Question about Panasonic CT-32D12D 32" TV
CT-27SX11E Fixed but need advice on R value
I fied this set the fault was R801 suerge resistor in the supply line now need some advice the original value of the resistor was 1.5 ohmes 7watts since i din't have 7watts i replaced with 1.5 ohms 5watts is this ok. thankyou.
  • 4 Answers
It is not good to replace the Watts of a resistor for a lower wattage the best thing you can do is if you didn't find the 7 watts resistor replace it for a 1.5 ohms 10 watts or more if you can't find that one you can always use a resistor with higher watts but not with lower than marked on the actual resistor , this is because the comsumption of amps of the resistor can damage a lower wattage resistor.
Posted on Nov 06, 2006
    Scholar:
  • 119 Answers
I would not recomend replacing the 7w with the 5w, beacuse the resistor will allways run hot, hotter then the resistor should be. the resistor could possible melt anything that touches it & will not last as long as the original before it goes bad. find a 7w, if just for safty reasons.
Posted on Nov 03, 2006
Value of resistor R801 on sony model KV-1420A
If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand TVs and other devices are given.
Sep 10, 2016 | Sony Televison & Video
Horizontal lines across TV screen Panasonic CT-31SF13U
The problem sounds like a vertical deflection issue form what you describe.
On average they are usually in the simple repair categories. On average they would run in the $50 range if you take it to a reputable repair shop.
There are several possibilities
Bad capacitor (s)
Bad vertical IC
resistor in the power supply to the vertical circuit changing value
Jan 24, 2009 | Zenith B25A10Z 25" TV
Jvc th-s8 no sound
There is a stock fault on the sub woofer unit.
R2702 fusible resistor is likely to be faulty.
Here is their modification - dodgy english but you get the idea.
Reasons: R2702 (QRZ9005-470X) a 47 Ohm 1/4W resistor is open circuit due to rush current at the time of
power supply ON/OFF.
Cure: 1) R2702 change value : QRZ9005-470X --> QRJ146J-220X
2) C2704 change value QETN1EM-107Z --> QETN1HM-476Z
Sep 28, 2008 | JVC TH-S8 System
Panasonic COLOR CT-27G14A
check Vertical IC out (LA78..) and resistor voltage supply from flyback transformer to this ic. Check the STR main power supply(and resistor near, change value), some times seems good out main board,but in operation not good
May 18, 2008 | Televison & Video
Fried resistor, need value for R801
Brown/ Black/ Brown/ Gold It is a 100 ohm +/- 5%
Nov 08, 2007 | Sylvania 6413TG 13" TV
I have already responded to your first question in relation to the Ohms and wattage,It worries me that maybe you can not see an answer to that question.The wattage rating should be the same or highier.
Nov 01, 2006 | Panasonic CT-32D12D 32" TV
CT-27SX11E Panasonic
The Ohms are ok but the wattage should have been the same or higher.A 1.5 with only 5 watts is not sufficient.
Oct 31, 2006 | Panasonic CT2722H TV
Help on value of surge R801 Panasonic CT27SX11E Please
Check this out. http://www.pasc.panasonic.com/Epartr/PartsList.asp
Oct 31, 2006 | Panasonic CT-32D12D 32" TV
Panasonic CT-32D12D 32" TV Logo
101 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
