SOURCE: My Garmin 205W does not
With the satnav turned off Press the bottom right corner of the screen and then slide the on button to the right and hold it until the prompt comes on. You'll be asked if you want to do a factory reset. Select yes and it will reset.
SOURCE: My Garmin nuvi 660 only
This is caused by a corrupted file on the Nuvi. To fix this issue, a special version of firmware has to be flashed on the unit, telling it to not look for the corrupted files. The unit will boot normally, then using the PC, the corrupted files need to be replaced and then finally the special firmware needs to be replaced (reflashed) with a standard firmware.
I have done this numerouse times.
- Jim
SHARCNET-USA
SOURCE: my garmin 255w keeps telling me that it's
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the
bottom, press and hold it until the nuvi powers back on. If it does not
have the reset button on the bottom, slide and hold the power switch to
the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
