Question about Lands Phones
Change clock time.
Hi, I have an NEC phone XN120, and need to alter the time. Any sugestions please.
Thanks
The XN120 I know is a PBX, so setting the time sets it for all phones connected to the PBX. The time can only be set on an XN120 system phone which has an LCD display (or a PC - see below). It's quite complicated - refer to setup guide such as
http://www10.GIScafe.com/nl/newsletter_confirm.php?enc_email=ZGF2ZS5jb3ZlbGxAc2lnbWFzZXZlbi5jby51aw==&subscriber_key=5d4ff921b647525ca172f7fb11ae56b4
Some of these PBX systems have TCP/IP network cards installed so the time can be set from the NEC PC-Pro configuration program run on a network connected PC.
Posted on Feb 06, 2009
How do i change the time and date!? PLEASE HELP!
Change the Time:
1. Press SPEAKER key, enter 728
2. Dial 2 digits for the hour (must be in 24 hour clock time)
3. Dial 2 digits for the minutes 4. Press SPEAKER
For more information go to this link
NEC PHONE SYSTEMS TIME AND DATE PROGRAMMING Inlinecom
Aug 21, 2014 | NEC 80570 Telephone
NEED TO CHANGE CLOCK TIME
On an Elite, IPK or Pro II, from one of the 2 main phones it's Feature,9,#, then enter hour, minutes, then seconds, then Feature to write and exit.
Mar 28, 2014 | NEC Lands Phones
How do i change the time on my verizon ravine 2 from military time to 24 hour time?
Hi Marilyn - As military time is the same as 24 hour time, did you mean you'd prefer to display 12 hour time rather than 24 hour time?
The phone's manual explains how to alter the clock format so I've copied the relevant part for you.
DISPLAY SETTINGS (page123 of manual)
EASY SET-UP
To set up display options using the Easy Set-up Wizard:
1. Press the Center Select Key [MENU], select Settings & Tools and press the Center Select Key [OK]. Select Display Settings, press the Center Select Key [OK], select Easy Set-upthen press the Center Select Key [OK].
2. Select the display settings including the PERSONAL BANNER, DISPLAY BACKLIGHT, KEYPAD BACKLIGHT, MAIN WALLPAPER, DISPLAY THEMES, MENU LAYOUT, DIAL FONTS, MAIN CLOCK FORMAT, FRONT CLOCK FORMAT, and press the Center Select Key [SET].
To skip the step, press the Right Soft Key D [Skip].
MANUAL FOR CASIO RAVINE
http://nec-casio-mobile.com/support/download/GzOneRavine2_Manual.pdf
VERIZON FORUM TOPIC - CASIO RAVINE CLOCK
Casio zOne Ravine 2 Support
Dec 20, 2013 | Creative Labs ZEN V Plus MP3 Player
Change the time on our NEC DT300 Series
What model of NEC phone system do you have? Go look in the phone or data room and look at the PBX. You might also be able to press Feature 3 to get some information which would be helpful to a tech. If it is an SV8100 try this:
To set the system Time:
1. Press
Speaker.
2. Dial
728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
Oct 08, 2012 | NEC Lands Phones
What steps do I take to change the time on my NEC DTERM 80 phone system? I have already tried the Feature+9+# as well as the Recall+728 but those do not work. The first gives me an error message.
NEC Electra Elite IPK
  • 1 Press the "Feature" key on the phone system's main terminal. This is one of the Dedicated Feature keys and is located at the bottom left hand corner of the keypad.
  • 2 Dial 9# to enter the clock setting menu.
  • 3 Enter the hours and minutes using the key pad. For example, if it is 12:15, you would press "1," "2," "1," and "5."
  • 4 Press the "Recall" key on the bottom left hand side of the phone key pad to toggle between AM and PM.
  • 5 Press the "Feature" key to exit the system.
NEC Electra Elite IPK II
  • 1 Press the "Speaker" key located at the bottom left of the phone key pad.
  • 2 Dial "728" to enter the phone's clock menu.
  • 3 Dial the hour using two digits. Use military time for any time in the afternoon. For example, 1:00 AM would be "01," but 1:00 PM would be "13."
  • 4 Type the minutes using two digits ranging from "00" to "59."
  • 5 Press the "Speaker" button to set the time
Read more: How to Change the Time on an NEC Phone ' eHow.com http://www.ehow.com/how_7338757_change-time-nec-phone.html#ixzz1XUGjOOet
Sep 09, 2011 | NEC Dterm DTP 16D-1 Corded Phone
Need to change the date and time NEC 22b
From extension 300, dial #TD.
If you have other NEC DSX or NEC DS2000 questions let us know at http://www.nec-dsx.com
Jan 13, 2011 | NEC 80570 Telephone
How to connect my laptop via RS232 to my NEC XN120 telephone exchange using the PC Pro telephone system software in order to programme the exchange?
I connect mine with the RS-232 cable in the side of my laptop. It's a Toshiba rinning Windows XP (nee Vista).
Since you're asking the question, I guess you don't have an RS-232 port. For my Vista machines without serial ports, I own a USB to RS-232 adapter cable. On our side of the pond, they carry names like Iogear GC-232. Here's a U.K. search result http://www.amazon.co.uk/USB-RS232-Converter-Cable/dp/B00077DJIQ
Sometimes, you have to go into the device manager and change the port assignment of these adapters to something in the 1-4 serial port range. That was common with the old software.
Carl
Feb 22, 2010 | NEC Lands Phones
Need help changing the time on my clock
hi from uk to reset clock ? there are two buttons/stalks? on the speedometer clock the left one is for trip reset and the right one is for clock reset/alter time to alter twist left for hrs reset and right for minutes it springs back to neutral when you let go hope this helps ?
Jan 27, 2009 | 1999 Hyundai Accent
Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Jan 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
146 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
