Question about Philips KEY005 128 MB MP3 Player
Getting my computer to recognise the player
My dell computer will not accept my player when the wizard for install hardware comes up it says drivers not installed software could not be found .even though i have installed the disc which came with the player.it works on my sons computer fine .but not mine i get a message saying the player is not digitialy signed.is there any help out there
  • 3 more comments
  • ann buckley Nov 14, 2006
    i have now manage to install the drivers but my computer fails to recognize the device allow itis there my computer is a dell dimension 2400 running service pack 2 xp home
    hi sandrew . i did all that . the drives for my mp3 are now installed but the computor just ignores it. windows media player does not see it either nor does real player nor music match
    hi the drive where installed from the software that came with mp3. it does not show under my computer list . but when i remove it on the safe to remove hardware it is there. it is plugged into a powerd usb. but what is usb 2. could it be an power issue ie not enough power to the usb
    hi the mp3 is by philips and is supposed to work on windows xp . the mp3 works fine on my daughters and sons its just my computer that does not like it. thanks for your help anyway.
  • ann buckley Nov 16, 2006
    tried all that i have a feeling it is a usb problem on the computer itself .and i was on xp from scratch
  • 47 Answers
Hi Annebelle, I just read the user manual for your KEY005 and it says it's a USB 1.1 device and that no drivers are needed for WinXP. It ALSO says that the device is powered directly from the USB port when plugged in. The USB hub might be the problem. Try plugging it directly into a USB port on your PC. If it still does not work try flipping the switch to OFF/CHARGE and then back to PLAYBACK/DOWNLOAD. I think plugging it straight into the PC will solve the problem. If not you can try the latest versions of any drivers/software from here: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=FLASH_AUDIO_PLAYERS_SU&session=20061116141635_68.37.246.195&grp=PORTABLE_ENTERTAINMENT_GR&ctn=KEY005/00&mid=Link_Software&hlt=Link_Software BTW you didn't happen to upgrade to WinXP from a previous version did you? That can sometimes cause problems like this (ESP. with USB devices) unfortunately upgrading to WinXP is NOT the same as a full fresh install of WinXP (gotta love M$) I hope this helps. Let me know how you make out, El Duderino
Posted on Nov 16, 2006
    President:
  • 2,961 Answers
When you install the software/driver a message box will pop up saying this driver is not digitally signed, you sould ignore this and click continue, otherwise the driver will not install.
Posted on Nov 14, 2006
  • andrew pester
    andrew pester Nov 14, 2006
    If you computer fails to recognise the player, the drivers are not installed properly.
    Check in my computer to see if your mp3 player appears in other devices as a storage device, if not the driver is not installed.
    Also make sure it is being connected to a USB 2 connection as sometimes mp3 players specify using USB2.
    Also if you have a non powered USB hub (eg. not mains powered, usb powered only), this will also cause connection problems.
  • andrew pester
    usb2 is a faster file transfer rate, but I PODS for example will only run on a usb2 port, although, if it were not recognised it would not give the option to remove safely, make sure the driver you have installed is for Win XP.
Computor wont recognize dvd player
You might need to have a computer administrator account to perform some tasks.
Most new devices your computer will recognise automatically. When your comp is running, plug in your new dvd player. Does it beep and say 'New Hardware added? If not then use
The Add Hardware Wizard which enables you to add new hardware or troubleshoot any hardware-related problems.
Open the Add Hardware Wizard
  • To open the Add Hardware Wizard, click Start, click Control Panel, and then click Printers and Other Hardware. Under See Also, click Add Hardware.
  • If it can't recognise the player, it gives you the option to select the correct make and model. Is yours on the list? If not, you may need to go to the Microsoft site and update the list of players.
  • Do come back here if you need further help.
Dec 28, 2013 | Televison & Video
Infitek MP4 8GB player - No Drivers??
What windows version are you suing?? Try going to device manager and look for a root hub there or any usb device that has a exclamation mark then right click on it select update driver and let the wizard search for the driver.
Hope that helps..........
Jul 31, 2008 | iLO (2 GB) MP3 Player
How do i turn on my bluetooth on my emachines pc
Click the "Start" button, then choose "Control Panel," "Network and Internet" then finally "Setup a Bluetooth enabled device."
Power on the Bluetooth Hardware you want to connect to the computer. You must have some sort of hardware to connect to the computer, in order to enable the Bluetooth connection.
Click "Add" and the computer searches for any Bluetooth hardware in the area. Once it detects the hardware, select it and click "Next."
Type in the passkey for the Bluetooth hardware (found in the device's user manual) and click "Next."
Install any drivers now that came with the Bluetooth hardware. (Insert the driver installation CD that comes with the Bluetooth hardware, wait for the the installation wizard to load onto the screen, accept the license agreement, then click "Next" for the installation name and location and select "Install" to install the drivers.)
Choose "Locate and install driver software" if there are provided drivers. If not, click "Don't show this message again for this device" and click "OK."
hope this helps
Aug 12, 2012 | E-Machines eMachines W2686 PC Desktop
How to install a Dell printer 1710 without the disk
you can download the driver from here.
http://www.dell.com/support/drivers/us/en/19/DriverDetails/DriverFileFormats?c=us&l=en&s=dhs&cs=19&DriverId=R109665
Custom Instructions for Dell_AAY_Win2KXP_Driver_en.exe: * Follow these steps to install 1. Download the file to a directory on your hard drive. The file downloaded is a self-extracting executable. 2. Execute the downloaded file and follow the on-screen instructions. 3. After the files have been unpacked, you may delete the self-extracting file downloaded in step 1. 4. Plug in the printer to the computer. 5. When the "New Hardware Wizard" comes up, follow the onscreen instructions. 6. When prompted for the drivers, browse to C:\Dell\printer\Drivers\Print\Win_2kXP and click next. 7. After the "New Hardware Wizard" is complete, reboot the computer.
Mar 08, 2012 | Dell Office Equipment & Supplies
My sony nwz-b152f is not accepting .i need adriver for that
You don't need any driver software, if your pc has windows xp sp2 or later and Windows Media Player 11.
If you have problem with your device follow this steps:
1. Connect the player to the computer.
2. From the computer, select start - Control Panel - Performance and Maintenance - System. "System Properties" is displayed.
3. Select Hardware tab, and open Device manager.
4. Open Universal Serial Bus controllers, and select USB Mass Storage Device or WALKMAN NWZ-XXXXX.
5. Select Action - Update Driver ... from the menu bar. "Welcome to the Hardware Update Wizard" is displayed.
6. A dialog on Windows Update connection will be displayed. Select No, not this time., followed by Next.
7. Select Install from a list or specific location [Advanced], followed by Next for the hardware install method.
8. Select Don't search. I will choose the driver to install., followed by Next for the search and install option.
9. Check Show compatible hardware, and then select MTP Device* in the model list, followed by Next. The device driver is installed.
10. "Completing the Hardware Update Wizard" message is displayed, and confirm "MTP Device" message. Click Finish.
Good work and luck!
gylacz
Jun 24, 2011 | Sony Walkman NWZ-B142 MP3 Player
Can't get the usb port to accept the mp4 player.
Switch on your Mp4 player and connect it to the usb port. Your computer should produce a message "New Hardware Detected". If you don't get such a message either the lead, the usb port or the Mp4 player is faulty.
If you do get such a message, if your computer can't find and instal the right drivers automatically there will be another message or the Found New Hardware wizard will appear. By following the onscreen instructions your computer should be able to search the internet for suitable drivers.
In any eventuality, when connected the Mp4 player should appear in the My Computer window and if it doesn't it isn't connected.
Jun 26, 2017 | Samsung YP-T9JQB Digital Media Player
Dell P-1500 laser printer
how do i install dell p1500 without cd
Jun 05, 2008 | Dell P1500 Laser Printer
Philips KEY005 128 MB MP3 Player Logo
116 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
