Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
The grinder works, the on/off light comes on, but no brewing???
Pleasen help !!! The water just sits in the tank, there is no brewing . It looks like the water is not pumping up????
  • 1 more comment
  • hopgal Nov 13, 2008
    Ours is doing the same thing. I thought at first it just needed cleaning, but I put vinegar solution in it overnight, and it didn't help. Also, I took the charcoal filter out & that didn't help either. I think maybe it needs to be sent in for repairs.
  • Anonymous Nov 22, 2008
    We have the same problem. We ommited the filter in the water reservoir a while back so I thought that it is clogged, or  pump is done..possibly.
  • Cindy_NJ Feb 16, 2009
    I have the same problem. Was fine until I turned it upside down to read the serial number when I called customer support about getting new rubber gaskets for the feet. No gaskets available - I added some cork circles which solved that problem. But then the water wouldn't feed thru the coffeemaker. But I've turned it upside down before when I accidentally put too much water in the reservoir so I doubt that's the problem. Still turns on and grinds and waits a minute or two then stops as if the cycle is complete. I left vinegar in it overnight and nothing helped. The support hotline also said I probably need to replace it.
  • 8,596 Answers
You have not missed anything. Unplugging for longer than 16 minutes (has 15-minute memory) is the only troubleshooting you can perform. Call Cuisinart to find out if you are still in warranty. All electronics have a failure rate. Cuisinart's is acceptably low, but their coffee makers are the least reliable of all their products. The basic problem with electronic coffee makers is that coffee makers produce high heat, and high heat kills electronics and melts plastic. At least Cuisinart has a 3-year warranty - higher than the industry standard.
Let me put it another way. All coffee makers have a high failure rate. As many Cuisinart coffee makers that break down, the non-Grind-and-Brews still have a 91 rating from Consumer Reports. Consumer Reports doesn't give ANYTHING a 91 rating. A lot break, but you probably won't fare much better by switching to a different brand. The problem with a Cuisinart breaking down is that an expensive unit broke down - you wouldn't be upset if your $15 Mr. Coffee broke every year. The law of averages is on your side - a 2nd Cuisinart will probably last longer.
-Tha Mp3 Doctor
Posted on Dec 17, 2008
What can I do to have the Ready to Brew light come on? I tried to slowly pour in water and fill water tank but doesnt work.
Be sure spray disk and brew gasket are properly installed in the
brew head.
Be sure the water supply is properly connected and the water
supply valve is turned
ON
Be sure the WATER TANK IS FILLED
BEFORE plugging the brewer into a receptacle, or otherwise
connecting brewer to electrical power
THE WATER TANK MUST BE FILLED
Place an empty decanter under the brew head. Lift
the pour-over cover then pour warm tap water into the pour-over
opening until water flows from the brew head. When water stops
dripping from the brew head, empty the container.
Once the tank is full of water,
connect the brewer to electrical
power. The heating elements will begin heating the water in the
tank.
When the water has reached the proper temperature, the
"READY To BREW" light will glow. http://www.cdccoffee.com/pdf/bloomfield-8571-8572-user-manual.pdf
May 12, 2015 | Bloomfield 8571 Coffee Maker
Coffee maker turns on but will not brew
why question to all of this is with a "self clean" button, why doesn't it every tell you to clean it..... ??
Sep 07, 2012 | Cuisinart DCC-1200 Coffee Maker
I have a Hamilton Beach 6 cup brew station and it has stopped taking the water from the tank and making any coffee. It just sits in the tank making noise like it is working but nothing happens. Thanks...
unplug it,empty contents
put 2 cups white vinegar in tank , plug in and start brew cycle.
discard vinegar and run 2 tankfuls of water through to remove vinegar taste
Jan 08, 2011 | Vacuums
Saeco vienna Deluxe grinder doesn't work properly
Try to open the steam knob and make a cup of water.
Make sure everything is in place.
One more thing you can try is:
open the door, take out the brewing unit, driptray and dregsbox.
Look in the machine and you will see three hole, one in the lower left corner, one in the middle above the driving shaft and one in the right upper corner.
Turn on the machine and put a screwdriver in each hole and see if the lights go off.
Hope this will help you.
/Mirran
Sep 02, 2008 | Saeco Vienna De Luxe Espresso Machine
Replacing micro switch
You have to take of the top, there are several screw to loosen.
  1. Take off the water tank and bean hopper
  2. Take out drip tray and dregbox
  3. loosen the two screw in front where the dregbox and driptray was ( one in each corner)
  4. Take of the plastic adjustment in the right corner (grinder adjustment)
  5. Loosen the screw in chassi where the water tank was, look inside where the beanhopper was to make sure there not are a screw, some models have one there. If there are one you will see that behind the grinder.
  6. Take off the plastic on your steam pipe.
  7. Take off the top.
  8. On the right side near the hole where you put pregrounded coffee, there will be a little microswitch.
I hope this will help you
Jul 14, 2008 | Saeco Royal Digital Plus Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Krups Grind & Brew KM7000
if you dont have something jamming the grinder look like blow grinder motor you can trie activate the grinder at the same time gently tap the side off machine maybe what ever blocking the grinder gonna come off if not tank good for warranty good luck cheers
Jan 17, 2008 | Coffee Makers & Espresso Machines
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
No coffee coming out of the machine!
First step, increase the grinder size. Note: only change grinder setting while the grinder is spinning. If that does not work, look into cleaning your brew group screens. The machine should have came with a key to remove the screen. If your machine as a preground option try making a preground coffee without inserting coffee to see if only water will come out. If water comes out then you know its your grinder. Usually too small of grinder sizes will stop water flow.
If you need a brew group key:
http://cerinicoffee.com/Saeco_Brew_Group_key.asp
Espresso machine Cleaning supplies:
http://cerinicoffee.com/Coffee_cleaning_supplies.asp
Dec 01, 2007 | Saeco Incanto Classic Espresso Machine
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
318 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
