Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Picture will not come on
When you push the on button for the tv, the button will light up red but no picture will show up. There is also no sound.
- HiTech I am having the same issue, are you sure about your solution?? Because if I unplug the Covgence IC board, the TV power up with a miss-aligned screen. So I am assumming is the the IC board (STK392-040 with other burn out resistor) I am about to fix that, so I just wanted to know are you sure your soultion will work? - Judy, can you confirm did you get this working by fixing that
Posted on Nov 09, 2006
    Problem Solver:
  • 7 Answers
Sounds like you Switching IC has failed. This is becoming a common problem with this type of TV's. This IC is identified on the board as IC831S (STR-X6456). The chip cost about $24.
  • Charles Husak Nov 10, 2006
    This was a possible solution, but if you say it powers up when you
    remove the Covergence Module this could be a possible problem. The
    Samsung's are equipped with a Fail Safe circuit, if the F/S changes from its 2.5 volts the MICOM kills power to T801S. To test
    this check the power on CN801. They sould read as follows:
    with your meter attached to TP61 to grd should read 117 volts and
    13.8 volt at TP62. If these are not present then T801S is turn-off. If they are present then you will need a Oscope to do futher
    testing or just replace the Covergence and see what happens.
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
First time to operate indicater light comes on reacts to remote but no picture or sound 42 philips flat tv
First red light normal
Now select channel or other source from remote with full batteries or pushing buttons left down side of TV. Red light is only stand-by
Apr 28, 2009 | Philips 42 in. Plasma TV
No picture, no sound
we need a request on what the blinking red light means on your model number and manufacturer of TV, we can then try to see what the blinking light means,(although it doesn't sound good) You ca always unplug the DVR and see if there is a change, then you would know it was the DVR
Thanks for the rating
Apr 12, 2009 | Televison & Video
Setting up 42lg3000 with sky and lg home cinema dvd system.picture and sound from dvd.poor picture and sound from tv speakers only from sky .please advise on correct wiring connections for this set up.TV...
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Nov 29, 2008 | Televison & Video
LC-23Y25 Problem with turning on power?
so i had the same problem. red light came on, but no blue light or anything on the screen. it turns out that there were some capaciters blown on the circuit power board. unless you have a good understanding of circuit boards, its not a quick fix. but for someone who knows their electronics, its not too hard, and its not expensive to fix, unless you bring it into a store. but the supplies needed arent expensive. good luck
Nov 09, 2008 | Prima C2012 TV
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Dec 22, 2007 | Televison & Video
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Jerry Greenberg
Jerry Greenberg
