Question about Panasonic PV-C1352W 13 in. TV/VCR Combo
Panasonic PV-C1352W cable signal
I set up cable in my apartment, and i should now have basic cable up to 90 channel on this tv. Unfortunately, i only have the basic local channels. My cable rep tells me that this may be because my tv is set at the wrong signal. How can I change the signal if I do not have a remote for the tv?
    Sergeant:
  • 337 Answers
They claim that if you leave the set unplug from the wall for about 10 minutes and then plug it back in and ushing the power button the set will auto program all the channels available,Without the remote is possible but not as easy,in the front of the set you have the stop/eject button and the REW button,if you press both buttons at the same time a MENU(display) should come up on the screen,keep pressing action until the CH square is highlighted then use the arrows up or down until antenna is selected the use the arrows left or right to change it to Cable,once is in the cable mode go down one more to auto set and press the arrow to the right and it should auto program all the available channels. I hope I made sense but just in case here is the link to the owners manual http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportResults?storeId=15001 ,it can be done.You can use my name in a new question to let me know how it goes ir if you need more information.
Posted on Nov 01, 2006
  • Omar Urrutia
    Omar Urrutia Nov 01, 2006
    THe first link does not work use this onehttp://www2.panasonic.com/webapp/wcs/sto...
    I went to select a category then I selected televisons,the I selected TV/combos the I found the model in the list and I was able to see the owners manual.
    Your rating response is also important.
I have a Panasonic PV-V4525S VCR and I'm trying to program it to work with the Comcast cable. Right now it will only record the same channel that the TV is on and I have to tell the VCR to record channel...
If your using digital cable it will only record channel 3 or 4 depending on what your cable box is set to...In order for it to record different channels it needs a cable source plugged directly into it. You will only be able to record standard cable channels 1-125. If it's digital cable forget about... you can only record it with channel 3/4 a solution to this would be using a 2nd digital box.. "auto-programming" may be limited even with a 2nd cable box. If your only using standard cable 1-125... you can use the TV/VCR button it will switch between the tuner of the TV & VCR allowing you to record while you watch a different show... keep in mind this won't work for digital channels which if I'm not mistaken comcast has already converted all channels to digital even basic.
Feb 13, 2011 | Panasonic PV-V4522 VHS VCR
Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
May 12, 2010 | Panasonic PV-C1350W Combo
I can´t sintonice more chanels than 17. How
If you have a cable system hook-up, in the menu setup there is a selection for type of TV signal, select cable and then select the auto channel tune feature.
Apr 29, 2010 | Panasonic PV-V4022 VHS VCR
I need a Code to Program my Panasonic PV-C135 2W to work my
code should be in the owners manual -- if not -- you can download one online ==
Feb 27, 2009 | Panasonic PV-C1352W 13 in. TV/VCR Combo
Connect to Converter Box
There are a fews ways of accomplishing this.
On the back of your converter box and TV/VCR there are two coxial connections an (OUT) and an (IN):
Step 1. Connect the coxial cable from the antenna to the (IN) connection on the back of the converter box.
Step 2. Connect one end of a spare coxial cable to the (OUT) connection on the back of the convert box.
Step 3. Connect the other end of the Coxial cable to the back of your TV.
I hope that you find this solution helpful. Please take a moment to rate tis solution.
Jan 19, 2009 | Panasonic Televison & Video
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Need new part for panisonic pv-c1352w
Replaced tuner after getting part number thru panisonic
Aug 24, 2008 | Panasonic PV-C1352W 13 in. TV/VCR Combo
Cannot program cable to tv
if your are using a cable box,all of your channels will be control only on the cable box.so, what you are going to do is use the remote control of the cable box.
Nov 07, 2007 | Panasonic PV-C1320 13 in. TV/VCR Combo
Panasonic PV-C1352W 13 in. TV/VCR Combo Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
