Question about Sony VAIO PCG-Z1WAMP1 Notebook
Hard disk crashed
Removed the screws on the casing but can not get the cover off to remove/replace the hard drive. any thoughts?
    President:
  • 2,961 Answers
I think it maybe mounted through to top of your laptop under the keyboard, for instructions on how to remove keyboard and sometimes the HDD is held in a carrier. click below http://www.vaio-link.com/tutorials/memory/memory.asp?l=en&category=0&serie=PCG-Z1&m=1165
Posted on Nov 01, 2006
Toshiba disk drive mk6028gal
The hard disk drive (HDD) in your Toshiba laptop is the component that holds all the files and folders you use.
If you are running out of room on the hard disk drive because of all the programs you have installed, it may be time to replace it with a new one that has a larger capacity.
Replacing the hard disk drive on a Toshiba laptop is a fairly straightforward and simple process, as you only need to remove one other component to be able to reach the hard drive.
Save a backup copy of any file or program that you will need from the original hard disk drive to an external device such as a CD-RW or USB flash drive.
Shut down the Toshiba laptop's operating system completely.
Disconnect the power cable if it was plugged in and then close the top screen lid.
Flip the entire unit over so that the bottom end of the laptop case is facing towards you.
Hold down the release latch for the Toshiba laptop's battery.
Slide the laptop battery out of the case and then put it aside.
Locate the screw at the upper-left corner of the case that holds the CD or DVD drive into place.
Remove the screw and set it aside. Grab the edge of the CD or DVD drive and then pull it away from the Toshiba laptop case. Set the drive aside.
Remove the four screws holding the large square plastic cover over the hard disk drive at the lower left end of the laptop case.
Lift the square plastic cover off the laptop case and set it aside so that you can see the metal plate that covers the hard disk drive.
Take out the screws holding the metal plate in place.
Lift the metal plate out of the case and set it aside.
Remove the two screws at the top edge of the hard disk drive and then the two screws at the bottom edge of the hard disk drive.
Disconnect the hard drive from the motherboard by sliding it out towards you.
Lift the hard disk drive out of the case and set it aside.
Push the new hard drive into the open slot and then reconnect the four screws.
Set the metal plate back on top of the new hard disk drive and then attach its screws.
Put the plastic cover on and reattach the cover's screws.
Slide the CD or DVD drive back into its port and then reconnect the screw.
Put the battery back into the Toshiba laptop.
Turn the laptop over and open up the screen.
Power the computer on. Insert the recovery disk that came with the Toshiba laptop into the CD or DVD drive.
Follow the operating system installation instructions that will appear on the screen.
Transfer the backup copies of the files you saved earlier from the external device to the new hard drive.
Toshiba Satellite hard drive replacement
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Aug 13, 2013 | Computers & Internet
Need to take cover off a HP all in one computer that has lock. Need to replace hard drive. How do I get if off?
I never knew a computer came in All-In-One's. That's for Multifunction Printers. Anyway, if you're asking how to get to the hard drive it's simple.
If you're talking about a desktop, then you simply remove the outer case usually secured by 4 or less screws. Then you can remove the hard drive which might have screws or some type of bracket holding it in place.
If you're talking about a laptop in most cases you simply turn the laptop over and on the bottom look for a cover that has 3 or 4 circular disks on it. That's the hard drive. Remove the screws that is holding the cover, then you will see the drive. The drive might be secured by screws also and it might be inside of what is called a caddy which has screws. Remove all screws to get the drive.
Mar 15, 2012 | HP Computers & Internet
How do i put my hard drive inside? me
Open the external case, by removing some screws, and sliding the cover away from the insides.
Connect your disk-drive to the "power" and "data" connections, and secure the disk-drive with the mounting screws. Close the case.
Jul 25, 2011 | BYTECC ME-350V4-ISA SATA or IDE to USB 2.0...
How do i remove a harddrive from a computer case when only one side has screws to remove? Details: Okay so i'm trying to remove a hard drive from a computer case that only has screws on the back right...
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
Jun 12, 2011 | Compaq Computers & Internet
HOW DO I REMOVE THE HARD DRIVE FROM MY SONY VAIO VGC-LT23E? CHATTED ON LINE WITH SONY - THEY DID NOT WANT TO HELP. THE OLD HARD DRIVE IS CRASHING. I'VE WORKED ON COMPUTERS FOR OVER 15 YEARS, BUT I AM AT A...
I just did it. It's time consuming but not too difficult.
  • Take off the top three screws for the extra hard disk cover.
  • Take off the stand
  • Loosen all the screws around the back case. There a many. The ones on the four corners will not come out and they are vey long and take many turns. You also need to loosen the screw that holds the extra hard disk holder in.
  • Gently pry the case off. There are clips on several places and they will pop loose just be careful not to break them.
  • Once you have done this the hard disk has three screws on a holder. One screw is easy to spot and the other two are at the bottom of the hard disk.
  • The hard disk with the holder slides out. There are four screws holding the drive.
Oct 07, 2010 | Sony VAIO VGC-LT23E 22" PC/TV All-in-one
I want to replace HDD on my HP ProBook 4510sand I don't know how help somone.
Hard Disk Drive removal
  1. Review the safety considerations before performing the steps listed below by clicking on the following link: CAUTION: Failure to comply with the precautions could result in damage to your product or loss of data. CAUTION: Observe all precautions when removing and replacing components.
  2. Remove the battery, switch cover, keyboard, and palm rest.
  3. Remove the two silver 3mm P000 Phillips-head screws from the left side of the hard disk drive bracket.
  4. Loosen the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive away from the hard disk drive connector on the system board.
  6. Remove the hard disk drive from the hard disk drive bay.
  7. Place the hard disk drive in an electrostatic dissipating bag.
Hard Disk Drive replacement
  1. 1. Remove the hard disk drive from the electrostatic dissipating bag.
  2. Place the hard disk drive into the hard disk drive bay and align it with the hard disk drive connector on the system board.
  3. Use the black Mylar tab located on the hard disk drive enclosure to slide the hard disk drive securely onto the system board connector.
  4. Tighten the captive P1 Phillips-head screw on the right side of the hard disk drive bracket.
  5. Replace the two silver 3mm P000 Phillips-head screws on the left side of the hard disk drive bracket.
Sep 19, 2010 | HP ProBook 4510s FM849UT Notebook
I need a Emachines D620 SERVICE MANUAL! I'm needint to replace the hard drive in my friends laptop! READ THIS!!! I AM NOT GOING TO PAY 0.01 FOR SOMETHING I SHOULD BE ABLE TO DOWN LOAD FOR FREE!
One DOESN'T need a service manual to replace a hard drive!
You just need to open the case where the drive is. Usually a few screws that are obvious on a cover on the bottom of the units for most laptops. Some have only a couple screws then a carrier slides out.
There is usually a carrier that may require a couple more screws to remove and then up to four screws holding the drive to the carrier.
There often is an adapter plugged onto the drive which you have to transfer to the new drive in some cases.
Just go slow an keep the screws in little divided tray to make sure you put the right length back for each location.
Oct 17, 2009 | eMachines eMD620-5133 Notebook
Hard disc
Switch off the Printer and remove the Power Cord.
1. Remove 6 T-15 screws (Type B) from
the HDD Access Cover. Remove the
HDD Access Cover.
2. Remove the HDD with its foam holder.
3.
Disconnect the HDD Cable and Power
Supply Cable from the HDD.
When Installing the Hard Disk Drive make sure the holder is
placed in the right position so that it cannot move.
When the Hard Disk Drive is
replaced perform the
following Service Utility: Backup EEROM
Backup EEROM
This Service Utility is used to restore the contents of the EEROM
when a service engineer has replaced the Main PCA or the Hard
Disk Drive. If the Main PCA is replaced the EEROM content,
backed up on the hard disk, is restored to the Main PCA and if the
Hard Disk Drive is replaced the EEROM content is saved to the new
Hard Disk Drive.
Before using this utility, make sure that you are using Firmware
version A.02.xx. If NOT, make sure that you upgrade the
Firmware version to A.02.xx BEFORE using this utility.
1. In the Service Utilities submenu, scroll to "1.6 Backup EEROM"
and press Enter.
2. Select the part that has been replaced and press Enter
3. If you select "Hard Disk Drive (HDD)" a message confirming
selection is displayed. Press Enter to confirm and exit this utility or
press Back to cancel.
4. Press Back to return to the Service Utilities menu.
Sep 23, 2008 | HP Designjet 5500 (42 in.) InkJet Printer
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Vaio VGN-TXN25N, need to remove hard drive
Usually the laptop hard disk is only reside in the side of the laptop. Sometime you need to remove the small cover first before you can see the screw. Look in the right side of the laptop or in the back but there is also laptop model that the hard disk is below of the keyboard.
Apr 23, 2008 | Sony VAIO VGN-TXN25N/B PC Notebook
Sony VAIO PCG-Z1WAMP1 Notebook Logo
141 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
