Question about Sylvania SRCD227 27 in. TV/DVD Combo
Sound but no picture
Our DVD player wasn't opening so we took off the back of the TV to try and fix it. We fixed it, but when we reconnected the wires, we now get sound but no picture at all, just a blank screen. Are there any particular wires that control the ability to produce the picture that we should check? We don't have any technical knowledge about how a tv works. Thanks
    Sergeant:
  • 337 Answers
Is hard to tell what might be happening but the set has wires coming from the chassis to the crt board,backtrack your steps and check the conectors,ussually they can only fit one way and can not be forced in,make sure they have not been switched and stay away from the thick red lead coming from the output transformer to the back of the picture tube,it has high voltage and it can hurt a grown up man easily,the crt board in the neck of the picture tube nneds to be pushed in all the way,just checked that is in and if you have to remove it make sure you pull straight out and do not twist it because one of the pins in the crt might break,if you took it out before just check that one of the pins is not bent.Let Us know if you need more information.
Posted on Oct 31, 2006
  • Omar Urrutia
    Omar Urrutia Oct 31, 2006
    Your rating response is also important.
I have a magnaxox dvd/vcr player that is hooked up to a high def TV. It got disconnected Now when we connect it we only get the sound and no picture. How do we fix this?
Reconnect the player to the rear of the TV noting correct color codes, usually red for right channel audio, white for left channel audio, and yellow for video.
Mar 23, 2018 | Televison & Video
I have sound from my DVD player but picture is from the cable show how do I fix and make them both the tv sound and picture or dvd sound with picture, what settings
take sound from audio out from back of TV rather than from back of DVD player.
Move the red and white rca cables to the audio out of the TV
Jan 18, 2017 | Televison & Video
Can't get video on vhs sound but no picture, is it broken
I had the same problem, so I took it back to basics. Hooked cable into VCR/DVD player and another cable from player to TV. S cable too, plus red/white audio. Plays DVDs on AV1 and VHS on Channel 3 on TV setting.
Jun 30, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
I have the Sony KV-36XBR400. The picture freezes intermittently. Sound is OK. When I turn TV off and on again, I may get a good picture for about 15mins, sometimes longer. Sometimes half of the screen will...
Hi.. Sorry to hear that the Picture is freezing.. Here are some of the steps that you can try:
*Try to connect a different video source with the TV like DVD Player, Blu-ray player and check.
*If the issue persists, disconnect the power cord and reconnect to a different wall outlet without the Power surge protector.
* If the issue persists, you need to contact the nearest service center to fix this.
Yes, you were correct many LCD TVs have problems compared to this TV.
Sep 22, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Will play sound but no picture
1.check your video cable between DVD and TV.
2.in back of dvd one yellow socket only for video out others for some other purpose.
3.open tray conditon .-go to system menu on Remote -go to general set up page-video set up -and switch of .progressive -in OFF-mode.
then try it for video play back
4 if not ok replace the video decoder ic.
Nov 12, 2008 | Philips DVP642 DVD Player
No picture after resetting by pressing stop button for 20 sec
Problem fixed: I realized that the problem was that with resetting the player it defaulted to the standard video ouput ie no longer sending signal through the component video. I used a standard video cable and connected player to tv with that and it had a picture. Then I changed the setting to progressive output and got picture signal through the component cable again.
Aug 15, 2008 | Cyberhome CH-DVD 300 DVD Player
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
No sound thru dvd player, but fine for tv and vcr
Just had the same problem and it is fixed for me. With NO DISC in the player go to the System Menu. Next Navigate to Preferences on the top of the screen.
You will set an option titled "Default". Select that and it seems to reset the player to default settings and fixes the sound.|
Jan 03, 2008 | Philips MDV460
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
DVD PLAYS GREAT, TV AND VCR PLAY IN BLK-WHT W/NO SOUND
You have your DVD connected to your VCR, which is then connected to your TV, right? The problem is Macrovision. It's designed to prevent you from connecting your DVD player to your VCR, so that you can't make duplicates of copyrighted movies. It's a real pain in the neck. Try turning the DVD player off - or better yet, unplugging its power cord (as some DVD players are always in a standby mode, even when turned off). If that fixes the problem, then you need to reconnect your DVD player directly to the TV, not wired through the VCR. If your DVD player isn't wired through the VCR, are you using some kind of wire splitter (one cable branches into two) to connect both the DVD player and VCR? That can also cause this kind of interference, if both have power at the same time. There are video switches you can get to work around that. Here's one such switch (first I found for a decent price with a google search): http://www.pickeasy.com/20070827-video-selector-switch-video-game-p-555.html Hope that helps.
Aug 30, 2007 | RCA 27F500TDV 27 in. TV/VCR/DVD Combo
Sylvania SRCD227 27 in. TV/DVD Combo Logo
59 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
