Question about Gigabyte GV-NX62TC256 GeForce 6200, (256 MB) PCI Express Graphic Card
Dual monitor problem
I'm having GV-NX62TC256P4-RH PCIe video card based on Nvidia GeForce 6200 video chip. This card has three outputs: DVI, Analog VGA and TV Out. First monitor is connected on Analog VGA and second is connected via DVI-Analog converter to DVI port. I'm not using TV Out. I have installed drivers that came on cd with graphic card, and I'm running Windows XP Professional with SP2. I'm having problems running both monitors in same time, in DualView mode. In dropdown list within driver preferences, there is only SingleView mode, and in this mode both monitor work perfectly, but only one at a time... Is there any solution? Can this card run two monitors in DualView mode (user's manual say they can)? Thanx in advance!
  • 2 more comments
  • Sasa Milovanovic Nov 03, 2006
    Thank you for your reply...
    I want to use both monitors in dualview mode, not TV and monitor... I suppose that I don't have to explain you why I don't want to use TV as second monitor :)
    Greetings!
  • Sasa Milovanovic Dec 01, 2006
    Sorry for a long delay, I was out of country...
    Just tryed your suggestion, downloaded files and all... It appears it's not working with my card. It's not even listed in .txt that comes in archive :(
    Too bad... but, I'll try to find updated bios for my card anyway.
    Thank you :)
    I have downloaded the file... name of the file is same as my video card...
    But there seems to be problem inside the archive file...
    When I start update utility it's says: This VGA card is unknown.
    Also, in readme.txt there is nothing about my card... :(
    I guess somebody mixed up something :(
    Thanks again for your concern...
    Maybe it's the flash utility that is wrong...
    I'll try with utility that comes with card...
  • 47 Answers
I've heard this card will support dual monitors but might need a firmware upgrade to do so. You can get the new BIOS here; http://www.gigabyte.com.tw/Support/VGA/BIOS_DownloadFile.aspx?FileType=BIOS&FileID=12292 Hope this helps. Let me know. Dudester
Posted on Nov 16, 2006
  • The Dude
    The Dude Dec 01, 2006
    Strange.
    The file name you downloaded was vga_bios_gv-nx62tc256p4-rh_f2.exe right? That is the exact model number of your card yes?
    Did the BIOS upgrade work or was there a problem with the install?
    President:
  • 2,961 Answers
I think you may have to use tv out as the secondary monitor
Posted on Oct 31, 2006
Hi.i`ve vga card problem.but i haven`t my card driver.i must download this from internet.please help me
Posted on Jan 15, 2009
Very easy fix buy a dvi-vga adapter plug both monitors then this will activate the multi display option you can then select which combination you wish to use
Posted on Sep 01, 2007
2 Suggested Answers
SOURCE:
bronk50
  • 27725 Answers
SOURCE: nVidia GeForce 6600GT card (XP
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disc the drivers could be on it
Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don
Posted on Mar 26, 2011
No encontro el driver adecvado para la tarjeta grafica: Model 7600GT PCI-E 256Mb DDR3 TV-OUT DVI. Sistema Operativo win 7
you can download driver on this page:
http://www.nvidia.com/object/win7-winvista-32bit-266.58-whql-driver.html
Mar 02, 2011 | Gigabyte GV-NX76T256D-RH GeForce 7600 GT...
I have an EVGA 6200 in an HP P4HT...it is working properly, and I can run dual monitors..BUT, my #1 monitor is a 23" Acer LCD, and my #2 is a 19" Dynex TV. #1 is run of the VGA cable, and #2 is run off the...
you have an nvidia based card. there should be nvidia control panel with those drivers, if not download it. to find out just right click an empty portion of your desktop. then look for nvidia control panel. if it is there just start it. then on the left side of the control panel look for display and click the subcategory set up multiple displays. this will give you a window that shows both of your displays. just uncheck the clone displays. this will allow you to configure them independently.
Jun 26, 2010 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Will an Nvidia GeForce 6200 graphics card support dual monitors?
I would say yes one on your old computer montior connect and one on the card unless that card has two tv outs
Jan 28, 2010 | Evga nVIDIA GeFORCE 6200 TurboCache 256MB...
Cant identify model no of my Gigabyte graphics card -- need driver Just says ''Silent Pipe II''
GIGABYTE introduces GV-NX76T256D-RH graphics card based on the 90nm NVIDIA Geforce 7600GT GPU. The GV-NX76T256D-RH, which features proprietary GIGABYTE Silent-Pipe II technology with new NVIDIA 7600GT, delivers higher performance than other passive thermal solutions. In addition to triple guarantee, including performance, cooling and 0dB, the GV-NX76T256D-RH also also fully supports SLI, Shader Model 3.0, and OpenGL 2.0. With 128 bit memory bus and 256 MB GDDRIII memory, the GV-NX76T256D-RH ensures High-Def PC gaming and flawless digital media playback.
Oct 29, 2009 | Computers & Internet
Have a new 23 inch samsung monitor that requires res 1920x1080
The problem is the cable connection to the video card.
When using the DVI output of the FX 5500, the maximum screen resolution that you can select is 1280 x 1024.
But, if you use the Analog (VGA) output, the card will support resolutions up to 2048 x 1536, which should be ok.
Apr 23, 2009 | XFX GeForce FX 5500 Graphic Card
Choosing Graphics card.
NVidia Geforce series, i have found is the most reliable and less likely to screw with your system in a negative way like Radeon.
I have used all forms of video cards in the past. the GeForce series is stable. I have a Dual HDMI output card myself, its only a 512mb DDR2 but it does the work load of MMORPG's with ease and my system very rarely has issues unless i am trying to run more than i rightly should. So my suggestion is the GF9600T. It is powerful beyond beleif and will make resolution and texture ratio through the roof.
Thats my professional opinion on this.
Nov 02, 2008 | Computers & Internet
Nvidia GeForce 7200 GS PCIE - Multi-Display does not work
This card does not allow you to Multi-Display with the VGA port and the S-video port. If you put a DVI to VGA port adaptor (not supplied) on the DVI port, you can Mulit-Display two VGA monitors and (presumably) a VGA (from the DVI port) and S-video monitor.
This is not explained anywhere and the card does not come with a DVI to VGA port adaptor, so I wa only able to work this out after I bought the DVI to VGA port adaptor.
May 21, 2008 | Nvidia GeForce 7200 Graphic Card
Video card for Dell 531s
This computer uses a PCIe-16 slot, so any half-height dual-monitor card with DVI would do for you. The XFX Geforce 7200GS with 256MB memory has dvi and vgb outputs. It supports the resolution of your 20" Syncmaster, and is around $40 at Newegg.com at this time.
Nov 04, 2007 | Computers & Internet
Computers & Internet Logo
2,423 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Thomas F. Schneider
robert roberts
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
