Question about Canon PowerShot A520 Digital Camera
Stuck on change batteries
Camera says change batteries. i put in new ones five times. after the message,camera turns itself off. when switched to view taken photos it remains on but when switched to take photo mode and display button is pushed, it says to change batteries and shuts off. i did not damage camera. of course it went off warrantee this month.
I had the same problem. Turned out that changing the SD card solved it! Try formating your card and you might get lucky.
Posted on Jan 03, 2008
  • 188 Answers
It seems that the camera section is haveing troube, may be in the lense movement or initilizing system. if the camera does not initilizes while swithcing on it turns itself off by giving low battery warning.
Posted on Nov 02, 2006
I received this camera a few years ago as a gift. I used the batteries that came with the camera but when they died I put in new alkaline batteries and ever since the camera has been stuck with a message...
you might have cooked it..... fresh alkaline batteries carry a voltage of about 1.7v.
try turning it on/off multiple times to see if it will clear the fault.
Sep 15, 2013 | Nikon COOLPIX L18 Digital Camera
Mu 7.1 meg camera
F YOU PRESS AND HOLD THE ok/function BUTTON, AND TURN THE CAMERA ON AND OFF A FEW TIMES WHILST KEEPING THIS BUTTON DEPRESSED, IT SHOULD HOPEFULLY SORT ITSELF OUT?!
Jun 01, 2008 | Olympus Stylus 710 Digital Camera
Sony cybershot t300 lcd screen remains dark when switched on
Your camera must be experiencing these symptoms due to a faulty CCD, and not due to other problems. If the problem is due to your dropping the camera, you might be out of luck.
If you have not dropped your camera and still facing this problem, then contact service people to replace the CCD imager in your camera .
Hope this helps .
Shane
Dec 21, 2011 | Sony Cyber-shot DSC-T300 Digital Camera
Its a Panasonic DMC-TZ3. all on a sudden, LCD is not working. Monitors remains dark when I press 'On' button and the photo taken are also dark. However old photos on the SD card I can in the screen...
Hello
If you can view the pictures previously taken with the camera on the camera LCD, but the new photos just come out black, this is most probably a blown ccd.
This is a expensive component to replace, and you will also need specialized equipment to do this yourself.
I would suggest that you take your camera to your nearest repair shop and let them test the ccd.
Hope this can be of help.
Kind regards
Andrea
Aug 12, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
File Error shows up when I try to view photos taken
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C387963&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=144190705&stateId=1 0 144204387
The above link describes the following:
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files.
Another problem may be that the Memory Stick Pro/Duo or Memory Stick Pro used in the camera has dirty contacts, causing this error.
Or, the memory stick pro/duo is damaged somehow.
Remove and blow out the memory chamber with compressed air, and remove from any adapters and clean with compressed air and then reinsert fully into the chamber for the Memory Stick on the camera.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C265373&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=144190804&stateId=1 0 144204763
The above shows how to reset a cyber shot camera from sony.
Follow the appropriate procedure below for your camera.
Using an Initialize option in the menu
Since Cyber-shot cameras have different menu system layouts, refer to the instruction manual specific for your camera model.
Using a RESET button
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 26, 2010 | Sony DSC-T70 Digital Camera
Black view finder
try a new memory card,many have been destroyed by photo-lab processing machines!
also,sticks DO go bad!!
Dec 21, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Fuji Finepix E550. Camera working O.K. midway after 18 pictures whenever buton was pressed to take pictures the camera shuts itself off. Batteries new, able to view pictures taken but cannot now take...
Thanks for your prompt reply. The problem has been solved!!!! I put in new batteries and the camera is functioning normally.!!!!!!! It seems the batteries in the camera were old ones and not fully charged. I think its safer to put in new batteries than to use recharged ones !!!!!!
Anyway, thank you once again and have a Happy Christmas.
Gratefully,
Ken
Dec 17, 2008 | Cameras
Canon PowerShot A510
Your LCD display might have switch off by mistake.
Press on the display button in the camera.
Jun 09, 2008 | Canon PowerShot A510 Digital Camera
System error
This is fundamental break down and may not be repairable. Check out th Nikon Web site technical support
Jun 17, 2007 | Nikon Coolpix 4300 Digital Camera
Change battery message
I am experiencing exactly the same problem with my Canon Powerhot S2IS. I tried the same thing to remedy it by cleaning off the contacts, but no luck. And it's not simply a cold weather problem. My camera does this with brand new Duracell batteries as well as with freshly recharged NMH batteries. What gives? I've had the camera for nealy 2 years and have taken excellent care of it.
Oct 24, 2006 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot A520 Digital Camera Logo
134 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
