Question about Magellan RoadMate 700 GPS Receiver
Missing user preferences, no audio, blue-black-logo startup screen -- FIXED
I have a Magellan Roadmate 700 with 5.14 software. For many months, everything had been working fine. One night, while using the GPS, the unit reset itself and when it started up, it flashed the light blue (blank) screen, then a dark blue screen, then finally the logo screen. At this point, my name was no longer on the user screen and there was no sound either. Subsequent restarts confirmed this same issue, no user settings were being stored nor any of my previous destinations, etc. No sound either. Per Magellan tech support, they asked me to perform a "manual update" of the map data. This required me to plug the unit into my computer, show system files (view options in My Computer), and delete all folders on the device other than the USBTrans folder. Then perform a reload of the software from the original DVD. This did not solve the problem, however. It also took over 2 hours, but I believe that is normal. Well, after contacting Tech Support again, they indicated it must be a bad hard drive, and since it was out of warranty, it would cost $150 to send in and get repaired. Instead of doing this, I looked around the web and found this site. In one of the postings here, it mentioned a few "secret" menus you could use to check the equipment or format various parts of the unit. I selected the option to format the NAND memory. After doing so, the unit turned off. On start-up, the sound worked again!! And even better, the user settings I entered were still there on restart. I am now running the reliability tests on the NAND memory and the Hard Drive, but I am hopeful this solves the problem. Thanks for the great resource!!
  • poppy a May 07, 2008
    will not start up with blue light key. blank blue screen and cant shut it off , logo comes on for 1 minute and screen goes blank.. called customer service a f----- nightmare.. can you help an old marine veteran? thanks art d
    Novelist:
    Scholar:
  • 86 Answers
Glad to be of service.. did everything end up working out ok?
Posted on Nov 28, 2006
Frozen screen after update 3.11 to my Roadmate 1470
roadmate 1470 will not boot up. stuck on startup logo
Jul 23, 2011 | Magellan RoadMate 1470 GPS Receiver
My Magellan RoadMate 1340 will power up to logo and "moving clock
Have you tried updating the software on your device.
Go to Magellan.com and download the Magellan Content Manger:
http://www.magellangps.com/products/map.asp?tab=0&PRODID=2216
Once you've installed Content Manger onto your PC, connect your device to your PC using the USB cord. The Content Manager will allow you to update your 1340 with the latest software and updates which 'should' fix the problem that you're having with your unit.
Apr 04, 2010 | Magellan RoadMate 1340 GPS Receiver
My roadmate 800 will not turn on. When I use the reset switch, it goes to the blue "Logo" screen then nothing.
if its freezing on the magellan screen, there is a special utility from magellan to fix this issue. fortunately i havent had to use it yet so use caution while installing.
you can get the utility HERE
let me know if you need further help.
bill
Nov 14, 2009 | Magellan RoadMate 800 GPS Receiver
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
Blue screen with magellan logo , this is what I see after turn on my gps receiver, I tryed to push any button but anything change on the screen, to shut it off i have to use 'enter' ,'cancel' and power...
This is the boot screen, Remove the power connection, and reinsert while you press the "Cancel" button at the same time, if done correctly, your Roadmate should continue to boot and enter the user mode.
Mar 16, 2009 | Magellan RoadMate 700 GPS Receiver
Frozen screen
I have a Solution for this Problem,
i have a Software
Any need this contactme i don't know how to post the file,
Fabian
Apr 25, 2008 | Magellan RoadMate 800 GPS Receiver
Magellan roadmate 3000t not working properly...
This happened to me, I had to send it back to Magellan for repair.
Mar 12, 2008 | Magellan RoadMate 3000T GPS Receiver
Temperature below safe level warning when starting GPS
Ahh yes the ever so elusive temp. below safe level error. lol. (sorry) Attached to the radio board are 3 wires connecting to the top of your lcd. This is where the temp is read from. I know telling you this doesn't help, just info. This problem has been fixed from swapping out radio boards (the board that's behind your keypad), additionally swapping out hard drives. I'm not sure if the unit will detect the USB but, if you can, try re-loading whichever version you have ie. 4.32/5.14. As far as end user fixes, I don't exactly have one unless you can find a scrap unit that someone doesn't want b/c it's malfunctioned as well. Good luck and I wish I could of been more help. -Dan
Sep 24, 2006 | Magellan RoadMate 700 GPS Receiver
RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan RoadMate 700 GPS Receiver Logo
183 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Steve
Steve
Are you a Magellan GPS Expert? Answer questions, earn points and help others
