Question about Amana AOCS3040 Electric Single Oven
I am unable to trun it on. Control pennal does not work
Without any reason one day this thing stopped working. NOw the pannel show the clock and the " OFF" . Any key does not work. How can I bring it out of this stat? Power on and off does not change this condition. PLease help me.
  • 5 more comments
  • Badar Awan Nov 19, 2006
    Thanks for yur help, your suggestion brought the oven out of off state, now when I try to bake or brial it shows F9 or F6, what is this. I will really appericiate your help.
    I lost the manual for this oven, is there any way I can get the list of error codes. I really appreciate your help. You are the guru
    Thanks for your quick response, I really appreciate it.
  • greg1459 Nov 05, 2007
    I have the same problem, but pressing bake and cooktime will not bring it back. I have turned the power off and on a number of times hoping it will will work. Still nothing.
    The only button that works on the control panel is the oven cancel button. It just beeps when pressed.
    Any suggestions?
  • dave shoe Dec 16, 2007
    yes need code book
    need a code book fo means
  • KBKB Jan 30, 2008
    The control panel says "Off" and the oven won't heat. There are no other F codes.
    President:
  • 878 Answers
Badar, press and hold bake and cooktime together for 5 seconds. Sometimes a power failure will put it in lock mode. Catriver..post back.
Posted on Nov 17, 2006
  • Ron Marek
    Ron Marek Nov 19, 2006
    Badar, F9 is the code for a failed lock motor or switches. The lock mechanism for the self clean latch will have to be checked out. I'm not finding a F6 for the model posted, but in most Amana built in's F6 means a failed electronic control. See if you can put this model into the quick test mode. Kill the power to the oven, re-apply the power. After power is back on, press and hold the cook time pad for 5 seconds. Now press clean and you should see a the door lock status. You have approx 30 seconds between tests, bake,broil, convection, light etc., by pressing each pad to test the function. If any one fails, you should get an error code in the display. Press cancel to exit the test mode. Catriver..post back.
  • Ron Marek
    Badar, check out this link http://www.affordableappliance.com/Tips/...
SOURCE:
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
GE Wall Oven Model # JKP07G0D2BG - The clock has quit working. Any suggestions would be greatly appreciated.
I assume the display for the clock/timer is now blank. If the oven is still working the only thing you are missing is the clock. If you can't do without it you will need a new clock.
Most of the time the clock/timer stops working it affects the operation of the oven, the oven won't work. If this is the case you will need a new timer unless you can do without the clock/timer. If so a repairman should be able to bypass the clock with ease so that the oven will operate without the clock/timer.
Feb 12, 2011 | GE 24" Built-in Single Electric Wall Oven...
On the window where it shows the clock time, it showed error E0 F2. The stove top works but the oven stop from working. All the digital numbers and all keypad entry was not functioning. For the whole time...
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock). Follow the link for diagrams and illustrations of your specific model.
Oct 14, 2010 | Ovens
NEFF CIRCOFIRM OVEN HAS DIED? ITS 8 YEARS OLD, HAS ALWAYS WORKED WITHOUT FAULT BUT 2 DAYS AGO IT STOPED RESPONDING TO ANY CONTROL, AND THE WINDOW WHERE TEH TEMPERATURE RANGE IS DISPLAYED IS SHOWING -5- OR...
the chid lock is activated!! how did you manage to do that accidentally??? the instruction manual tells you how to disable it from memory it is turning the oven mode selector switch 3 times beetween the light position and off quickly.
Aug 27, 2010 | Neff B1641 Single circotherm super...
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
Turn off the timer on an old imperial st george
I have this exact same oven and this "feature" annoys me no end. To turn it off ... turn the clock dial to PAST the time that the timer dial shows. EG: If your timer dial is showing 6, turn the clock dial so that it rolls past 6 o'clock. This will pop out the timer dial and thus turn off the timer, allowing you to use the oven normally.
To stop accidentally pushing/turning that timer dial, I removed the knobs. Good luck.
Jan 23, 2010 | Ovens
FO shows on led board for both ovens
HI. This is a basic communication issue that will concern, either the control board, or touch/Key pad assembly. Normally, this will produce a stuck key, which will cause one of the power relays to become suspended.
Determine if The problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting the key pad Ribbon Cable from control(main), and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE_ Some models incorporate the touch/Key pad into the EOC as a single assembly(Whole device), in which case this test is not necessary. Simply replace the EOC (Clock).
Nov 06, 2009 | GE Profile JT952 Electric Double Oven
Oven doesn't work
Looks like it's time to put your oven down and adopt a new one. (Taps plays softly)
Aug 15, 2009 | Ovens
ERROR F6
HI, the reason for the non responsive control is being caused by a major fault within the control circuits. the entire control board will need to be replaced. it has failed at this point.
Replacing the Oven control board will solve this issue.
Jul 19, 2009 | Ovens
Amana AOCS3040 Electric Single Oven Logo
280 people viewed this question
Top Amana Ovens Experts
Steve Allison
Steve Allison
Sal De
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
