1981 Moto Morini 500 Turbo Logo
Anonymous Posted on Nov 10, 2008
Dash warning lights
The dash warning lights I read somewhere that green is for lights on What about the neutral light?
Anonymous
Level 3:
President:
  • Master 2,336 Answers
  • Posted on Nov 10, 2008
Anonymous
Master
Level 3:
President:
Answers
2336
Questions
37
Helped
756034
Points
8022
These things seem to differ depending on where they were delivered and the fact that the bulb holders can be switched around easily doesn't help. Mine was delivered as follows: Red = Low oil pressure Yellow = Headlight on Green = Neutral... or maybe not Blue = high beam I've rewired my yellow to flash with the turn indicators 'seems more useful to me.,,
2answers
2answers
Fuel warning light on
its 1 of 2 things.
1: the fuel is low, use a dip stick, if gauge reads ok.
2; or the tank sender is bad, but gauge reads wrong.
3: the guage wire is disconnected, cut or corroded connections.
Park neutral position switch
Yes I would agree the trans selector switch has failed, provided the wiring is good.
The license plate lights would be on a different circuit tied into the regular tail lights.
1helpful
Inner lights on dash and speedometer dead
fuseboxes normally are in one of 3 places..under the drivers dash.. in the glovebox.. or under the hood near the battery..dealer can say for sure..
Green water or oil can looking light on ford diesal dashboard
its coolant low indicating light.
Check the link below:----
Blue Water Warning Light on Dash?
http://whatisbyme.blogspot.in/2012/07/blue-water-warning-light-on-dash.html
These will help.
Thanks.
Ive got a 1983 Subaru GL wagon, Automatic trans. non turbo. My problem is that the brake fluid, stop lam, and A.T. Oil temp warning lights on the dash stay on constantly. I noticed that whenand if they...
Yes it may be the wires are shorting or its actually the problem with instrument cluster.
Also get the vehicle scanned for any error codes stored in computer this will confirm whether is short circuit issue or actual problem:------
I suggest you few help links with accurate solutions to refer/go through:----Click the link below:------
Battery and brake Warning lights on Dash
http://alltypesofpartsreplacing.blogspot.com/2012/10/battery-and-brake-warning-lights-on-dash.html
--------------2002 Ford Windstar: Brake Warning Light ON dash? http://schematicsdiagram.blogspot.in/2012/06/2002-ford-windstar-brake-warning-light.html
-------------ABS & Brake warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
-----------Chevrolet Tahoe Hood open warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
-----------2005 Chevy Impala: Service Vehicle Soon Warning Light? http://whoisbyme.blogspot.in/2012/06/2005-chevy-impala-service-vehicle-soon.html -------------- Malfunction Indicator Light ON http://whoisbyme.blogspot.in/2012/06/malfunction-indicator-light-on.html
-----------Car Runs Fine But Check Engine light is ON?
http://whatisbyme.blogspot.in/2012/05/car-runs-fine-but-check-engine-light-is.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
How to Read Codes from Check Engine Light? http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
-------------These will help.Thanks.
3helpful
2answers
What is blinking red light on top of dash board by wind shield and what is green light on rear view mirror for
The Green one on the rearview sounds like an autodimmer. (tints the rearview mirror from bright headlights behind you) & the Red one on the dash could be an alarm warning light
2helpful
2answers
Dash panel warning light is permanently on and reads POWER
sounds like the check engine light...probably needs to be looked at by a mechanic
Top Moto Morini Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Moto Morini Expert? Answer questions, earn points and help others
