressor is good. but this will also narrow it down to an either A: and over charged system or B: a bad sensor on the condensor. or C: if your compressor runs constantly, and undercharged system. Make sure to check for leaks, use some water around the two a/c system servicing ports, check the high and the low side as over time the O-rings deteriorate, and even though they have the plastic cap on them they can leak. remove the plastic caps, and put some soapy water around them and see if you get in bubbling with the system on. On my 92 the a/c use to leak down ever 30 days, i thought it was the compressor leaking during operation. i soap water tested all the connections and it was the service connections leaking. Went to autozone, replace the caps, reserviced, and went 3 years (Before selling the car) without having to service it again.
My car keeps getting almost to the red in the temp gauge and the thermostat was already replaced I dont know what else to do
Most common problem is debris build up on the radiator front, or debris build up on the AC condensor causing no or little air flow through the radiator and AC condensor. The radiator and AC condensor must have good air flow to keep everything cool, debris on the AC condensor will cause your AC temp to be high even with a proper AC charge. If there is no debris on the radiator or AC condensor and there is no white smoke coming out of the tailpipe and no loss of coolant, I would suspect a stopped up radiator on the inside or a bad water pump, good luck, Gary
2answers
A/C compresser on 2001 chevy blazer works part of the time. When vehicle starts compesser does not work untill it been running about 15-20 minutes and sometimes it just stops cooling. The A/C is fully...
Sounds like you may need a compressor ? Start the vehicle and verify the compressor is not engaged , if it is not take a small hammer and lightly tap on front of the compressor ,it should engage.
Radiator Fans
You may have air trapped in the cooling system, this causes a hot spot and the fans run, This is a common issue on most front wheel cars, jack the front of the car up as high as you can, fill the coolant reservoir full, run the engine until hot,( don't overheat it) then shut down, let the engine cool, this should self bleed the air, refill the coolant bottle and retest for your problem, restore the wiring, the not running fan is for AC. Spray cold water from a hose on the radiator his will help get the air out after the shut down.
1998 CRV Radiator and A/C condensor
There is no special tools needed you must evacuate a/c system if it did not already lose all freon from hit.
here is manual instructions:
  1. Drain the engine coolant.
  2. Remove the upper and lower radiator hoses, and ATF cooler hoses.
  3. Disconnect the fan motor connector.
  4. Remove the radiator upper bracket, then pull up the radiator.
  5. Remove the fan shroud assemblies and other parts from the radiator.
  6. Install the radiator in the reverse order of removal. NOTE:
    • Set the upper and lower cushions securely.
    • Fill the radiator with engine coolant and bleed the air.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
