Question about Sony Walkman D-EJ100 Personal CD Player
Blinking "disc" error
On my sony cd walkman d-ej100 I insert a disc into the walkman and "disc" (blinking) error appears in the read out. It also shows the battery as full then shuts off.....will not play anything.Help???????????????
  • Anonymous Feb 25, 2008
    when i try pt play a cd it displayes disc error and the battery reads full
    Problem Solver:
  • 12 Answers
Another thing to do is listen to the unit as it spins up, you may be able to hear the disk spinning (though you can definitly see it if you open it up) and you should also be able to hear the mechanism that moves the optics allong the rail. If you hear that but still no read, you might try opening up the case (6 small phillips screws and then a small bit of prying to open) and look to see if the small thin plastic wireing harness is fully seated in the connector on the main board. If not loosen the small brown retaining clip and push the plastic strap with the traces fully into to connector and push the retaining clip back in. I have fixed 2 d-nf420 units this way.
Posted on Nov 16, 2006
    Problem Solver:
  • 9 Answers
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Posted on Nov 01, 2006
Thanks a lot.
Mihir Kulkarni (India)
Posted on Jun 09, 2008
Or you can 5 brokes ones on ebay and use them for frisbees, they seem to fly really far. haha !
Posted on Dec 15, 2007
Buy a new player if none of the solutions work!
Posted on Jun 16, 2007
2 Suggested Answers
SOURCE:
SOURCE: sony cd walkman D-EJ100 troubleshooting
There is a switch on the bottom of the unit that puts it in "HOLD" mode. My guess its for use when it is shipped so there will be less chance of damage. Try switching the two position switch to the other position.
Posted on Nov 14, 2009
Dvd/cd & blu-ray lights keep blinking
probably don't read copied discs, insert a genuine one a try then, and see if it loads
Dec 06, 2013 | Televison & Video
I have connected an adapter of 4.5V with Sony Walkman, i am receiving an error "HI DC IN". Let me know the problem.
hi,
check the out put voltage of that adapter may be its out put is higher than 4.5V dc.
thats why the Walkman displays HI dc IN. do one thing purchase a 4.5V 1amps SMPS adapter (connector with same polarity). it will give a constant output of 4.5v (110v t0 240v input)
ok
Jan 19, 2011 | Sony Walkman D-EJ100 Personal CD Player
My sony N50 won't play and reads no disc when htere is one in it. The batteries are fine
It is quite possible that your optical unit is faulty. First of all clean the lens on the optical head using an ear bud, softly rub for a good glazing. then try to see if it works if not the lens unit assembly must be replaced and must be done with care and experience.so take help to replce but make sure the cost is within a practical level. Good day
Aug 09, 2010 | Sony Walkman D-EJ100 Personal CD Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Sony cd walkman D-EJ100 troubleshooting
Aug 11, 2008 | Sony Walkman D-EJ100 Personal CD Player
2 questions
Hold down the Display/Menu function button (one of those three buttons on the left of the unit) for about 3-4 seconds until the display reads "t set". When this appears, push the track forward button once (>>|) so the display reads "beep"; now press the play pause button (>||) once. The display will now say "on", push the track forward button (>>|) once to make it read "off"; now push the stop play button. You're done. Enjoy the silence.
Mar 14, 2008 | Sony Walkman D-EJ100 Personal CD Player
Disc read error
check if your cd have scratches, this is one of the causes of disc error and you need to clean your cd rom you can use a cd cleaner just play it this cleans the lense o your cd rom
Nov 25, 2007 | Sony PlayStation 2 (PS2) Console
Discs will not play.
Could be some dirt on laser lenses. Try to clean it.
Sep 25, 2007 | NAD C541 CD Player
Sony Walkman D-EJ100 Personal CD Player Logo
420 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
