Are there any uninstall problems encountered with this application when uninstalling it from Windows 2003?Are there any uninstall problems encountered with this application when uninstalling it from Windows 2003?
I went ahead and uninstalled it and did not encounter any problems. I had a small window of time to take hold of the opportunity and went for it.
Thanks to anyone who looked at it.I went ahead and uninstalled it and did not encounter any problems. I had a small window of time to take hold of the opportunity and went for it.
You can't post conmments that contain an email address.
It may be possible if you have a another lifetime. It might work in legacy mode, you can easily get a 3.5" drive to connect by usb, and image the disks using winimage then install from the images or even use the disks directly, but you are going to spend a LOT of time and effort and then it might not work. Move on unless your bitcoin collection is on the discs.BTW what is Window 85, did you mean Windows 95?
Invalid parameter.
File or directory does not exist.
File: C:\PROGRAM FILES\HANDYCAFE\SERVER\PDOXUSRS.LCK
Directory in use by earlier version of Paradox.
File: C:\PROGRAM FILES\HANDYCAFE\SERVER\PARADOX.LCK.
go to the directory and change the file "PARADOX.LCK" to "PDOXUSRS.LCK"
I use "DOS Box 0.74". it opens a dos window that you can run paradox in. Its FREE and works great, even in full window mode. Only issue I had was I toggle to DOS occasionally to clean up txt files and DOS Box has limited DOS commands.
no not unless you plan to use a virtual machine to emulate a earlier version of windows like 95 or 98 you could if your really determined i hope this answers your question and please vote
It seems to me like this program is not designed for Windows 7.
This has happened many times. Microsoft always upgrade but, do not include the words, " Previous Software may not work with new O/S. "
Im afraid this software will not work on Win 7. Sorry.
However you could try to ask Corel online if they have an upgrade, for this prog,for win 7.
Hope this helps.
