IF IT STUCK IN PARK.CHECK BRAKE LIGHT SWITCH FUSE AND THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID FUSE.AND PARK NEUTRAL SAFETY BACK UP SWITCH FUSE.IF ANY OF THESE 3.IF FUSE IS BLOWN OR ANY IS FAULTY.YOU WONT BE ABLE TO MOVE CAR OUT OF GEAR.ANOTHER THING MAKE SURE YOUR BATTERY HAS 12.5 VOLTS.
You need to remove top off gearbox and with a pry bar or screw driver pull the selector back into neutral Your gearlever has popped out of selector Gearbox does not need to be removed
shift linkage needs adjusting,,could be bent, easy fix, located along firewall to fram beneath the column, ask your son wut he ran over and didnt tell u about... hope i could help...:)
What engine? Rear wheel drive ?Sounds like shift linkage or cable out of adjustment slightly. Have a look at where cable or rod attaches to transmission for adjustment. If not sure of what your looking for get back to me with info.
