susan beyer Posted on Nov 14, 2006
Xerox workcenter XD120f
When we make a copy by putting the original in the document feeder, the copy comes with a black line down the sheet. If we make a copy by laying the original on the glass, there is no black line on the copy. We originally thought it was a bad drum, but why wouldn't all copies have a black line down them?
A
Anonymous
Clean the small glass.
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Jan 27, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
5
Helped
9109
Points
16
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Every time I fax or copy a paper there is a black line through it
If you do it from the feeder you can get a line, because the paper goes past a strip of glass. It could have white out on it or some dirt. Clean that glass.
1helpful
2answers
Duplex copying on xerox phaser 3300mfp
I have the same problem and was told by the telephone helpdesk that the machine cannot copy double-sided to double-side. The duplexing referred to is copying 2 single-sided documents onto one single sheet on both sides....Like whoever does that! This is misleading on Xerox's part . Colin B.
12helpful
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
When i make copies a line appears on the right side of the copy. This problem does not occur when i scan to copy only when the document runs through the feeder
Clean the document feeder scanner glass. This is the much smaller strip of glass that is to the right of the large main glass. This strip of glass is used ONLY when using the feeder. So if you are getting a dark line when using the automatic feeder but not when laying a document on the glass then just clean the strip glass. 100% sure this is your problem. You may need to clean it several times as I have seen stuff get stuck to this glass.
Good Luck and Thank You for using Fixya.
We have a black line down the center of all copies...
If the problem only happens on copies or sent faxes then no it is not your drum. There is something on your scan glass. My guess is you are getting the line on your copies when you run the original through the document feeder. If you get lines through the document feeder but not on copies made off the glass then it is a dirty scan glass. There is a thin glass strip where the document feeder feeds the original. Usually something like white out that did not dry smears off an original and ends up on this thin strip of glass. Scratch it off with your finger nail and use some glass cleaner to resolve the problem. The scan glass is about 1/2 an inch to an inch wide and will be on the same side of the machine that the copier feeds the originals in on
Blank line down left side of outgoing fax or feeder copy
The most common cause of blank (void) lines on a scanned document is from whiteout on the glass where the page is scanned when using the document feeder.
If there is a clear mylar sheet on the bottom of the document feeder, the whiteout may be there instead.
If there was dirt or a dark smudge on the glass (or mylar), it would show up as a black line, but whiteout is white, and shows up as a void (blank) line.
1helpful
2answers
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
1helpful
3answers
I have a WorkCenter M20 and I am unable to use the document loader on the top of the machine... why is this? I try to load the documents and press start, but then onlty a blank sheet is spit out, because...
What you want to do is this. Turn the machine off, then go to the back of the machine and unplug the document feeder, There is a white connector with 2 thumb screws holding it in place. loosen the 2 thumb screws and unplug the plug. With the feeder unplugged turn the machine back on and let it come to ready. Once it comes to ready turn the machine back off, then plug the document feeder back on and turn the machine back on. That should re detect the document feeder and work fine. The M20 for some reason just forgets it has a feeder and you have to force the plug and play portion of the software to detect the machine not having a feeder then seeing that is has one. I don't know why, not even the newest versions of firmware for the machine resolves that issue. Odd,,,,,
6helpful
2answers
Black lines
There is a thin strip of glass that you will see when you lift the top feeder. There is most likely white-out on it.
When you use the top feeder, it doesn't use the large glass, it only 'rolls' the original document over this small strip of glass.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
