Computers & Internet Logo
Posted on Apr 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I've setup the router (edimax 3G-6200n)and all was working well for a couple of days. This morning however, only the power light is on. The LAN network cable is fine as i connected it directly to
Jeffrey McDaniel
Level 3:
  • Master 669 Answers
  • Posted on Apr 04, 2012
Jeffrey McDaniel
Master
Level 3:
Answers
669
Questions
0
Helped
200422
Points
1944
If the only light you have on is the power light, it is most likely dead. You try unplugging the router then plugging it back in to see if this clears the issue. If it does, the issue will probably come back. Your best bet is to replace this router.
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
Only power light goes on when I reconnect to electricity. WLAN and LAN lights stay off
It sonds like you are ethernet connected to the Edimax from your home computer. Can you access a wireless connection? If so Try This:
Unplug the ethernet connection between the PC and the router. Exchange the connection (The ethernet connected to the PC place it in the Edimax and Put the connection from the Edimax into the PC) Check to see if you have a connection light on both devices.
Reboot you Edimax and PC. First turn on the PC and let it power up to the desktop. Once the PC is on then power on the Edimax. Now check to see if you have a connection. If these steps don't work I suggest you try replacing the ethernet plug connected between both devices.
2helpful
Would like to know how to configurethe WPA password for edimax router br6226n
Use an Ethernet cable to connect from one of the LAN ports on the router to the network port on your Windows computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway ... 192.168.123.456
Start Internet Explorer
Type http://192.168.123.456
Press Enter
Login to your router's web-interface
Click to run the Wireless Networking Setup Wizard
Choose 'WPA' or 'WPA2' encryption
Pick a SSID ("network name" for your wireless network)
Pick a password for your network
Click OK to restart the router
Connect via the new SSID/password
Cannot connect to the internet
Improve the Fixya.com experience for everyone by voting!
The solution I'm suggesting works in my business (LAN installations) about 95% of the time. I trust that it will work for you.
Let's see if I can help you.
Begin by turning on your computer and your router
? Open Internet Explorer;
? Click on 'Tools';
? Click on 'Internet Options';
? Click on 'Connections';
? Click on 'Setup'
? Click on 'I want to set up my Internet connections manually . . .';
? Click on 'Next';
? Click on 'I connect through a local area network (LAN);
? Clock on 'Next'
? Click on 'Next' [This is not an error];
? Click on 'No';
? Click on 'Next';
? Click on 'To connect to the Internet immediately . . .; and,
? Click on 'Finish'.
That should have you online
All the best
Ben
2helpful
4answers
My usb connection with my huawei ec226 for Internet
check the modem installer if there is a need to install the driver for usb port of your modem to your pc.
1helpful
3answers
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Top Edimax Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
