I have the fridge freezer above. Only seems to work on the coldest setting, any less and the fridge and freezer defrost. When the fridge door is opened the light flashes, the green light flashes and you can hear the compressor cutting in and out. Close the door and all is well but sick of my kitchen becomming a disco every night!!! Any help or suggestions will be greatly appreciated. I have not removed the fridge freezer to look at the back. Thanks
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
SOURCE: Fisher & Paykel active smart E521T
I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
SOURCE: SERVIS MO262S FROST FREE FRIDGE/FREEZER, FRIDGE NOT WORKING
servis frostfree fridge freezer not working after 2weeks holiday returned it had completely defrosted fridge & freezer power supply still connected. warning light on. done all the trouble shooting in the srvice manual still want go cold or freeze. light on in the fridge, no water in the rear tray & cleaned the overflow pipe??. Model No M0330-ALU 5yrs old. think it has 2 seperate thermostats, surely they wont both have gone at the same time???????
SOURCE: Servis Fridge Freezer not working
fridge appears to be working, but freezers section intermittingly keeps going off
This is the integrated model so has no display panel. Also there are no door switches visable, the fridge door light seems to be operated by a magnet type switch, there is no ice build up in the freezer but the rear wall of the fridge is pretty frosted up! Thanks
Any idea's anybody?
