Question about Sony KV-32V40 32" TV
Tv shuts off - sony kv-32v40
Timing is sporatic, usually 15-60 mins after start usually flashes orange prior to shutdown sounds like a capacitor discharging during shutdown i've read similar issues w/ recommendations of resoldering various parts, but haven't read anyone else having orange flashes or discharge sounds & wanted to check if these events are relevant
    Sergeant:
  • 337 Answers
They are very relevant because you might have a high voltage ark from the output transformer or a shorted picture tube,the ark or high voltage leak you might not see but the shorting of the picture tube you will when it does it,being careful remove the back cover and leave the back open,turn the tv on and wait for the moment the shutdown takes place and look at the neck of the picture tube and thru the glass of the tube you might see the moment it shorts out and the set shutsdown,if you see something in the neck of the tube is because the tube is bad,take a look at the conections in the crt board maybe one of them is loose,the arking or leakage from the output transformer is dangerous and it should be observed from a safe distance(10 feet),if you notice something in the output transformer he will need to be replaced,both situations involved high voltage areas and if you are not too familiar with tv service you should get the assistance of a servicer.It is a good idea to resolder the main board if the two possibilties do not show or when the main problem is corrected.Let Us know how it goes or if you need more information.
Posted on Oct 31, 2006
  • Omar Urrutia
    Omar Urrutia Oct 31, 2006
    Your rating response is also important.
Why does my Sony 57" Hi-Scan 1080i? 16:9 Projection Television keep turning itself off. I turn it on and after 10 min it shuts itself off I can turn it back on but the longer it is on the quicker it shuts...
Sounds like a heat problem. Check to make sure that if it has a internal fan that it is working, and clean any dust build up, most projection tv's have fans, usually the number of flashes indicate a code that repeats.
Mar 16, 2010 | Sony KV-28FX60 28" TV
Unit shutdown immediatly then standby light flashes 7 times
check secondary power supply. check eletrolytic capacitor nearby chopper and regulator
Jun 01, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
No picture, no sound, stand by timer light flashing
Need a little information here...
1. The TV remains on, yet there is no picture and no sound? Or does the TV turn off altogether?
2. How many blinks does the standby light give? Are they continuous? Is it the same each time, or random?
3. Did anything else happen before this, or did it just happen one day?
Answer that and I'll try to help with what I know.
Jun 09, 2008 | Sony KV-32V40 32" TV
Sony KV-32V40
I'll let you know if the user manual is available.
Blank screen
These tvs are known for bad power supply capacitors. Try power cycling the tv several times (8-10) to see if it finally comes up. Four flashes indicates a power supply problem or a deflection problem, usually it is the first. Take the set into a shop if you are not an electronics technician, as these are dangerous areas to work on. Otherwise, use a capacitor checker to test the caps, starting with the main supply caps which are usually 200v. I've found these to be low by 200uf. Also, check the 1000uf and 2200 uf caps. These will be low by 100 - 200uf.
It could be a flyback or deflection problem, but check those caps first.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
KV-32V40 32" TV Problem:
1. The TV remains on with no picture, but the sound is fine?
This problem is indicative of a problem with one of three (of the same) ICs. Give me a bit more info and I'll give you some links to the solution, or help you myself.
Nov 24, 2007 | Sony KV-32V40 32" TV
Sonykv-32v40 red ligt blinking black screen and soud good
Take it to a shop... It's a good bet that the jungel Ic, crt driver Ic or something in the HV has failed. Could be also that the crt itself is failing. If that's the case a tech can test it with a B&K and know for certain.
Also, if you want to save a few dollars take it in to them, don't make them come and get it - it just drives the price up for a pu/del charge.
Bill
Nov 24, 2007 | Sony KV-32S45 32" TV
No picture but sound ok
HI,YOUR PROBLEM IS ON THE FLYBACK TRANSFORMER OF YOUR TV. YOU MUST REPLACE THIS BUT BE VERY CAREFUL REMOVING THE FLYBACK.
Nov 22, 2007 | Sony KV-32V40 32" TV
Sony kv-32v40 Screen blins on and off
Increasing the screen control will not repair the problem,look for loose conections in the Horizontal driver transformer,readjustback the screen control.
Aug 25, 2006 | Sony KV-32V40 32" TV
Sony KV-32V40 32" TV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
