Try reflowing the video card. You probably have the Nvidia card which is a manufacturer defect. The card is soldered onto the motherboard.
These guys will reflow it, and ship it back by Fedex or UPS cheaper than any quote you get including shipping. If you can't get a quote as low as $125 then send it to them.
Look them up at: http://www.generalsystemsconsulting.com
SOURCE: HP pavilion dv6000 ( intergrated microphone problem)
Go check in the control panel to see if the microphone is configured correctly. Then check in skype to see if that is configured and try again.
SOURCE: how to change hp pavilion dv6000 from german to english
If you want to change Operating System from one language to another one, there is only one way. You need install English version of the Operating System. You can change some regional settings (time, writing languague to make programs recognise it), but nothing you can do about whole system. Please obtain an English version of Windows (or Linux if this is your operating system) and make a new installation on your computer. Of course back up all you datas before doing so
SOURCE: ethernet card driver for winxp
update the drivers via device manager and select the device with the yellow question mark,right click update,reboot and restart
if nothing then remove the device via add/remove programs
select device and remove,reboot and restart
should auto recognise and install the drivers for you,
dont forget to do SP2 updates
Good luck with that,
Let me know how it goes thanks
SOURCE: hp pavilion dv6000
The only internal power for a laptop is the battery. The external power is the AC adapter. (Charger)
If you're asking for the schematics, for the circuitry and component layout of the motherboard, to my knowledge only HP trained authorized technicians, have access to this. In truth, if they have a problem, they just replace the entire motherboard. It's more cost and time effective.
Which leads me to this. The main issue of power problems for a laptop, is the DC Power Jack, right after a failing battery. This is the round port on a laptop, where the AC adapter plugs in. Although replacement of this jack, is no 'Walk in the park', it isn't that tough. However, there aren't that many of we tech's around, who do this anymore. There are just a bunch of 'Parts Changers' out there. Still, from a laptop manufacturers point of view, it may be more time and cost effective, to just replace the motherboard. Less chance of that laptop coming back for the same issue.
I state, that the DC Power Jack is the main source for laptop power failure, right after a failing laptop battery because, the jack receives a lot of accidental abuse. When the AC adapter is plugged in, and the plug of the adapter receives a heavy 'bump', the DC Power Jack can break, or it's solder connections can break, very easily.
This is an enlarged photo of an average DC Power Jack, http://us.st12.yimg.com/us.st.yimg.com/I/yhst-42877593004970_2046_1476209 You can see the 'body' of the jack, is not much larger than the plug that goes into it. The body is also made of plastic.
The thick pin in the center is the Positive connection. The outer metal shell inside, is the Negative connection.
Sometimes the plastic body can break. Sometimes the connection at the end of the center pin, can break. Sometimes the cylindrical metal outer shell, inside the body of the jack, can break.
There is also another issue. In the photo the DC Power Jack is upside down, in relation to how it sits on the motherboard. The flat metal pins that are sticking up, go down through holes in the motherboard, and are soldered to the motherboard, on the backside.
(The flat metal pin in the middle sticking up, goes to the center pin in the jack. One of the flat metal pins on the sides, goes to the metal shell inside the jack. The third flat metal pin on the side, is just soldered to the motherboard, and helps to give strength to hold the jack in place)
Sometimes these solder joints for those pins can be broken. They develop a crack in the solder joint.
In a case like this, just re-soldering the solder joint/s, puts the laptop back in business.
I posted all of this, in case this is the issue you are having.
The following is a link to a Maintenance and Service Guide, for the HP Pavilion dv6000. Don't let the name 'Guide' fool you. This is really an extensive Service Manual.
It tells you, and shows you how to disassemble the entire laptop down to just the bare motherboard in your hand. Also tells you and shows you how to remove and replace all the hardware components inside. It also has all the part numbers. It also has exploded illustrations of the entire laptop.
This is HP.com/Support>Manuals, and the page to download the manual I stated above,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1842155&
Just go down to the blue ->
HP Pavilion dv6000 Notebook PC Maintenance and Service Guide <- , and click on it.
This is a PDF file you download. You have Adobe Reader on your computer. Adobe Reader uses PDF files.
After you copy and paste the link above into your address bar, press the Enter key.
For as much as 30 seconds, you may not see anything happening. The file is downloading, I assure you. The first page may pop-up after ten seconds. IF So, you should see a green Adobe download
bar below to the right. It will show the progress of the download. I suggest you let the file fully download, before you look through it. If you start looking through it before it is fully downloaded, you could break the download connection.
After it has fully downloaded, you can save it to your computer if you wish. This way you can have it to look at, anytime you want. You can also burn it to CD disk.
Just go up to the top headings, and click on the floppy disk icon. It is the second icon from the left.
Hovering your mouse cursor over it will briefly reveal, "Click to save this file to your computer or another location"
(IF you take the laptop apart, remove the battery and the AC adapter first. Also so I suggest using an ESD wrist strap. They are cheap, and help to insure that you relieve your body of Static electricity)
SOURCE: does the hp pavilion dv6000 have a sleep button ON KEYBOARD?
The default sleep setup is the Fn + F5
