Question about Dell A920 InkJet Printer
A920 scanner malfunction
My Dell A920 has a scan problem. It scans the image but shows solid black for the first 2 inches and then the rest of the image. All settings have been checked as well as obstructions and placement of the document. Any suggestions?
  • 56 Answers
There could be the hardware issue with the scanner.So contact the tech support incase the warranty is still there and you could getb a replacement
Posted on Dec 27, 2007
SOURCE:
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
hi
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    Dell 810 all in one printer/scanner not scanning
    scanning is a bit of a trick. You have to have hardware to scan with, and SOFTWARE to receive images. Make sure the scanners imaging software suite has been installed, OR, you can use the scanner manager in windows to scan with. Just select the dell 810 as the "scanner source" and click "scan". that should do it.
    Oct 26, 2009 | Dell 810 All-In-One InkJet Printer
    My Dell copier model# A920 will not copy manually
    If you want to scan you will need to connect the device to a computer. For copying, place a document to be copied on the flatbed scanner and press the color or black button (as appropriate).
    Jun 02, 2009 | Dell A920 InkJet Printer
    A920All-in-one
    The all in one solution software you used in XP doesn't work fully with Vista.
    But you can still scan and copy by using Windows Photo Gallery.
    1. Click on files tab at the top in Window Photo Gallery.
    2. Click on import from camera or scanner.
    3. Highlight your scanner icon (eg Dell A920) then click import.
    4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
    Hope that helps.
    Chris (ziraffa)
    Jan 08, 2009 | Dell 962 Photo All-In-One InkJet Printer
    C4480 cannot scan to pc
    I can not scan from my printer to my pc. I have a hp c4480. everything works on it. bill
    Jan 04, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    Printer prints solid black block at end of page
    You have to replace the white tape, connecting the scanner sensor with the printer PCB. 26642b8.jpg
    Nov 23, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
    Dell a920 all-in-one printer
    just try by reloading the software for the printer & scanner
    Jul 23, 2008 | Dell A920 InkJet Printer
    Dell A920 3 in one printer/scanner
    wow..that's most likely from the scan settings..make sure that the area you are scanning in your software is showing all the image of what's on the glass..
    Mar 20, 2008 | Dell A920 InkJet Printer
    Dell 920 scanning/copier problem
    do you have a driver for vista
    Feb 09, 2008 | Dell A920 InkJet Printer
    Black section in scans
    Check/clean scan glass for marks (small section of glass under lid that runs width of copy glass.
    Is lamp dim or dark in one section?
    at low res. what is the result?
    Nov 04, 2007 | Lexmark X1150 All-In-One InkJet Printer
    Dell A920 InkJet Printer Logo
    55 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    David Patricia James
    Marvin
    Marvin
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
